    Installed 4.0.2 and roms not working
    4.0.23.83.8.1amigaroms
    39 Posts 10 Posters 20.5k Views
    • herb_fargusH
      herb_fargus administrators @SimonF1
      @SimonF1 yeah it's cause you're missing a cue file. Bin was removed so there wouldn't be duplicate entries in emulationstation, keeps the lists cleaner and many need a cue to cue the sound files, so if you selected a bin instead of a cue you may not get all the sound files. There are guides online on how to generate cue sheets to go along with your bin, there are also cue sets you can just download but they fit under the category of roms so you're on your own in finding those.
        ktoft
        I must say that i am in the same problem aa the creator of this thread.
        When i do a clean install it online shows 13 games is availble but i cant enter anything else then the retropie settings.
        I have tried to install All packeges and follow ton of guides and how to but it wont show Any games nor the preinstalled or the roms i am applying from usb.
        Have Any of tried to make clean install from retropie homepage with image 4.0.2 and follow the guide and i just works with nothing else beside the guide?
        Br
        Kevin
        dankcushionsD W 2 Replies Last reply Reply Quote 0
          dankcushions Global Moderator @ktoft
          @ktoft put some games on your system. the emulators are already installed. https://github.com/RetroPie/RetroPie-Setup/wiki/First-Installation#transferring-roms
          if you've put games on your system and they're not showing up, then they must be in the wrong place/format.
            SimonF1
            im up and running with amiga and PlayStation :) graphics on the PlayStation look terrible tho also is there a c64 emulator because i don't see a rom folder for it. but im so happy i have both emulators running now.
            herb_fargusH rbakerR 2 Replies Last reply Reply Quote 0
            • herb_fargusH
              @SimonF1 you need to install it from the setup script. its called vice.
                SimonF1 @herb_fargus
                @herb_fargus
                excellent thank you.
                Never thought i would say it but v4 is beginning to look good.
                could i not just expand all the emulators via "manage optional packages" so they are all up and running when needed or would that slow the pi down? the way i see it is the retropie will only load what it needs to run a game, So if i had a big long list of emulators to pick from would hopefully not slow the system down.
                  mediamogul Global Moderator @SimonF1
                  @SimonF1 said in Installed 4.0.2 and roms not working:
                  I believe the biggest slowdown you'd notice would be when you update your system, as it would then have to update all the emulators you both use and don't use.
                    SimonF1 @mediamogul
                    @mediamogul yes good point.
                    • rbakerR
                      rbaker @SimonF1
                      Use the pi-crt shader and it looks amazing.
                        BuZz administrators @rbaker
                        You can also try the retroarch core option for enhanced resolution. May be too slow in some games though.
                        • L
                          larsmjoh
                          So, I'm also in the situation that none of the emulators I am interested in are available pre-installed.
                          However, I run a network-less zero. Is there a way to download a local cache of the repository for the setup script to install from? Can't seem to find any info on that in the wiki...
                          Thanx,
                          Lars
                            BuZz administrators
                            No - you will need to get a ethernet / wireless dongle for the initial setup (or set it up on a another raspberry pi)
                            • L
                              larsmjoh
                              Not even "hand loading" the sd-card (I'm on Linux, so I have full access to the sd-card partitions from my laptop)?
                                BuZz administrators
                                you could do it from an emulated arm chroot on linux, by mounting the sdcard and chrooting to it (using qemu).
                                https://wiki.debian.org/RaspberryPi/qemu-user-static
                                • L
                                  larsmjoh
                                  Thanx for the tip, I'll try that!
                                  • W
                                    Warshi @ktoft
                                    @ktoft I belive there is an error in the string displayed on the retropie dashboard. Instead of maybe telling how many emulators that is installed it says "13 games available". But no games are available after a clean install with the 4.0 image. This puzzled me for a long while as well and led me to belive that there was something wrong with the navigation. Last time I installed retropie it was 3.. something.. and then there where a few games bundled.
                                    Please fix so that it does not say "13 games available" after a clean install when there is infact no games available :).
                                    W M 2 Replies Last reply Reply Quote 1
                                    • W
                                      Warshi @Warshi
                                      @Warshi See https://cloud.githubusercontent.com/assets/10035308/16217874/c6bbdb3a-3734-11e6-998f-8cc714a320ce.png as an example. Should it state "13 emulators availble" here?
                                        BuZz administrators @Warshi
                                        @Warshi no. Really it means 13 retropie menu entries. I might hide this text on retropie menu in the future. But it's just cosmetic, and the install instructions explains what to do
                                          mos @Warshi
                                          @Warshi This puzzled me for a long while as well! Where are those games!? I'm glad you mentioned this here.
