Cannot connect RetroPie to Wi-Fi OR Bluetooth
Hello everybody! I recently discovered my old Raspberry Pi. It connected to Wi-Fi, and played games from many different consoles. However, upon discovering that it was on Raspbian stretch and was no longer supported, I decided to do a clean install and start over on a recent version of RetroPie, now on Raspbian Buster.
It was then that I realized something got messed up.
I do not have a usb keyboard, so I enabled ssh and connected with my laptop. I tried connecting a Bluetooth keyboard-something that had worked before the update-only to find that now it stopped working! I now get the error “ An error occurred connecting to the Bluetooth device
(Creating device failed:org-bluez.Error-AuthenticationCanceled:Authentication
Canceled)” instead of the normal keyboard authorization. I have tried removing the keyboard and rebooting, all to no avail.Even worse, my Wi-Fi won’t connect either! It connected just fine on stretch, but it won’t connect on buster. I tried resetting my network, moving the device to another room, and nothing worked. I can’t even install packages, or update the setup script!
I enter the password with the controller using the new on-screen keyboard, and it says connecting. After a few minutes it says “Unable to connect to network [Network name].I can access the terminal from ssh. I just don’t have a keyboard.
I have a Kintaro Super Kuma 9000 case which runs Raspberry Pi 3.
I have flashed my SD again, but it didn’t work. I tried both installing directly from Raspberry Pi etcher and BalenaEtcher, but it made no difference.
I would like to resolve the Wi-Fi first, and then the Bluetooth! The Wi-Fi is more important.
Any help would be appreciated, thanks in advance!
Edit: I forgot to mention that I can connect it to my laptop with an Ethernet cable and a shared connection.
@JoeyAW First of all, I’d recommend you to try to get a wired keyboard and start with a fresh new image. The wired keyboard will remove all the possible variables that could be messing the initial configurations. From there, press f4 and run Raspi-config from the CLI so that way you don’t even have to set up a controller.
Keep in mind that the wifi is blocked until you select a country.
On buster, you need to set the Country first (via raspi-config), before configuring the Wi-Fi.
Try adding that info in a
wap_supplicant.conffile - see https://retropie.org.uk/docs/Wifi/#connecting-to-wifi-without-a-keyboard_1 and then check if the BT radio gets enabled also to connect your keyboard. -
@mitu I have tried connecting with a config file, however I will give it another shot.
Also what do you mean by the Bluetooth radio?
@xerozkeel I have tried selecting the country, but to no avail. I did just start with a new flash, but I do not have an available usb keyboard. I might try booting a Wi-Fi file from a config again, to see if that works.
@mitu I got no result. It still isn’t connected to the internet after unplugging the Ethernet, making the file and booting it. It still says to set my Wi-Fi country after turning it on.
@JoeyAW If you're connected via Ethernet, the Wi-Fi isn't started, so any configurations should be tested on Wi-Fi only.
@mitu I always unplug it from Ethernet and it does not do anything. Even after editing the config file it still says my country isn’t specified. I think I’m gonna try installing raspberry pi OS and seeing if that connects. It it doesn’t, I might have accidentally physically damaged my board. Is that possible? One time before I installed it I attempted to slide in the SD card, but accidentally slid it into the case and onto the board. Could that have damaged the Wi-Fi?
@JoeyAW said in Cannot connect RetroPie to Wi-Fi OR Bluetooth:
Unlikely.
@mitu Ok, is there anything else I could try or is it just done?
@mitu So I flashed raspberry os onto another sd card. Same problem, unable to connect to network.
@JoeyAW Can you post the
dmesgoutput from the system on pastebin.com ? -
@mitu I fixed it! There was a problem with the Wi-Fi links around the house, as i was in the back room. It appears that the keyboard has a problem, so that is probably fine as I connected a ps3 controller via Bluetooth. Thank you!
