    Request for artists working on themes - needs for (lr-mess/MAME) additions
    lr-messmamescriptmoduletheme
    207 Posts 12 Posters 134.3k Views
    • DTEAMD
      DTEAM @Folly
      @folly
      Very nice!!
      • FollyF
        Folly @DTEAM
        @dteam
        PR is done.
        • jamrom2J
          jamrom2 @DTEAM
          @dteam
          All set. Do you need them with a white background as well?
          • DTEAMD
            DTEAM @jamrom2
            @jamrom2
            Yes please. I’ll try both. Thanks !!!! Those ones are perfect
            FollyF jamrom2J 2 Replies Last reply Reply Quote 0
            • FollyF
              Folly @DTEAM
              @dteam
              Created one for Electron (PR is done) :
              I have found a great way to make the images and soften the edges quite fast in gimp :
              • cut out the desired part out of the picture with => scissors
                (once selected all around you can fine-tune the edge by dragging,
                when you are happy then just click in the middle and it's selected)
              • create a new file and select transparency as background in advanced
              • create a new layer and copy and paste the desired file into the new file
              • select the magic tool and select feather edges (set radius on 7 and threshhold on 30) then select the transparent part after selecting press delete, then you will see the edges get a bit transparent and smooth
                (magic, gone are the raw white edges)
              DTEAMD 1 Reply Last reply Reply Quote 2
              • DTEAMD
                DTEAM @Folly
                @folly
                great job
                merged
                I did a last change for Dragon 32. I think It's better now
                • FollyF
                  Folly @DTEAM
                  @dteam
                  Thanks !
                  Works far better and faster now with my new method described in the earlier post.
                  The logo is an svg with a black doubled shadow created with inkscape.
                  • DTEAMD
                    DTEAM @Folly
                    @folly said in Request for artists working on themes - needs for (lr-mess/MAME) additions:
                    @dteam
                    Thanks !
                    I'll try that for Dragon 64 system.png and other images with white contours.
                    For svg, sometime it works sometime not, depending the number of colors and details
                    DTEAMD FollyF 3 Replies Last reply Reply Quote 0
                    • DTEAMD
                      DTEAM @DTEAM
                      @dteam
                      Slowly, I'll rework imperfect images from the theme.
                      • FollyF
                        Folly @DTEAM
                        @dteam
                        Yes SVG's are a pain in the butt sometimes, I agree.
                        We have to make miles for that in order to know how it works ;-)
                        • FollyF
                          Folly @DTEAM
                          @jamrom2 @dteam
                          The dragon32 and dragon64 logos looking great now.
                          Nice job !
                          • DTEAMD
                            DTEAM @Folly
                            @folly
                            Ideas for new systems. see:
                            https://thegamesdb.net/list_platforms.php
                            and
                            https://gamesdb.launchbox-app.com/
                            • jamrom2J
                              jamrom2 @DTEAM
                              @dteam
                              clear background if you need them
                              • FollyF
                                Folly @DTEAM
                                @dteam
                                I have re-done fmtmarty , if you like it I will do a pull request.
                                (PR is done)
                                DTEAMD 2 Replies Last reply Reply Quote 0
                                • DTEAMD
                                  DTEAM @Folly
                                  @folly
                                  Better presentation. Nice work I’ll accept your request
                                  • DTEAMD
                                    DTEAM @Folly
                                    (PR is done)
                                    I forgot to say that your mascot / system files must be less than 280 KB. If they are bigger than that, you will have a white screen problem. Retropie does not seem to tolerate big size image files if you manage many systems (80 systems and more).
                                    • FollyF
                                      Folly @DTEAM
                                      @dteam
                                      Ok, so the mascot of fmtmarty has to be reduced a bit.
                                      Will do that asap.
                                      PR is done reduced to 250kb
                                      • FollyF Folly referenced this topic on
                                      • jamrom2J
                                        jamrom2 @Folly
                                        reworked Game Gear for use... the colors of Green and Blue were off in many of the .svg files
                                        Also made it grey and black for light and dark without outlines.
                                        jamrom2J DTEAMD 2 Replies Last reply Reply Quote 1
                                        • jamrom2J
                                          jamrom2 @jamrom2
                                          created a "new" Defender box for AdventureVision if anyone needs it. I didn't like the one that was out there and I used the other boxes as the baseline to create an improved version. I think this was a pack-in game so it didn't have an actual box.
                                          The scene is taken from Extex's hand-held version, as was the original. I just didn't like how many times it said Defender on it and kept it cleaner looking.
                                          Use for whatever you need it.
                                          jamrom2J 1 Reply Last reply Reply Quote 1
                                          • jamrom2J
                                            jamrom2 @jamrom2
                                            A corrected TRS-80 badge for the CoCo2. Taken from other parts and reworked into this horizontal style badge. This is for US/North America market released units, so it's spelled "Color" rather than "Colour".
