    Help getting Amiberry to work on RetroPie Thanks
    pi3 b+retropie 4.8amiberrynew to retropi
    19 Posts 3 Posters 2.0k Views
      Dekawar
      seems some are or have had the problems i am having. i have not moved to UAE yet.
      seeing that they said Amiberry was the easiest one to setup.
      and i like not having to swap the floppy's to play games. so the LHA files are ok. (maybe i can find LHA's for the ADF files i have or a way to make them in to LHA's)
      But the Problems i am having are with it. Are after getting it all worked out and setup then getting the Amiberry installed with the installer "Manage optional Packages" so now have Amiga folder showing up to put the games .LHA
      E:\retropie\roms\amiga with a jump drive and putting the
      kickstart files in the jump drive E:\retropie\BIOS
      so all seems good i looked at the files on the Pi and they seem to have copied over good and in the place it said they should be is there another place to put them???
      but when i try and run a game.
      it goes to a black screen and then winks back to the pick a game screen.
      if i keep clicking on the A key it loads up a screen "System: Amiga" asking to select "default emulator" ES, ER,
      VE, FE, FR, X, Q.
      so when looking "ER" at Bios the names to not match the ones i uploaded. thinking it would be named the same as the ones uploaded.
      not sure if this is the problem. do i need to do something other than just putting them in that folder???
      (( Please help)) i seen something that the updater is not using the newest one will start looking at that.
      my system is a Raspberry Pi3 B+ in the USA.
      Hisense 4 K HDMI tv
      XBox corded controller. Keyboard and mouse.
      have been doing like the video said using the USB jump drive to move files over. "Raspberry Pi 4 Retropie - Amiberry Setup MikeyGRetro"
      and use many other videos to help with setting up Retropie on the Raspberry Pi 3b+ "RetroPie 4.8 Setup and Install Guide for the Raspberry Pi" Wagner's TechTalk.
      i have had UAE for Droid on my phone for 10 years i think. with the Amiga forever Kickstarts. but made a cool 3D printed Amiga case for my Pi 3b+ and wanted something i could use on the TV and the kids could play.
      i do have Amibian working on another flash card on the Pi 3+ but just not as easy to use as the videos said RetroPie is. and this would be good. have seen some info on the site saying need to use the numerical updater seeing the auto one is not working right??
        mitu Global Moderator @Dekawar
        @Dekawar said in Help getting Amiberry to work on RetroPie Thanks:
        They need to be put in retropis/BIOS/amiga. Do that and then re-install Amiberry. Does the +Start Amiberry link work and starts the emulator ?
        D 2 Replies Last reply Reply Quote 1
          Dekawar @mitu
          @mitu ok thanks i checked this and not sure if i moved them to the folder or if it Auto did it. but the files are in that folder.
          this is the video i used to install it. i did use the Jump Drive. but also checked in file manager on the Pi 3b+
          i am getting the black screen after i try and launch any game or the start Amiberry.
          Now if i tap the A key it will bring up a page to pick the Bios no matter what i do or pick,
          it goes black for 5 seconds and then back to the pick games list. Thanks for the help.
            Which version of RetroPie do you have installed and how did you install it ? The Amiberry UI should start regardless of any kickstart roms being available or not.
            Can you post the contents of /dev/shm/runcommand.log, taken after starting a game or just Amiberry standalone ?
              Dekawar @mitu
              @mitu i am downloading it from the site Version 4.8.9 ok what it shows.
              "Execut ing: /opt/retropie/emulators/amiberry/amiberry.sh"/home/pi/RetroPie/rons/aniga/1869_v1.0_AGA.lha"model CDTV
              Paranelers:
              Launch ing
              autoload ^hone/pi^RetroPierrons/aniga/1869_v1.0_AGf.Iha =-nodel CDTU -G
              /aniberru
              malloc (: unsorted double linked list corrupted
              /opt/retropie/emulators/amiberry/aniberry.sh: line 10?: 2449 Aborted
              "$enu lator" "$(parans[0])"
              I used my phone to grab this off the screen. so it has typos. i do not seem to be able to copy the file to my USB stick like i did with Amibian file system. so i will try and reinstall it all.
              seeing it shows corrupted and double linked list.?
                Does it show the same error when opening just the emulator, with the +Start Amiberry entry ?
                EDIT: just to rule out the ROM file, can you also install lr-puae and try starting the game with it ? You can choose which emulator to use for a system/rom from the runcommand launch menu.
                  Dekawar @mitu
                  @mitu yes says unsorted double linked list corrupted
                  /opt/retropie/emulators/amiberry/aniberry.sh: line 107: 12145 Aborted
                  "$enulator" "$(parans[@])"
                    Dekawar @mitu
                    @mitu Which version of RetroPie do you have installed and how did you install it ?
                    i did install it from the https://retropie.org.uk " The "First Installation" instructions said.
                    Installation
                    First, insert the MicroSD card into into your computer
                    Download the RetroPie .img.gz image from the official website for your Raspberry Pi model.
                    If you use Raspberry Pi Imager (recommended), this linked me to this site. https://www.raspberrypi.com/software/
                    not sure if this is what i had used on the 1st one i did for Amibian it worked but was not a nice as retro pie for playing games.
                    checking on this now. the video said to goto this other link for a faster setup. https://www.raspberrypi.com/software/ and the instructions on the one site said to do the same.
                    S D 2 Replies Last reply Reply Quote 0
                      sleve_mcdichael @Dekawar
                      @Dekawar you posted in this other thread: Getting an amiberry error when trying to run an Amiga game on a new system:
                      thanks this might be what going on with mine.
                      Did you try the fix shown there ie. placing amiberry.conf in configs with a rom_path to the bios folder?
                      @mitu, is there anything to this?
                      @sleve_mcdichael said in Amiberry broken on Pi 4/Buster:
                      malloc(): unsorted double linked list corrupted
                      Aborted
                      Investigating, it seems related to amiberry.conf:
                      if amiberry.conf exist with a defined rom_path= to the kickstarts, then RP binary does work,
                      This COULD be work-around by pre-populate conf with rom_path value, but it don't explain why github version still work fine with no conf at all.
                           # set various media paths to the 'amiga' rom folder
                      -    if [ -f "$md_inst/conf/amiberry.conf" ]; then
                           iniConfig "=" "" "$md_inst/conf/amiberry.conf"
                      +    iniSet "rom_path" "$biosdir/amiga"
                           iniSet "floppy_path" "$romdir/amiga"
                           iniSet "harddrive_path" "$romdir/amiga"
                           iniSet "cdrom_path" "$romdir/amiga"
                           iniSet "lha_path" "$romdir/amiga"
                      -    fi
                      +    chown "$__user":"$__group" "$md_inst/conf/amiberry.conf"
                      Current script module does set some paths in conf, but the behavior confuse me. Since the conf file is not exist on clean install, these values are not set at first. Defaults are then used ($md_inst) for some time until (optional) if user chooses to reinstall/update amiberry. Only at that time, file DOES exist, and so paths are now CHANGE to use $romdir instead of $md_inst like they had been using. Is this really the intended way, and if so then why?
                      D mituM 2 Replies Last reply Reply Quote 1
                        Dekawar @Dekawar
                        @Dekawar have not tried it yet. sorry, with the Amibian i was able to move files from the Flash OS Drive to the USB drive. with the last setup of Retro Pie it would not let me do that. i could not even goto Media and see the drive. but it was taking all the files off the drive. need to find out why windows 11 is not letting me connect to it over network. some setting on my system im sure.
                        looks like its a windows 11 Pro thing. https://techcommunity.microsoft.com/blog/filecab/accessing-a-third-party-nas-with-smb-in-windows-11-24h2-may-fail/4154300 ok this was able to fix the network problems.
                          Dekawar @mitu
                          @mitu ok i reinstalled everything and have the network connection to the Pie working also.
                          going to move the jump drive over. it does not have a retropis/BIOS/amiga the video said to just drop them in the retropis/BIOS i want to test it and see if it makes the folder and moves it to that location.
                          only going to send this 2 kickstarts " they are the 2 i could find that say it works LHA file.
                          Kickstart v2.05 rev 37.350 (1992)(Commodore)(A600HD)[!].rom
                          Kickstart v1.3 rev 34.5 (1987)(Commodore)(A500-A1000-A2000-CDTV).rom
                          have not found this one.
                          Kickstart v3.1 rev 40.68 (1993)(Commodore)(A1200).rom 1483a091 / 1d9aa278 ✔️
                          https://github.com/BlitterStudio/amiberry/wiki/Kickstart-ROMs-(BIOS)?fbclid=IwY2xjawH5D3ZleHRuA2FlbQIxMAABHWanz_KoETPsyk22mfLoQXZn91aAOwCOnv9kdphdorUFfczC-sgkq0wB5w_aem_cDPoYEYoSc-3ZdGp2VTd3w
                          they have a different name than the ones i have from cloanto.amigaforever.essentials
                          so was thinking that might have been a problem.
                          so it did not make a Amiga folder in retropis/BIOS/ on the USB or in the home/pi/RetroPie/BIOS. even after restarting it. so i made sure everything was done as instructed and it still does not work. when i try to just run the +start Amiberry i get this. 50e9079f-62ab-4a05-9a0f-9a15fe26fad7-image.png
                          and then booted back to the AMIGA +start AMIBERRY list.
                          Parameters:
                          Executing: bash "/home/pi/RetroPie/roms/amiga/+Start Amiberry.sh"
                          ./amiberry: error while loading shared libraries: libserialport.so.0: cannot open shared object file: No such file or directory
                          sleve_mcdichael not sure what files you are looking at or ware they are at? anything else to help me thanks.
                            Dekawar @sleve_mcdichael
                            @sleve_mcdichael am working on it now. Wow had to go back and read it. and trying it now. Yeah, you just need a file /opt/retropie/configs/amiga/amiberry/conf/amiberry.conf with the following content:
                            rom_path=/home/pi/RetroPie/BIOS/amiga
                            (Make sure it's capitalized exactly like this, and if your install is under other than the default pi user, then make sure to edit the home dir path /home/pi accordingly.)
                            See for more details:
                            https://retropie.org.uk/forum/post/301768
                            https://github.com/RetroPie/RetroPie-Setup/pull/4009
                            Does getting a different pre-compiled binary make sense?
                            If so, how do you install a different pre-compiled binary on the Amiberry in RetroPie?
                            If you get the amiberry binary from the release page and replace the one in /opt/retropie/emulators/amiberry, it can work even without placing the conf file. But it is easier I think just to place the conf and then it works with the default RP provided binary.
                            posted it here for if anyone reads this trying to fix it also can see this.
                            @sleve_mcdichael ok i made the file amiberry.conf copyed and put the text in you gave us.
                            saved it over network to a the spashcreens fold and now going to move it to
                            if this works wow. Thanks does this mean i need to move or make a file called amiga in BIOS/ and that is where i need to put my kickstarts?
                              Dekawar @Dekawar
                              this did not work. going to check and make sure the files is still in the right place.
                              so i am looking and this seems to be a Big ongoing problem. reading a lot of posts on this. https://github.com/BlitterStudio/amiberry/issues/1392
                              looks like tomorrow i might get around to trying this one.
                                mitu Global Moderator @sleve_mcdichael
                                @sleve_mcdichael said in Help getting Amiberry to work on RetroPie Thanks:
                                I think so, the rom_path missing is breaking Amiberry.
                                This means you have not updated your RetroPie-Setup. Do a full update for RetroPie and then re-install Amiberry. Create the following file (if it's not there) - /opt/retropie/configs/amiga/amiberry/conf/amiberry.conf , then edit it and add to it:
                                rom_path=/home/pi/Retropie/BIOS
                                This teaches amiberry to look directly under BIOS for kickstart files.
                                After the .conf file modification, start again Amiberry and see if it starts without errors.
                                EDIT: actually, just update RetroPie-Setup and reinstall Amiberry, without any edits. See if that fixes the issue.
                                  Dekawar @mitu
                                  @mitu said in
                                  i was able to get to a screen with workbench drawers open. could move the mouse but no button worked.
                                  so in what file do i need to put the Rom's for lr-puae?
                                    If you mean where to put the kickstart ROM files, use the BIOS folder (no amiga subfolder for it).
                                      Dekawar @mitu
                                      @mitu like in the Video i just put them in the
                                      /home/pi/RetroPie/BIOS seeing that is what the video had said.
                                      so i tested it when i reinstalled it all.
                                      and did it like it said.
                                      again it did not make the amiga for the bios.
                                      so i made a it and put the Kickrom's in it.
                                      still does not work. really wish i could get this to work.
                                      any help getting it to work is welcome.
                                      i have them in both places lol still does not work
                                        Dekawar @mitu
                                        @mitu have really been hoping an update would fix it.
                                        i like the RetroPie setup it is fun and easy to use. The kids like it. and to let them play some old Amiga games would be so nice.
                                          @mitu have really been hoping an update would fix ..
                                          If you have the right BIOS files (as specified in the documentation) and the game still doesn't work, then the issue might be the game. What game(s) are you trying to start, what is their filename and which emulator (lr-puae2021 or amiberry) are you using ?
                                          If you start the Amiga test kit image, does it work ?
