    Issue with 8bit Do SN30 Pro Bluetooth gamepad
    8bit do8bit do sn30gamepadbluetoothtriggers
    27 Posts 3 Posters 4.1k Views
    • I
      IGA
      Hardware: Pi 4 - 4gb
      Power supply: 5V 3A Power Supply
      RetroPie V.4.7.19
      Built From: Pre made from RetroPie website pi4 image
      USB: logitech keyboard
      Controller: 8bit Do SN30 Pro Bluetooth gamepad
      VideoOut: crt-tv via composite !
      Hello!
      Can't normally configurate this gamepad.
      After pairing with retropie\raspberry in retopie setup\bluetooth I can't normally remap buttons in emulation station menu - both trigger buttons (R2 and L2) are undetected, when i press them nothing happens.
      Gamepad is normal. It's work fine with PC or recalbox.
      More of them - with this Bluetooth gamepad any rom started after 1 minute black screen. ( with my old 360gamepad games started immediately after loading screen)
      • I
        IGA @IGA
        Well, as i understood it's need to use pairing in Switch mode and all will ne fine...
        Close
          Pairing works also in XInput mode, but you have to install the xpadneo driver first, from RetroPie-Setup.
          I 3 Replies Last reply Reply Quote 0
          • I
            IGA @mitu
            @mitu oh, thank you for information!
            • retropieuser555R
              retropieuser555
              8bitdo can be a little finicky (I have the pro 2, SNES FC30, g bros adapter and n64 mod kit) but thankfully they have 4 modes, I guess that controller is no different? I tend to use dinput and it works ok on RetroPie. Then use switch mode for my desktop computer
              Pi 5 4GB
              • I
                IGA @mitu
                @mitu said in Issue with 8bit Do SN30 Pro Bluetooth gamepad:
                Stop....
                With Switch Pro Controller mode all button are work correctly but no vibration function. Vibration is absent :(
                I've download xpadneo driver from drivers packages , remove Pro Controller from Bluetooth menu and pair gamepad again in Xinput mode .
                • The effect still the same - triggers L2 and R2 - doesn't work.
                  Why???
                • I
                  IGA @mitu
                  Still need a help.
                  How to make this gamepad normally work in Xinput mode?
                  Or how to get vibration in switch pro controller or Dinput modes?
                  • retropieuser555R
                    retropieuser555 @IGA
                    @IGA Which games/cores/emulators are you trying to get force feedback on?
                    Pi 5 4GB
                      Make sure you have an up-to-date RetroPie installation, otherwise you'll get an outdated xpadneo driver.
                      After you paired it via Bluetooth, test the controller with jstest and see if L/R are detected. Run from the command line (either from the console or via SSH.
                      jstest /dev/input/js0
                      and press the buttons to see if they register. You can interrupt the test by pressing Ctrl-C.
                      • I
                        IGA @retropieuser555
                        @retropieuser555 said in Issue with 8bit Do SN30 Pro Bluetooth gamepad:
                        • dreamcast\ps1: PCSX ReARMed\ duckstation. Redream for dreamcast. Any games that supported it...
                        • I
                          IGA @mitu
                          @mitu could you remind how to up date installation - i've forgot (i don't need and want update all retropie at all, cause now after my last update work fine and i don't want to configure something again, that could need to be configurated after new update or something else - i just need update installer only to install new xpadneo)
                          • I
                            IGA @mitu
                            I don't see the point - at Switch or Dinput this buttons are work...
                            I mituM 2 Replies Last reply Reply Quote 0
                            • I
                              IGA @IGA
                              but i've try - and what I need to get?!
                                mitu Global Moderator @IGA
                                @IGA said in Issue with 8bit Do SN30 Pro Bluetooth gamepad:
                                Ok then.
                                • I
                                  IGA @mitu
                                  Ok then.
                                  And what so? ))
                                  • retropieuser555R
                                    @IGA With the force feedback, i'll remind myself how to set that up for my 8bitdo Pro 2 as it should probably be the same as the older version. What firmware are you on btw? And force feedback works on windows in retroarch or redream or any other emulators?
                                    Pi 5 4GB
                                    • I
                                      At windows and retroarch feedback works well as a retropie with Xinput (but in Xinput mode emulation station on retopie can't recognize both triggers buttons). At micro-sd flash card with recalbox all work fine too - and vibration and all buttons
                                      How find out what a firmware in btw? What is btw?))
                                      • I
                                        IGA @mitu
                                        Well, i've go to retropie setup, then make Update Retropie-Setup script. Go to mange packages\manage drivers packages and remove xpadneo. Then install once again - got:
                                        Package Origin: source
                                        Build Date: 2023-11-08T12:13:38+00:00
                                        Built from source via:
                                        Type: git
                                        URL: https://github.com/atar-axis/xpadneo.git
                                        Branch: v.0.9.5
                                        Commit: d2453218678cd5069be0c51f331593b98ace6f62
                                        Date: 2022-09-17T22:39:22+02:00
                                        • triggers still not recognized in Xinput mode....
                                        • retropieuser555R
                                          @IGA Just had a quick google, does this solve your problem?
                                          You mentioned you're using lr-pcsx2-rearmed and duckstation, do you mean lr-duckstation? Also in redream's menu can you map your controller triggers manually? As it seems the issue is in emulationstation rather than retroarch. And given L2 R2 don't do a lot in emulationstation you don't really need them working.
                                          Pi 5 4GB
                                          • I
                                            yes. Exactly in emulationstation cause i can't remap l2 and r2 in menu of E.S. And seems to be xinput driver too,
                                            About this video tutorial fix - is bad solution for me, cause i use several 360 gamepads, that work correctly, and when i need or want to choose them i'll need to remap buttons in retroarch each time again - it's sucks
                                            Why at recalbox this gamepad work fine by default? - maybe i should took some drivers files from there and replaced them on retropie or something like this??
                                            And even does it is worked i won't do like this - cause i wan't remap buttons each time in each emulators when i want to use any others gamepads - it's nconvenient. For a what? - Xinput there , and Xinput there - all layout the same - comfortable. But if use Dinput, yes, in this way we need change all layout buttons. That why nobody use D input now.
                                            Ok. maye if no methods to solve problem with Xinput, maybe there are methods to get vibration in Switch mode on Retropie?
