    Runcommand System Splashscreens!
    run commandruncommandsplashscreenpixelpixel theme
    342 Posts 81 Posters 576.4k Views
    • matchamanM
      matchaman
      The link is down :( anyone kind enough to reupload?
      ShaneTheTrain12S 1 Reply Last reply Reply Quote 1
      • chubstaC
        chubsta
        works for me
        Raspberry Pi 400 - overclocked to 2.3GHz
        Theme - Comic book
        Emulators: All of them...
        Roms: Pretty much all of them...
        Favourite games: Circus Charlie, Gorf, Gauntlet Legends
        Controllers: Mayflash F101
        • ShaneTheTrain12S
          ShaneTheTrain12 @matchaman
          This post is deleted!
            DirtyDH757
            i get a 404 page when i try to download it
            • pixelpiklzP
              pixelpiklz
              love those runcommand splashes im using them on most of my setups i didnt see a jap megacd one or megadrive one yet(maybe i missed them?) so i remixed some if you too would like to display jap versions here they are,
              1_1490011974553_launching-megadrive_jap.png 0_1490011974553_launching-mega-cd_jap.png
              im adding any remixes i do to my blog
              goo.gl/TI6NKQ
              RetroPie v4.1.20 | attractmode 2017• RPi3 Model B • Samsung 5.1V 2.5A PSU • 8GB SanDisk microSD to boot > 1TB External USB HardDrive
              • L
                LorThe3rd @meleu
                @meleu Many thanks, I got it. :)
                • bwbutler415B
                  bwbutler415 @Rookervik
                  @Rookervik the download link is not working for me. dropbox says the file cannot be found.
                    @Rookervik maybe a link to the github repository in the OP would avoid all these guys saying the same thing about the broken dropbox link. ;-)
                    RookervikR 1 Reply Last reply Reply Quote 0
                    • RookervikR
                      Rookervik Global Moderator @meleu
                      @meleu Sorry, I've been extremely busy at work the last month. I might have more free time next week. I've updated the download link to the github repository.
                      • E
                        Emmanuel14
                        Thank you very much for this awesome job man,greetings from Argentina!
                          meleu @Rookervik
                          @Rookervik I'm working on a tool to automate the installation of some arts, I'm doing my first tests with your pixel-friendly launching images from your github repo. I would like to know if you're OK if I release my tool with the option to download those images from your github repo.
                          I emphasize: I'm not modifying your amazing artwork. The tool will get the images directly from your repo. One of the benefits is that the tool donwload only the images for the systems that the user has installed (no need to download every single image and use just a few).
                          • E
                            Elber
                            Hello everyone!! I have every launching screen working but the one for Steam. Where Im suppose to put the .png file for it? I tried /opt/retropie/configs/steam, /opt/retropie/configs/moonlight, /opt/retropie/configs/ports/steam and moonlight. It endup working with the .png file in /opt/retropie/configs/all but that's not optimal. Any ideas? Thank you!
                              Users interested in an easy way to install those awesome pixel-theme-friendly launching images shoud take a look in the tool I'm talking about here: https://retropie.org.uk/forum/topic/9686/rpie-art-easy-way-to-install-art-on-your-retropie
                              To install the @Rookervik 's launching images you just have to launch the script and select
                              https://github.com/udb23/rpie-ovl >> Launching image list and then check the contrib/meleu/pixel-launching/* options. Pretty simple, huh?
                                McDutchman3 @Rookervik
                                @Rookervik THANKS!! Super awesomess!
                                • RookervikR
                                  Guess I need to update these to the new pixel artwork. I'll add that to my list of stuff to do.
                                    **Scannigan**
                                    I've skimmed through this and other associated posts and can't seem to find an answer, I've created my own "launching" images however they don't seem to fit the screen and I have black borders either side of the the image is there a command I can include in runcommand.sh for fbi that stretches to screen, I've tried both .png and .jpg images with the same result?
                                      backstander @**Scannigan**
                                      @__Scannigan__
                                      I haven't heard of any command to accomplish this.
                                      I assume your using 1080p resolution? Just edit that launching image and resize it to 1920x1080.
                                      * 1 Reply Last reply Reply Quote 0
                                        **Scannigan** @backstander
                                        @backstander spot on dude, is that the required size?
                                          @__Scannigan__
                                          Yeah, a 1080p display (16:9 aspect ratio) = 1920x1080
                                          http://www.digitalcitizen.life/what-screen-resolution-or-aspect-ratio-what-do-720p-1080i-1080p-mean
                                            @backstander ah now I feel silly, cheers dude
