    3DO, MAME and FB NEO Question
    mame3dofb neo
    17 Posts 5 Posters 2.8k Views
    • JirynJ
      Jiryn
      I'm running a PI 5 16GB with a 2TB SSD.
      I'm using the original OEM PSU.
      How is the 3DO emulation?
      Anyways, what's the best, most compatible MAME to use with the console?
      2010?
      I do want to play Carnevil if possible and any other games similar.
      Finally... this was an issue i had on my PI4.
      How do I differentiate the title of my archives?
      Both FBNeo and Mame2010 said "Arcade" on the main RetroPie Menu.
        barbudreadmon @Jiryn
        MAME2010 is trash.
        MAME (current), MAME2003+ and FBNeo are the only arcade emulators you should ever consider using on a pi5.
        Out of those 3, only MAME (current) is gonna emulate 3D'ish games like carnevil properly.
        More details about the different arcade emulators here.
        JirynJ 1 Reply Last reply Reply Quote 0
        • sirhenrythe5thS
          sirhenrythe5th
          3DO -> runs great (on a Pi5, which you have)
          seperate Systems in ES -> your arcade-roms are in the directory /home/pi/retropie/roms/arcade/"
          Move the roms to ".../roms/fbneo/" and ".../roms/mame/" to make these systems(names) show up in ES.
          RetroRatio: 1.88
          Started Games beaten: 2,47%
          Site Rank: 4382/93743 ranked users (TOP 4.76%)
          Last seen in [The Legend of Zelda: Lost in Time (HACK) [N64], exploring Hyrule at Night]
          S JirynJ 2 Replies Last reply Reply Quote 0
            sleve_mcdichael @sirhenrythe5th
            @sirhenrythe5th said in 3DO, MAME and FB NEO Question:
            ...don't exist in default RetroPie. Try fba and mame-libretro folders if you want that separation.
            • JirynJ
              Jiryn @barbudreadmon
              @barbudreadmon said in 3DO, MAME and FB NEO Question:
              MAME2010 is trash.
              What library is MAME CURRENT?
              Is it an optional package?
                sleve_mcdichael @Jiryn
                @Jiryn said in 3DO, MAME and FB NEO Question:
                Experimental, I think.
                • JirynJ
                  Jiryn @sirhenrythe5th
                  @sleve_mcdichael said in 3DO, MAME and FB NEO Question:
                  I am going to explain this better, and hopefully easier to understand.
                  I don't remember what folder I had them in, but the libraries WERE Separated
                  However, when in the UI selecting the system it had two libraries, both named ARCADE so I was never sure if I was in FBNEO or MAME2010's library.
                  • JirynJ
                    Jiryn @sleve_mcdichael
                    @sleve_mcdichael
                    I mean what's the name and what's the rom type?
                    0.276?
                    How well does it run?
                    B mituM 2 Replies Last reply Reply Quote 0
                      0.276?
                      According to https://retropie.org.uk/forum/topic/29682/development-of-module-script-generator-for-lr-mess-lr-mame-and-mame-standalone/2221, yes.
                      Undoubtedly faster than mame2010 for carnevil, MAME introduced multiple arm64 dynarecs in 0.274, making it ~4 times faster than it used to be for the games using those dynarecs, which includes carnevil and most of the demanding games.
                      I might recommend the standalone version though, i've seen mixed reviews about those dynarecs in the libretro port.
                        mitu Global Moderator @Jiryn
                        As explained in the docs, it installs the latest monthly release for MAME - at this time it's indeed 0.276.
                        FBA has it's own icon, different than arcade, so you probably didn't use it before. You can start using it now, if you wish to have fbneo as a separate system, though most of the ROMs are identical with MAMEs.
                        • JirynJ
                          Jiryn @mitu
                          @mitu probably used the arcade folder before..
                          It's been a few years, but I remember being confused AF.
                          Thank you!
                          Thank you!
                          • JirynJ
                            @barbudreadmon
                            Now I just need to find the romset.
                            It should be the same # right?
                            Sorry, this part always bugged me, that there are so many sets.
                            Wait, am I over thinking ROMSETS?
                            I always thought ROMS in newer sets were newer ROMS, made to take advantage of the advancements and updates in MAME code.
                            or are they the same ROM?
                            (Aka like can I use the 2003 or 2010 romset with current MAME?)
                              No, new ROMs are not 'created' to take advantage of new MAME code.
                              No.
                              This question has been answered countless times and and it's pretty well documented. Get the ROMSET for the emulator version you have and - optionally - validate it against the .dat file(s) produced by the emulator with a ROM validation tool like ClrMamePro/ROMluator/Romcenter/etc.
                              See
                              • https://retropie.org.uk/docs/Arcade/
                              • https://docs.libretro.com/guides/arcade-getting-started/
                              • https://docs.libretro.com/library/fbneo/#building-romsets-for-fbneo
                              • JirynJ
                                @barbudreadmon
                                WELP that famously didn't work.
                                Spent the last couple days downloading a terabyte of data, all the roms, chds and BIOS to run MAME .276 on the PI..
                                I could hear sounds, but graphically it was a gabled mess that looked like colored static with nothing distinct.
                                Tried older games like Sunset Riders, Golden Axe, and some System 32 games.. had sound but no the image was the same static mess. (Literally looked like a static screen but in various colors)
                                FBNeo seems to run System 32 amazingly now..
                                Anything I need the MAMES for now? Beyond 3D games which you're right, would be an issue (Someone showed a few of them working fine a few months back, which is why I asked)
                                  did you test both standalone and the libretro core ?
                                  • JirynJ
                                    @barbudreadmon
                                    Just the standard...
                                    I should have tried to libreto core, but worried it wouldn't perform well either.
                                      @Jiryn either way, you should probably seek help in the topic dedicated to mame current i previously linked.
