    Boot Script ordering for USB Mount and SplashScreen
    splash screensplashscreenusb-stickusb rom service
    14 Posts 4 Posters 2.8k Views
    • hooperreH
      hooperre @jonnykesh
      @jonnykesh Simple, yes. Not the most practical as accessing the USB through windows is preferred to having to use Filezilla every time I want to add and remove splash screens.
      4B ~ RPi PSU 5.1V / 3.0A ~ 32GB SanDisk microSD ~ 128GB USB
      • jonnykeshJ
        jonnykesh @hooperre
        @hooperre You could delay launching ES until the USB is mounted. Add a sleep x variable to the launch script. Obviously this will delay the whole boot process.
        hooperreH 1 Reply Last reply Reply Quote 0
        • hooperreH
          hooperre @jonnykesh
          @jonnykesh said in Boot Script ordering for USB Mount and SplashScreen:
          Thanks! Is that boot/config.txt?
          • jonnykeshJ
            jonnykesh @hooperre
            @hooperre No, the autostart.sh script is in /opt/retropie/configs/all/
            They changing the line to sleep 10; emulationstation #auto
            You may need to adjust this value
            hooperreH 2 Replies Last reply Reply Quote 0
            • hooperreH
              hooperre @jonnykesh
              @jonnykesh Thank you for your help!
              • hooperreH
                hooperre @jonnykesh
                This does in fact delay the launch the ES2 launch, but does not change splashscreen and usb mount orders, sadly.
                • jonnykeshJ
                  jonnykesh @hooperre
                  @hooperre Well, It won't change the mount order of the USB. This is determined by the kernel, I believe and whenever the daemon runs.
                  If you are calling the the splash from a USB then, you of course need to wait until the USB is mounted, otherwise it won't be called.
                  Have you tried increasing the sleep value? I'm not sure how far into the boot process the USB mount happens but it is one of the last processes to happen as everything else needs to be in place before it occurs.
                  • hooperreH
                    hooperre @jonnykesh
                    I follow. The problem, I think, is that the splashscreen launches independent of when ES2 launches. So I'll see my boot script, I'll get the error saying the splashscreen isn't found, and then it waits an inordinate amount of time and then starts up ES2. In summation, I don't think ES2 launching has any bearing on the splashscreen process.
                    Thanks for sticking with me thus far. I've put it off because I know a simpler solution exists... but this is why I love am addicted to my Pi haha.
                    • jonnykeshJ
                      jonnykesh @hooperre
                      @hooperre Have you considered turning the custom splash screen into a static video file? say 5 or ten seconds, whatever you feel is best.
                      You say videos on the USB work fine so just turn the static image into a video file.
                      • hooperreH
                        hooperre @jonnykesh
                        Truth. Good shout. I'll probably just put them on the SD card unless I can dig into the splashscreen stuff and find out how to have it start later? Not sure. I know using Filezilla if I attempt to change permissions it doesn't work and I can't add them, but I know I can do it with Putty (chmod) it works. That's the only reason I preferred to stay on the USB.
