    Request for artists working on themes - needs for (lr-mess/MAME) additions
    lr-messmamescriptmoduletheme
    207 Posts 12 Posters 105.8k Views
    • FollyF
      Folly @DTEAM
      @dteam
      I always commit to the master branch .
      But If you want you can make an other branch .
      You could name it something like "modified".
      • DTEAMD
        DTEAM @Folly
        @folly
        I'll do it in the master
        • DTEAMD
          DTEAM @DTEAM
          @dteam
          I can't put more than 100 files. Do you know why?
          • FollyF
            Folly @DTEAM
            @dteam
            No, I never did more than 100 files.
            Can you do it in parts ?
            Ok, just learned something.
            I says here that a commit is limited to 100 files :
            https://stackoverflow.com/questions/43404202/how-to-upload-more-than-100-files-at-once-in-github
            • FollyF
              Folly @DTEAM
              @dteam
              Nice, I am seeing progress ;-)
              • DTEAMD
                DTEAM @Folly
                @folly
                It works for more than 100, but you have to create a new commit after each 100 files
                • FollyF
                  Folly @DTEAM
                  @dteam
                  Ok, good to know.
                  Edit :
                  I have to go now.
                  Good luck with uploading.
                  I will look at it again tomorrow.
                  • DTEAMD
                    DTEAM @Folly
                    @folly
                    Done, It’s on GitHub!! Retropie theme : Cygnus - Blue flames
                    Theme good for (3D box + marquee (logo) + video) in same time or for single images . Don't use OMXplayer.
                    • FollyF
                      Folly @DTEAM
                      @dteam
                      I just added your theme to the esthemes module-script just to test it out.
                      Installing works ok.
                      I see there is still work to be done for the missing systems as you then get a black screen.
                      But other than that, it looks really great !
                      You should rename your repository to something like "cygnus-blue-flames" or "mamedev-cygnus" (just like I did with carbon).
                      Well, you have to decide for yourself, just don't use spaces in the name.
                      That way you have a unique name and it will not conflict with other cygnus themes if they are in the list.
                      I can't tell you now how to rename.
                      But it wasn't too hard, so I think you will find out how to do it.
                      Then you can just add the line to :
                      /home/pi/RetroPie-Setup/scriptmodules/supplementary/esthemes.sh
                      'DTEAM-1 cygnus'
                      Or after you renamed it :
                      'DTEAM-1 cygnus-blue-flames'
                      • FollyF
                        Folly
                        Here is a nice animation on how the cygnus theme looks like :
                        • DTEAMD
                          DTEAM
                          @folly said in Request for artists working on themes - needs for (lr-mess/MAME) additions:
                          Hi Folly, I renaned it cygnus-blue-flames. Konamih should be fine now.
                          If you found errors for some systems, let me know, Its probably an upload problem. Maybe some files are missing with the 100 files rule. I did a double check, but we never know. Thanks for the animation. It looks great!
                          If some system names are not standardized according to Retropie systems, please let me know as well. I will make the changes. I'll do a double check for that too.
                          • FollyF
                            Folly @DTEAM
                            @dteam
                            I will let you know if I find something.
                            • DTEAMD
                              DTEAM @Folly
                              I added it in my readme file on Github. thanks again
                              • FollyF
                                Folly @DTEAM
                                @dteam said in Request for artists working on themes - needs for (lr-mess/MAME) additions:
                                That's a really nice touch to the readme.
                                I have to that too with my mamedev-cabon ;-)
                                I have made a script for it.
                                I just collect the manual made png "print screens" and then I run the script which makes the animated gif.
                                I push that gif to github and then the link can be used in forum or a readme.
                                Still it shows only the pictures of the ones where I have put games in.
                                I want to be able to fool emulationstation so I can make screenshots of all systems that are in a specific theme.
                                Btw.
                                This is a new logo for coleco :
                                https://retropie.org.uk/forum/topic/31007/reworked-coleco-vision-logo-for-theme-use
                                Perhaps it's usable somehow.
                                • FollyF
                                  Folly @DTEAM
                                  @dteam
                                  I fooled emulationstation by generating a dummy es_systems.cfg with inside the extensions .png and .svg.
                                  So it wil find the .png and .svg an think that they are games.
                                  I renamed my roms directory and placed all theme directories in a new roms directory and removed only the xml files as they conflict.
                                  The animated gif should now contain all systems.
                                  If you don't see it directly then you have to wipe the cache in the browser,
                                  then you will be able see the updated gif.
                                  • DTEAMD
                                    DTEAM @Folly
                                    @folly
                                    I saw this on GitHub. I used your file extension to automatically change the gif on my readme file. Thank you so much. Really good work. I never tire of watching the animation.
                                    Finally, I think my theme is not that bad. I'm not sure if it's good enough for the official Retropie, but in the end I think it's one of the most complete themes available (by the number of systems).
                                    • FollyF
                                      Folly @DTEAM
                                      @dteam
                                      Perhaps we are able to commit this into the original esthemes.sh.
                                      Or you could just ask mitu if he is willing to add our themes.
                                      • DTEAMD
                                        DTEAM @Folly
                                        Hi mitu, are you willing to add my theme to the official Retropie themes list? It contains 168 systems for Retropie. It's a branch of the original cygnus.
                                        Here's the link on GitHub.
                                        cygnus blue flames
                                        model3
                                        Jakks
                                        ColecoVision
                                        MegaDuck
                                        Konamih
                                        Tigerh
                                          You'll need to submit a pull request to the RetroPie-Setup repository and add your theme - see for instance this one. If it's too complicated, I can submit it for you.
                                          DTEAMD 2 Replies Last reply Reply Quote 1
                                          • DTEAMD
                                            DTEAM @mitu
                                            Thanks!!
