    nescasediybuildtheme
    1.3k Posts 210 Posters 3.6m Views
      A Former User @SonPluck
      @SonPluck /etc/emulationstation/themes/nes-mini/ is a root directory so make sure you are using sudo in your command.
      The other thing you could do is edit the file on your computer, move it to a non-root directory and us sudo mv to put it in the /etc/emulationstation/themes/nes-mini directory.
      SonPluckS 1 Reply Last reply Reply Quote 1
      • sergioadS
        sergioad
        Why do you not add system changing and selection sounds @ruckage ? I think that could work 😀
        • ruckageR
          ruckage @sergioad
          @sergioad said in Cardboard Mini NES + Nes mini and Famicom mini themes:
          I would have but EmulationStation doesn't currently support playing sound effects for those events. It currently only supports sounds for the scrolling gamelist and game launching. The ability to be able to play other sounds has been requested I believe and I have all the sound effects ready if that happens.
          sergioadS 1 Reply Last reply Reply Quote 2
          • KneeTieK
            KneeTie
            Hello, is there a way to make the theme only show the game names and no other info? Maybe something that I could change "a la basic" option from themes, thanks & awesome job with the theme!
            PS: I specifically mean when i choose for example NDS, the rom list only showing that and no other info.0_1497105868670_unnamed.jpg
            • ruckageR
              ruckage @KneeTie
              @KneeTie said in Cardboard Mini NES + Nes mini and Famicom mini themes:
              Not completely sure what you mean.
              If you mean you want to show the gamelist alone without any of the metadata (the info displayed either side of the list such as genre, release date, developer, rating etc.) then no, you can't easily remove that.
              If you mean that the names in your list show for example:
              'Super Mario Bros. 3 (USA) (Rev A)'
              and you just want to see:
              'Super Mario Bros. 3'
              Then that's nothing to do with the theme itself, it's down to the scraped information in your gamelist.xml. You could try scraping from a different source or edit the gamelist.xml yourself using search and replace in something like notepad++ .
              • KneeTieK
                KneeTie
                What I meant was scenario 1, removing metadata and only having the game list visible, thanks.
                • ruckageR
                  ruckage @KneeTie
                  @KneeTie
                  Then no, it's not possible. The theme is designed specifically as a detailed theme and if you removed everything but the gamelist you would just have a big empty space either side (not sure why you'd want it to look like that).
                    A Former User
                    Speaking of which, can you make a no-metadata version of this theme?
                    • SonPluckS
                      SonPluck @A Former User
                      @LiveFastCyYoung sorry but what should I exactly put in the command line? i'm confused.
                        @SonPluck If you just want to edit the layout.xml file, do this...
                        Quit Emulation Station. This should take you to the prompt.
                        Type...
                        sudo nano /etc/emulationstation/themes/nes-mini/layout.xml
                        Make whatever changes you are trying to make to the file.
                        When you are finished push Ctrl+X, then push Y to confirm your save and then press enter.
                        Then type exit and you'll boot back to Emulation Station.
                        • ruckageR
                          ruckage @A Former User
                          @itsnitro said in Cardboard Mini NES + Nes mini and Famicom mini themes:
                          I don't really have any desire to make a metadata free version, I already have plenty enough to work on as it is. On top of that I don't really see the need, the whole theme was designed with the metadata boxes in mind and it would look pretty empty without them.
                          I would need some very convincing reasons why a metadata free version is a good idea to even consider it.
                          • sergioadS
                            sergioad @ruckage
                            @ruckage I see
                              A Former User
                              I personally love the metadata. The only reason I could see a metadata-less version is because of how incorrect the metadata is most of the time, which is obviously not the themes fault whatsoever. Ratings are pointless(who is rating, most of them are missing ratings) and the number of players is almost never correct.
                              TMNTturtlguyT ruckageR 2 Replies Last reply Reply Quote 1
                              • TMNTturtlguyT
                                TMNTturtlguy @A Former User
                                @LiveFastCyYoung true story, but that info is easily corrected and you can do it right from the rom selection menu. Select on the rom selection screen and choose to edit meta data. Simple easy and fast!
                                ? 1 Reply Last reply Reply Quote 1
                                • ruckageR
                                  @LiveFastCyYoung said in Cardboard Mini NES + Nes mini and Famicom mini themes:
                                  It probably depends on the system/scraping source but I found the metadata to be accurate more than not. I personally quite like the ratings, I don't necessarily agree with the rating that is scraped but it's a great way to rate the games yourself. You could actually edit the gamelist.xml to begin with so all ratings are set to zero and then just rate the games as you play them.
                                    A Former User @TMNTturtlguy
                                    @TMNTturtlguy For sure. But even just talking about the NES that's what, 700 US games? Not taking into account all of the systems this theme supports.
                                    This belongs in another thread but we often have people asking how they can help the project if they don't know how to code. Maybe we should be pointing them to cleaning some of the bad metadata on some of these sites? Just a thought.
                                    ruckageR 1 Reply Last reply Reply Quote 1
                                    • ruckageR
                                      That would be a great idea, there was thread I saw a few days asking how people could help.
                                      • O
                                        Oen
                                        @ruckage do you have any plans to add DOSBox? Anyway I can help with that, if so?
                                        Thanks for all the hard work on theme so far!
                                        ? S 2 Replies Last reply Reply Quote 0
                                          A Former User @Oen
                                          @Oen DosBox is in the todo list and he's stated before he is handling all of the work for this theme on his own. He'll get to it.
                                            Syhles @Oen
                                            @Oen
                                            Check the bottom of the first post, system to-do list is there.
                                            He wants to do the whole theme himself, all we can really do is point out errors if any, and request systems that have been overlooked, but seems like all the main bases are covered.
