    Need help for some neogeo and mame games
    neogeomame
    7 Posts 4 Posters 2.7k Views
      broxopios
      Hi.
      While i run the most of neogeo and mame games, i face problems with these.
      NeoGeo: Nam 1975, Soccer Brawl, Street Hoop
      Mame: Arch Rivals, Puzzle Bobble (english version)
      About NeoGeo, installed lr_fba_2012 and tried to rebuild roms (from virus sources) for FinalBurn Alpha emulator with no succeed. I use the method with clmamepro.
      The same method i use with mame 2 games (0.78 - lr-mame2003).
      So i need help.
        dankcushions Global Moderator @broxopios
        @broxopios a lot going on here.
        for neogeo, use lr-fbalpha and an fba 0.2.97.39 romset. you shouldn't need to rebuild anything.
        ensure the neogeo.zip from the same romset is also present in the rom folder.
        • flopF
          flop
          I played Street Hoop with lr-fbalpha (0.2.97.39 romset) and it runs perfect; same with puzzle bobble, but I think puzzle bobble 2 or 3 (can´t remember) doesn´t work; maybe with the next rpi update with the new advmame it works :p
            broxopios @dankcushions
            @dankcushions said in Need help for some neogeo and mame games:
            And that was the solution.
            Thank you. I must missed that information and i tried the hard way.
            Now the only problem is Arch Rivals in Arcade emulator.
            I use lr-mame2003 and for this i have 0.78 romsets ready. All my favorite games play but Arch Rivals. When i run it i get the following image and i can't do nothing.
              dudleydes @broxopios
              @broxopios According to the lr-mame2003 compatibility list, Arch Rivals doesn't work. I am using AdvanceMAME 0.94 where it runs pretty well.
                broxopios @dudleydes
                @dudleydes thank you. I installed advanceMAME 0.94 and it works perfect!
                Thanks again.
                  dankcushions Global Moderator @flop
                  @flop said in Need help for some neogeo and mame games:
                  puzzle bobble 3 is not part of 0.2.97.39 romset. pb2 apparently works, and is part of it.
