    Analog Joystick/Raspberry Pi/Daphne Dragons Lair left/right not working - config
    retropiedragonslairdaphneanalog joystick
    9 Posts 2 Posters 687 Views
    • O
      OldSchoolSk8r
      I have read some of the other posts, and no matter what I've tried, I can't get the left/right to work on my analog arcade joystick for my arcade box. I am currently running Virutalmans 512gb on a raspberry pi 3, with 2 analog joysticks, 6 player buttons, 2 coin and 2 player buttons, and 4 extra buttons. I am trying to get Dragon's Lair to work. I have forward/backward working, coin, player 1/start, sword, and quit. But for the life of me can't get the left and right to work. Now, with this config, i can get 2 buttons to go left and right, but don't really want to do that. The funny thing is, the 2 buttons that go left and right are set for 0 in the dainput.ini, which should mean those buttons are disabled. So Button 2/3 I believe are doing the left and right, and they are set to 0. Any help would be GREATLY appreciated. I do not know much about the inner workings, it was a prepkg file i uncompressed to a sd card for the Pi. I do have access to the configs/etc. All the other emulators work fine with the buttons/analog joysticks (cept intellivision another headache). THANK YOU!
      [KEYBOARD]
      KEY_UP = 273 114 5
      KEY_DOWN = 274 102 7
      KEY_LEFT = 276 100 4
      KEY_RIGHT = 275 103 6
      KEY_BUTTON1 = 306 97 2
      KEY_BUTTON2 = 308 115 0
      KEY_BUTTON3 = 32 113 0
      KEY_START1 = 49 0 8
      KEY_START2 = 50 0 0
      KEY_COIN1 = 53 0 7
      KEY_COIN2 = 54 0 0
      KEY_SKILL1 = 304 119 0
      KEY_SKILL2 = 122 105 0
      KEY_SKILL3 = 120 107 0
      KEY_SERVICE = 57 0 0
      KEY_TEST = 283 0 0
      KEY_RESET = 284 0 0
      KEY_SCREENSHOT = 293 0 0
      KEY_QUIT = 27 113 9
      END
        We don't support 3rd party images, especially the ones loaded with ROMs. Please use the image from https://retropie.org.uk/download if you wish to get support here in the forums.
        Thank you.
        O 2 Replies Last reply Reply Quote 0
        • O
          OldSchoolSk8r @mitu
          @mitu Got ya. Installing it now. Thanks!
          • O
            OldSchoolSk8r @mitu
            @mitu Ok, so now I've put the RetroPie image on a 128gb sd card with Raspberry Pi imager. Picked Raspberry Pi 3, Emulation and Game OS/RetroPie 4.8 for Raspberry Pi 3. It was successful. I then put it in my Raspberry Pi 3, turned it on, it went through a lot of setup, then was stuck on this screen for over an hour (Screenshot 1). I turned it off, back on. It is now sitting at this prompt (Screenshot 2). Do I need to start a new thread on this?! Seems like the setup isn't right on initial startup. Not sure how I can copy/paste the screen logs on here.
              This doesn't seem to be the Pi3 image - the error shown and the last of EmulationStation seems to indicate you've written the Pi4 image (?)
              Also, you said your card is 128Gb, but the information shown at the start shows the card is only 32Gb - are you sure the sdcard is ok ?
              O 3 Replies Last reply Reply Quote 0
              • O
                OldSchoolSk8r
                So re-imaged the sd card, went through same thing. Saw config msgs, all green oks. Retropie Graphic joystick screen, goes back to config msgs, and i get the * failed to add service - already in use?
                • O
                  OldSchoolSk8r @mitu
                  @mitu Sorry, I switched to a 32gb just to see if maybe it was my sd card. I actually found out i have a Pi4 sorry, I bought it during COVID and its been a while. I am currently imaging a retropie 4 image to it now and am going to try. I am still on a 32gb card.
                  • O
                    OldSchoolSk8r @mitu
                    @mitu OK, so I got the 4 image on the card, booted up fine, got to the controller setup, had issues with this cause it automatically wants a D pad up to start, i had only my analog plugged in, and didn't think i should use that for D pad. So I hooked up my Xbox One controller through USB, and configured that first for all the standard buttons, that way i could move around the menus. then i setup my analog 1, analog up/down/left/right to the joystick on the arcade box, then start, select, a, b, x, y, left/right bumpers to the 6 buttons i have and the last one i can't remb to a button on the front of the arcade. now i need to connect it to my wifi so I can copy my roms to this correct? which i go into the retropie settings under config, takes me out to a blue screen, i pick my 5g network, it then asks for my password. I either use my usb keyboard, and type it in, or use the joystick select the characters, move to ok (which looks greyed out) and click the select button. Nothing happens, i then push a couple buttons on the analog and connecting comes up, again, nothing happens, and i hit more buttons (on the analog) and i get this garbage at the bottom of the screen. It doesn't matter if i use the Keyboard, XBox One controller, or the Analog. I have also tried each separately because maybe a conflict. nope. See screenshots
                    • O
                      OldSchoolSk8r @mitu
                      @mitu I got it connected finally. Going to try and get Daphne enabled, and Dragon's Lair on there under the Daphne roms folder. Just going to use the USB flash drive to do it for now.
