    Can’t Save|Load Games Without Going Through Retroarch Menu
    save gameload games
    8 Posts 3 Posters 1.3k Views
    • dsquaredD
      dsquared
      I am trying to save my game play by using the select + right trigger combination. I am unable to save games this way, much less load them (with the select + left trigger combination). When I try the select + right trigger combination, I do not see the “saved to slot#X” message, in the lower left corner. (nor do I see any message when I try to load a game this way.
      I am however able to go into the Retroarch menu (select + X) and save a game/load a game from there. When I do this, I get the usual messages in the lower left-hand corner. I am unable to load a game that was saved in this manner and then by using the select+left trigger combination.(I can 't use a mixed approach)
      My left and right triggers are working for game play.
      I have tried different emulators: GB, NES, & SNES and the results are the same.
      Is it possible I am missing some global Retroarch configuration?
      Any help resolving this issue, would be appreciated.
      Obligatory Information
      Pi Model or other hardware: 4B+ 2GB & WaveShare GamePI43
      Power Supply: rechargeable batteries
      RetroPie Version Used: retropie-buster-4.6 with Waveshare driver
      Retropie -Setup Script: V4.7.12
      Built From: Pre made SD Image from here
      USB Devices connected: GamePi43
      Controller used: GamePi43
      Error messages received:
      Verbose log (if relevant): None
      Guide used: None
      File: config.txt
      Emulator: lr-gambatte, lr-fceumm & lr-snes9x
        We don't support 3rd party images. Use the image from retropie.org.uk/download and if you can reproduce the issue, post again in the topic.
        dsquaredD 1 Reply Last reply Reply Quote 2
        • dsquaredD
          dsquared @mitu
          @mitu said in Can’t Save|Load Games Without Going Through Retroarch Menu:
          I do not know how to do this. Sorry for wasting your time.
            sleve_mcdichael @dsquared
            @dsquared said in Can’t Save|Load Games Without Going Through Retroarch Menu:
            Did you mean bumper?
            Edit: I just looked at your GamePi case. That doesn't seem to have the full button layout. Do those buttons on the back correspond to L1/R1 (bumpers) or L2/R2 (triggers)? Default configuration (I see you are using a third-party image, so your mileage may vary) uses L1/R1 for quick load/save.
            dsquaredD 1 Reply Last reply Reply Quote 0
            • dsquaredD
              dsquared @sleve_mcdichael
              @sleve_mcdichael
              Yes those are the ones I am trying to setup for save + load ( I guess also dpad to change the save state #)
                @dsquared ah then, I suppose it's probably time to contact the designer of the image you used, or else install the official image from here: https://retropie.org.uk/download/
                You could try reconfiguring your controller, but since it's a 3rd party image there's no guarantee this will work. Are there hotkeys defined in your /opt/retropie/configs/all/retroarch/autoconfig/<controller name>.cfg file?
                • dsquaredD
                  @sleve_mcdichael
                  Thank you for taking the time and effort to reply.
                  " Are there hotkeys defined in your /opt/retropie/configs/all/retroarch/autoconfig/<controller name>.cfg file?"
                  There are no files or subdirectories in the /opt/retropie/configs/all/retroarch/autoconfig/ directory. The closest I can find to a global retroarch config file is : /opt/retropie/configs/all/retroarch.cfg . The "joypad" appears to be setup in the /boot/retrogame.cfg file. Unfortunately I do not see any hotkey pairings being set up in either of these files. Do you have any ideas where hotkey pairings are created (such as Select + X = retroarch menu which is working)?
                  Edit 1: Tried editing /opt/retropie/configs/all/retroarch.cfg to add hotkey assignments found here - This didn't work.
                  #Hotkeys- Hotkeys enable you to press a combination of buttons to do such things as exit emulators, save states,
                  #and load states, as well as any other functionality in an emulator. (In the example below 8 is the select key
                  #and 9 is the start key so when I hold down select and press start it will exit the emulator.)
                  input_enable_hotkey_btn = 8
                  input_exit_emulator_btn = 9
                  input_save_state_btn = 5
                  input_load_state_btn = 4
                  input_menu_toggle_btn = 0
                  input_state_slot_increase_axis = +0
                  input_state_slot_decrease_axis = -0
                    Usually they are in autoconfig/<controller>.cfg i.e. Microsoft X-Box 360 pad.cfg.
