    SNES Straight to GPIO
    gpiosnesdevgameconsnes
    28 Posts 9 Posters 20.3k Views
    • denisuuD
      denisuu
      I took some parts out of a old computer (header pins & audio connection cable) and soldered them onto the SNES plate. I used the recommended GPIO setup from the gamecon installer.
      But only button A is working on player 2. I'm pretty sure my soldering is good, and I suppose the wire thickness is also ok since the original ribon cable is very small. I read something about the 3 different revisions of controllers.
      The question is what can I do about it?
      • DarksaviorD
        Darksavior @denisuu
        @denisuu You need to bridge both clocks for both pads to work. I was having issues when I was using thin wires. I'm using whatever thickness IDE cables are.
        denisuuD 1 Reply Last reply Reply Quote 0
        • denisuuD
          denisuu @Darksavior
          @Darksavior
          Yea both clock's are bridged I checked all connections in the front ports with the RPI GPIO pins and the wiring is good. But when I push B it shows as if I push all buttons at once in jstest. IDE cables are very thin for sure these wire's are thicker. But maybe the cable is too long it's 67cm.
          I will reinstall retropie, find thicker wires and try again.
          Controller 2 doesn't want to do anything at all I tried (GPIO7=Pin26 or GPIO3=Pin05)
          With gamecon_gpio_rpi map=0,0,1,1,0,0 and 0,0,1,0,0,1...
          DarksaviorD B 2 Replies Last reply Reply Quote 0
          • DarksaviorD
            Darksavior @denisuu
            @denisuu
            I'm using the default config retropie has for the gamecon driver which is 2 snes controllers. My wires are around half as long as of yours.
            Pin1=3.3v
            Pin5=D2
            Pin6=GND
            Pin7=D1
            Pin19=C1/C2
            Pin23=L
            • denisuuD
              denisuu @Darksavior
              @Darksavior
              That works thanks!! It's a completely different layout then the Wiki and driver installer suggest tough. Also it turned out one of my controllers just isn't working :P
              Anyway I made a small fool tutorial here
              • DarksaviorD
                Darksavior
                The gamecon installer pinout is almost correct except for the player pins need to be switched around. No need for a tutorial but ok...
                • denisuuD
                  denisuu @Darksavior
                  @Darksavior I realize that now by looking at the picture again that I was just stupid. I put clock and latch at the wrong place the whole time because I just counted one empty pin from the bottom. Anyway I'm happy It's finally working.
                    beudbeud @denisuu
                    @denisuu Hi i have the same problem i wanna how you do for fix it?
