    nescasediybuildtheme
    1.3k Posts 210 Posters 3.2m Views
    • ruckageR
      ruckage
      Sorry for the lack of updates, I've been having a bit of a break to work on something else.
      There have been some changes made to EmulationStation as of today that fixes and improves several elements of the gamelist, however I'm expecting it to break my theme so if you update ES via source expect some problems. I will be working to fix the theme for the new version of ES so will have an update soon. Big thanks to @jdrassa for making the improvements, they really are great.
      • SonPluckS
        SonPluck @mattrixk
        @mattrixk said in Cardboard Mini NES + Nes mini and Famicom mini themes:
        @ruckage UXS is the Universal XML Scraper. It scrapes the metadata from screenscraper.fr. One of the best things about it is you can create your own scrape profiles so you can scrape whatever images you want (box art, fan art, game logos, screenshots, etc) and mix them into a single image.
        How do you choose your own images for the scraped games?
        • mattrixkM
          mattrixk @SonPluck
          @SonPluck You can create Mix Profiles that let you place the different types of image however you want.
          They have tutorials on the github wiki page that teach you how to do it, or you can check out the ones I made for the ES Toolkit for inspiration.
          (You don't choose specific images to use, but you do choose the type of image, and where to place it eg: put the logo in the bottom-right, the 3d boxart in the bottom-left and screenshot in the middle.)
            bantxi
            I just registered to thank the author for his incredible work. Thank you very much!
            PS. Are there plans to add MS-DOS (DOSBox) and Mega Drive 32X?
            ? ruckageR 2 Replies Last reply Reply Quote 1
              A Former User @bantxi
              @bantxi Both are listed in the to-do section of the first post.
              • ruckageR
                ruckage @bantxi
                @bantxi said in Cardboard Mini NES + Nes mini and Famicom mini themes:
                Thanks for taking the time to leave a message. As @LiveFastCyYoung said both of those are on the to do list which you can find in the first post. I'm having a little break from this at the moment as I'm working on something else but will be going back to it soon to get the remaining systems added.
                SonPluckS 1 Reply Last reply Reply Quote 1
                • SonPluckS
                  SonPluck @ruckage
                  @ruckage Downloaded Mini Nes theme thru Retropie Setup, and I'm not getting the carousel update. Any help?
                  S ? 2 Replies Last reply Reply Quote 0
                    Syhles @SonPluck
                    @SonPluck
                    When was the last time you did an update to ES?
                    Because it sounds like you need to update.
                    SonPluckS 1 Reply Last reply Reply Quote 0
                      A Former User @SonPluck
                      @SonPluck As @Syhles said, you'll need to update ES. I'd also suggest uninstalling the theme and reinstalling it after updating ES. I had the same issue several weeks ago.
                      • SonPluckS
                        SonPluck @Syhles
                        @Syhles How do you I update emulation station?
                        EDIT: I'm using retropie 4.0.2, isn't that newest version?
                        ? ruckageR 2 Replies Last reply Reply Quote 0
                          @SonPluck Press start and quit emulationstation. At the prompt, type...
                          sudo ./RetroPie-Setup/retropie_setup.sh
                          Go to "Update RetroPie-Setup script". Let that run.
                          Go to "Manage packages" -> "Manage core packages" -> "emulationstation" -> "update from binary"
                          This will update your emulationstation.
                          Go back to the main menu and perform reboot.
                          • ruckageR
                            ruckage @SonPluck
                            @SonPluck
                            EmulataionStation can be updated seperately to Retropie as a whole and there have been lots of updates lately. I would advise against updating though if you intend to use this theme as the latest update will probably cause problems with this theme. I will be updating the theme soon though and then you can update ES.
                              Syhles @ruckage
                              @ruckage
                              Slightly off tangent, but don't forget to close the Issues you open on GitHub if they have been resolved.
                              Weren't they a part of the update @jdrassa recently did?
                              If they weren't just ignore me.
                              ruckageR 1 Reply Last reply Reply Quote 1
                              • ruckageR
                                ruckage @Syhles
                                @Syhles
                                Yep, I had forgotten - I've closed them now.
                                  Syhles @ruckage
                                  @ruckage
                                  I figured that you had possibly forgotten about them.
                                  I spend way too much time on GitHub.
                                  • SonPluckS
                                    SonPluck
                                    MAME year is missing, can I add myself?
                                    • ruckageR
                                      ruckage @SonPluck
                                      @SonPluck
                                      Is it just the year and is it only affecting mame? If so then it must be that the scraped data you have for mame is missing that information. Try scraping again using a different source.
                                      Here is a link to UXS scraper if that helps: UXS
                                      DigitalMonkeyD 1 Reply Last reply Reply Quote 0
                                      • DigitalMonkeyD
                                        DigitalMonkey Banned @ruckage
                                        @ruckage I think he means the year on the icon ("????").
                                        I think it was '97 MAME released?
                                        I presumed it was left at "????" because MAME isnt a console.
                                        • ruckageR
                                          ruckage @DigitalMonkey
                                          @DigitalMonkey
                                          You could be right. If that's what he means then yes that is deliberate as there is no set release date for arcades as it covers so many systems.
                                          • SonPluckS
                                            SonPluck
                                            Downloaded thru the retropie script, now I tried to change layout but nothing worked,
                                            I tried to overwrite the original - didn't work
                                            I tried to delete the original and change it with a backup - didn't work
                                            I tried to overwrite the whole file without deleting anything - didn't work
                                            Any help? Here is a screeny
