    Pi3 Won't Find NES30 Pro Bluetooth/Firmware 1.71/RetroPie 4.1
    nes30probluetoothrpi 34.1
    5 Posts 2 Posters 1.9k Views
    • qix77Q
      qix77
      I've searched on here and apparently this hasn't been addressed much. I have two Raspberry Pi 3s and after following instructions on YouTube, web forums, wiki, etc.. I just can't get RetroPie to recognize my Bluetooth Nes30 Pro.
      I upgraded the Firmware to 1.71
      I did do the following:
      sudo apt-get update
      sudo apt-get upgrade
      I did go to 'RetroPie-Setup' and went to the bluetooth settings. I also turned off the hack for the 8Bitdo NES30.
      So when I go to search for my device, it searches forever while my controller keeps blinking until it goes to sleep mode. I did press some buttons and the d-pad while as instructed by others but still won't find it.
      I did try the controller via a bluetooth dongle on my Windows 10 desktop and it finds it instantly and works, but I've tried two Pi 3s and neither will find it controller.
      Any suggestions?
      BTW: When 'searching' keeps going forever, is there any ways to exit out of that without having to reboot the system by using 'Ctrl+Alt+Delete' ?
      Thanks in advanced.
        BuZz administrators @qix77
        @qix77 Did you install the PS3 controller driver ?
        qix77Q 1 Reply Last reply Reply Quote 1
        • qix77Q
          qix77 @BuZz
          @BuZz Yes. I actually did that to test a PS3 controller a week before I got the NES30. Has there been reports of a conflict with the PS3 driver?
            @qix77 When you install/configure the ps3 controller driver it opens a dialog which says
            NOTE: You cannot currently use PS3 controllers with other bluetooth devices. The PS3 controller driver disables the standard bluetooth stack. If you want to use a wireless keyboard along with your PS3 controllers you can use 2.4ghz wireless devices that come with their own dongle.
            You will need to remove it to pair the nes30.
            • qix77Q
              qix77 @BuZz
              @BuZz OMG. Thanks, BuZz. It worked.. I guess this was some information that I either overlooked or just didn't come across. You just saved me from a great deal of stress.
              Thank you so much, BuZz... You are awesome. :)
