    Help! My Pi 4 has lost its mind!
    pi4displayresolutionwtf
    23 Posts 5 Posters 2.9k Views
      Clyde @JimmyFromTheBay
      @jimmyfromthebay Could still be the cable, especially since you'd moved and/or unplugged the Pi for each card change.
        JimmyFromTheBay @Clyde
        @clyde Yep, it was the cable. New one arrived, hooked it up, everything works a treat including getting rid of the borders. Weird, would never have thought a cable would cause that problem, I always figured it would either work or not.
          @jimmyfromthebay If you're into computers as long as I (starting with a Commodore 64 in the mid eighties), cables are among the first ususal suspects for any kind of strange effects. πŸ‘ΎπŸ‘»πŸ’©
          Glad that it worked for you. Have fun with RetroPie!
