    nescasediybuildtheme
    1.3k Posts 210 Posters 2.8m Views
    • AlexMurphyA
      AlexMurphy Banned @ruckage
      YF>GK@@,ju[ld“
      ruckage Hajhahahahaha....................................
      • AlexMurphyA
        @ruckage Can you turn that off? Maybe you could ask it for a date... Ha!
        • CybermenC
          Cybermen
          Hello, I noticed that the update to 4.2.4 the metadata is not displayed completely. It lacks: game's release date, developer, times played, etc...
          However, since running the "update all packages" script in RetroPie Setup, this meta-data has disappeared.
          Can anyone else confirm this issue? Anyone have any solutions to fix this?
          • ruckageR
            ruckage @Cybermen
            @Cybermen said in Cardboard Mini NES + Nes mini and Famicom mini themes:
            Hi, this was fixed a few days ago by @jdrassa , it was bug in ES due to the new z-index support, (everything is still there it just has the wrong zindex so is hidden underneath the background).
            If you install the latest version of ES from source (you can do it from within retropie) then the problem should be fixed.
            • CybermenC
              Cybermen
              @ruckage Perfect, works again. thanks
              • HexH
                Hex
                @ruckage Request : PC/DOS art
                ruckageR 1 Reply Last reply Reply Quote 1
                • ruckageR
                  ruckage @Hex
                  @Hex
                  Already on the to do list (see first post).
                    bjose2345
                    @ruckage : Can I request MSX2?, didnt see it in the list
                    sergioadS 1 Reply Last reply Reply Quote 0
                      kbronctjr
                      Hi, as latests versions of ES have the possibility to press X button to select a random game, could you add that button to the bottom area of the theme where other buttons appears
                      HexH ruckageR 2 Replies Last reply Reply Quote 1
                      • sergioadS
                        sergioad @bjose2345
                        @bjose2345 any kind of MSX could work
                        • HexH
                          Hex @kbronctjr
                          @kbronctjr said in Cardboard Mini NES + Nes mini and Famicom mini themes:
                          This is hardcoded and will need to be changed in ES
                            Syhles @Hex
                            @Hex
                            This theme has custom help Icons built into the background.
                            You are absolutely correct though that the actual help icons are hardcoded in ES.
                            • ruckageR
                              ruckage @kbronctjr
                              MSX is already on the to do list but I will add MSX2 as well.
                              I will add that the controls image.
                              • N
                                nj180grados
                                Hi @ruckage I leave this link: https://forum.recalbox.com/topic/7638/retropie-theme-port-posibility-cardboard-mini-nes-nes-mini-and-famicom-mini-themes/25
                                A fellow from the recalbox @ João-Nuno-Cravinho forum has partially ported the theme to recalbox, but it is an older version to the new design in carrousel
                                Check it out and tell us what you think, I have also left a message in the recalbox forum.
                                As you can see, they have not taken long to port, the theme has a lot of acceptance.
                                I would like you to contact @ João-Nuno-Cravinho to polish details, he has offered to finish the job if you give him your permission.
                                Anything you need will contact me.
                                Thanks @ruckage
                                ruckageR 1 Reply Last reply Reply Quote -1
                                • TMNTturtlguyT
                                  TMNTturtlguy
                                  Interesting post on both forums but I disagree with this request and the thought process behind it. Keep up the good work on your theme @ruckage
                                  N 1 Reply Last reply Reply Quote 1
                                  • N
                                    nj180grados @TMNTturtlguy
                                    @TMNTturtlguy why? Explain to me that it is wrong, the proposal was made at the time and the author expressed the interest to port the theme, what has done the user of the forum of recalbox is personal title has not yet published anything
                                    • TMNTturtlguyT
                                      TMNTturtlguy @nj180grados
                                      @nj180grados out of respect to @ruckage i request that we don't pollute his thread with this discussion and let him keep the posts about his theme. No one has done anything wrong here, I simply disagree that users are requesting that @ruckage or other theme makers or coders dedicate more of their personal time on things like this. If at @ruckage wants someone to help him port his theme that is his choice and he should do that to his liking. @nj180grados you have been very kind in your posts, however I personally don't like that you are trying to "broker" a deal to have someone port @ruckages work and then ask @ruckage to spend time in helping this happen. Again, let's keep this thread on topic of the great theme. I will not reply again on this topic in this thread, feel free to start a new post for further conversations. Thanks
                                      • ruckageR
                                        ruckage @nj180grados
                                        @nj180grados said in Cardboard Mini NES + Nes mini and Famicom mini themes:
                                        Thanks @ruckage
                                        While I appreciate the enthusiasm for my theme I've made it quite clear that I would port the theme myself once I've completed all or most of the systems, I feel this is more than fair. My license terms with the theme are also very clear:
                                        License
                                        This theme is being actively developed, a great deal of work has been put into the theme and art so please do not use the graphics I have created in other projects (with the exception of any graphics that are an exact copy of of those from the real 'NES classic'/'Famicom mini' menu).
                                        You are free to modify the theme for your personal use only - please do not share modified versions of this theme.
                                        Commercial distribution is prohibited
                                        You just need to be patient, I have literally put months of work into this drawing everything myself and do not want it to be fragmented, I have a clear idea of how I want each system to look and so wish to work on it alone. I'm sorry but I do not give permission for @ João-Nuno-Cravinho to release this. I hope you understand my reasons and will respect my wishes.
                                        N 1 Reply Last reply Reply Quote 3
                                        • N
                                          nj180grados @ruckage
                                          @ruckage there is no problem we will wait patiently for this all finished. The reason for the post was to provide you with help since I have considered interesting the fact that the user @ João-Nuno-Cravinho has made his own version of the theme.
                                          We respect your work and we will wait for you to finish it all.
                                          Thank you.
                                          • N
                                            @TMNTturtlguy I understand perfectly, in any case there is no bad intention and respect all the work of the author. The first intention was to help the author, but as he himself has stated, we will respect his work and wait patiently for it to be finished. In short, nothing more to add. See you around. Thanks.
