    lr-mame2003 rom specific rotation + aspect issues
    mame2003rotationaspect ratio
    69 Posts 13 Posters 38.6k Views
    • esmith13E
      esmith13 @RandoCalrisian
      @RandoCalrisian
      In the ROM folder right next to the ROM it is for.
      Example:
      /home/pi/RetroPie/roms/mame-libretro/pacman.zip
      /home/pi/RetroPie/roms/mame-libretro/pacman.zip.cfg
      Note the config file is named {romname.zip}.cfg
      Settings in this config will override settings in the other various configs but only for the ROM its name matches.
      RandoCalrisianR 1 Reply Last reply Reply Quote 0
      • RandoCalrisianR
        RandoCalrisian @esmith13
        @esmith13 said in lr-mame2003 rom specific rotation + aspect issues:
        @RandoCalrisian
        Example:
        Excellent, thanks for the response. I JUST figured this out too, as a result of setting options in "runcommand", then seeing a file manifest itself.
        To add to this, I'll say the only way I've gotten desired results, is using custom configs.
        Enabling tate messes with the aspect ratio, but doesn't rotate the game.
        Enabling tate and setting allow rotate to false messes with the aspect ratio, and still doesn't rotate the game.
        esmith13E 1 Reply Last reply Reply Quote 0
        • esmith13E
          @RandoCalrisian
          Enabling Tate and setting allow rotate to false does work if done in global configs. Certain configs override certain others . Just the same certain configs can be overridden by others. Tate mode enable should be in global. Allow rotate false should be in mame2003 core options config. That worked for me.
          Of course you must update lr-mame2003 from source first and make sure you are in fact using mame2003 not mame4all or advmame, etc...
          • RandoCalrisianR
            RandoCalrisian
            /opt/retropie/configs/mame-libretro/retroarch.cfg
            Is it safe to assume that refers to lr-mame2003?
            • caver01C
              caver01 @RandoCalrisian
              @RandoCalrisian said in lr-mame2003 rom specific rotation + aspect issues:
              No, it also is used by lr-mame2010.
                dankcushions Global Moderator
                my advice is to put per-rom overrides in /opt/retropie/configs/all/retroarch/config/MAME 2003/
                this is the official retroarch-supported way of using rom overrides. there's a few advantages (settings don't migrate to your main config even if save_on_exit is turned on, etc)
                  KillerQ @dankcushions
                  @dankcushions said in lr-mame2003 rom specific rotation + aspect issues:
                  @esmith13 you might have already solved this through .cfgs, but i've coded a 'TATE Mode' for lr-mame2003.
                  1. update from source (this takes about 30 mins)
                  2. follow the instructions here: https://github.com/RetroPie/RetroPie-Setup/wiki/lr-mame2003#tate-mode
                  it will mean no custom cfgs required - just change the per-emulator settings as i describe.
                  So, I just built a small rig with my Raspberry Pi 3 running Retropie on a dell monitor that rotates clockwise to portrait mode.
                  From what I gather, TATE is an emulator that I can get through Retropie setup that adds the option to change the video output to portrait - allowing me to hit a button and get into settings to change this before the game loads - right?
                  Just looking for the most efficient way to go about this.
                    dankcushions Global Moderator @KillerQ
                    @KillerQ said in lr-mame2003 rom specific rotation + aspect issues:
                    not quite :) TATE mode is just an option in the default /mame-libretro/ emulator.
                      @dankcushions does Retropie even have the capability of rotating its output on the fly, per rom - similar to how the display_rotate=x config command does?
                      Not having to constantly reboot the system in between different styles of games would be great.
                      caver01C dankcushionsD 2 Replies Last reply Reply Quote 0
                      • caver01C
                        caver01 @KillerQ
                        @KillerQ Yeah, you shouldn't have to reboot to rotate a game if you are using RetroArch emulators. The worst case would be that you would have to create config file for each game you want to rotate a specific way.
                          yes it does...
                          but i guess you don't understand this option - with your screen you'd enable it and simply rotate your screen when playing the vertical games. you'd not need to use any other rotating options.
                            @dankcushions when I'm in a game that I want to play in vertical position, I am searching for the Retroarch menu setting that I can change once I start the game, then after it rotates, I'll rotate my monitor. That's what I'm searching for.
                              edmaul69 @caver01
                              @caver01 who makes that monitor? It looks exactly like the 23" hp monitor i used to have. Which was the best looking monitor screen i have seen personally.
                              caver01C 2 Replies Last reply Reply Quote 0
                              • caver01C
                                caver01 @edmaul69
                                @edmaul69 which? The Dell 19"?
                                • caver01C
                                  caver01 @edmaul69
                                  @edmaul69 or do you mean the one in my roadcase cocktail cabinet? My build uses a Sony.
                                    edmaul69 @caver01
                                    @caver01 i apologize. I meant to ask @esmith13 about the one he was showing pics of. But i do like those dells. I used to have one. I had gotten several in an auction and sold them off but kept one for myself. Mame was great on it with the rotation.
                                      the tate mode option is something that you (someone with a rotatable monitor) leaves on for all games. then any vertical game is played alone the length of your monitor, and you rotate the monitor. the rest of the games play normal.
                                      mame knows what games are vertical or not.
                                        Great, thanks. Hats why I was Gathering
                                        I'm using a 16:10 widescreen aspect ratio, 56 cm (22") diagonal VIS (viewable image size) and 1680x1050 maximum resolution Dell E2210 monitor in this self-contained, cabinet-less setup that I just threw together yesterday:
                                        [url=https://postimg.org/image/ga6ioiqfx/][img]https://s30.postimg.org/ga6ioiqfx/IMG_3861.jpg[/img][/url]
                                        [url=https://postimg.org/image/sq7tw095p/][img]https://s30.postimg.org/sq7tw095p/IMG_3862.jpg[/img][/url]
                                        [url=https://postimg.org/image/pkn85sqjh/][img]https://s30.postimg.org/pkn85sqjh/IMG_3873.jpg[/img][/url]
                                        Thanks,
                                        Matt!
                                          KillerQ
                                          I just need to enable TATE apparently. I'll look into it. MAME only, not fba
                                            KillerQ
                                            TATE mode makes it so that per rom config files are not necessary any longer To have games rotate to portrait mode, correct ?
