    Retropie won't load
    not loading
    21 Posts 5 Posters 2.7k Views
      raspberry79
      I have Retropie 4.8 on my Pi 4.
      I have Kodi set to boot up first. But one thing is, when i try boot into Retropie, every time that i hit boot to load retropie, it keeps loading back into Kodi not loading retropie?
      • mituM mitu moved this topic from General Discussion and Gaming on
        sleve_mcdichael @raspberry79
        @raspberry79 said in Retropie won't load:
        You're trying to set it back so it boots to EmulationStation instead of Kodi, but when you change the setting it is not being saved?
          raspberry79 @sleve_mcdichael
          @sleve_mcdichael
          I have Kodi install and set to autostart at boot. So when i tried going over to play a game, I went to power on Kodi and hit reboot, but that just reboot back right back to kodi, When i try to exit, same thing. I know once back before a redid it all from reburning a knew copy of retropie, I had kodi to auto start at boot, and when i reboot, i would have to do it 2 or 3 times, when i reboot, loading EmulationStation when come on on the screen and right into Retropie. But know after awhile, i burn retropie image on a 64Gb SD card loading it on the Pi 4 and I got through setting thing up like installing the emulators.
          I when over to install Kodi, and setting it to autostart at bootup. So i got Kodi to load first at boot up but when i hit exit or reboot, it won't let me load into Retropie.
            @raspberry79 if it's set to boot to Kodi then no matter how many times you reboot, it's always going to boot to Kodi.
            That seems wrong though. When you exit without rebooting, it is supposed to load EmulationStation after.
              @sleve_mcdichael
              yes, that what it should do. I keep hitting the enter key on the keyboard but kodi keeps loading instead of loading into Emulationstation. Just trying to figure out how to fix that issue.
                BuZz administrators @raspberry79
                @raspberry79 Please post the contents of /opt/retropie/configs/all/autostart.sh.
                R sirhenrythe5thS 2 Replies Last reply Reply Quote 0
                  raspberry79 @BuZz
                  @BuZz
                  Today, i was able to exit to load Emulationstation to Retropie.
                  But, i would take 2 or 3 or more tries to exit Kodi to load retropie, how to fix that problem and how can u fix it.
                  • sirhenrythe5thS
                    sirhenrythe5th @BuZz
                    @raspberry79 do this:
                    @BuZz said in Retropie won't load:
                    RetroRatio: 1.91
                    Started Games beaten: 2,40%
                      raspberry79 @sirhenrythe5th
                      @sirhenrythe5th
                      where do i post it at, my first time at everything
                        @sirhenrythe5th
                        autostart.sh should be small enough to paste in a message here. Just put the content between code blocks:
                        ...like this
                        (Those are back-ticks.)
                          @sleve_mcdichael
                          ah, u talking about ssh to the pi
                            @raspberry79 yes or you can connect a keyboard and access the terminal (if you can quit Kodi without rebooting. Otherwise yes SSH would allow you to check remotely.)
                              @sleve_mcdichael
                              Yes, i had today manage to exit Kodi to load retropie Emulationstation
                              how would i get to the terminal window, I have the keyboard going.
                                @sleve_mcdichael
                                From EmulationStation you can press F4 on an attached keyboard, or on a controller press Start and then choose Quit.
                                  @sleve_mcdichael
                                  So i got the terminal window up ed3959ca-bf4e-49c9-864c-f622c8645526-image.png
                                  So if i type this in /opt/retropie/configs/all/autostart.sh
                                  then will it fix the problem when exiting kodi to load emulationstation
                                    No, we need to see the contents of that file. Please type:
                                    cat /opt/retropie/configs/all/autostart.sh
                                    ...and show us what it says.
                                      @sleve_mcdichael
                                      Ah, i just type that into the terminal window and it will open up to the problem that u want to get and past for u to see.
                                        @raspberry79 yes.
                                          @sleve_mcdichael
                                          I typed it in and this comes up
                                          Do anyone have the same problem or is there anyone who can just exit kodi and load into ES
                                            The autostart.sh is ok, it instructs the system to boot kodi and (when it exits) start emulationstation.
                                            What might happen is kodi crashing on exit and then automatically restarting, thus not allowing EmulationStation to start.
                                            Go into Kodi settings, choose System and then in the Input sub-menu, go to Peripherals and disable the CEC Adapter. Then restart your system and see if exiting kodi still has issues.
