    Marquee on second monitor (need guidance)
    marqueeartworkconfigurationmonitorsretropie
    1 Posts 1 Posters 400 Views
    • W
      wtstreetglow1
      Hello,
      Does RetroPie support second screen marquees by default.
      Or does it require a special package be installed before it can be configured. The only thing I have found is below:
      https://github.com/losernator/PieMarquee2
      Also, is there anyway to have the scraper populate the necessary files for use on this second monitor and have RetroPie fill them to the screen so that there will hopefully be no need to touch every image wanting to be used for the marquee for rescaling?
      Also, what is the difference in wheel art and marquee?
      It looks like the package above needs the artwork stored in the piemarquee2 subfolders, does an yuh one know if there is a way to have the already scraped info mirrored to the proper folders to get the marquee going.
      I'm essentially trying to keep from doing a bunch of manual work in order to keep this going as I add new games to the system.
      Thank you all for any guidance/ knowledge you can give.
