    Wii Classic / Pro Controller - Analog not working
    wii controllerretropie 4.2analog stickraspberry pi 3
    23 Posts 5 Posters 10.5k Views
    • W
      WildDarkness @edmaul69
      @edmaul69 I tried adding the home button in this, which didn't work
      I'll try adding the select button
      Thanks again
        Charononus @monkeypie
        @monkeypie said in Wii Classic / Pro Controller - Analog not working:
        @Charononus
        Was that just using BT? I don't want to spend money on adapters like the Mayflash dolphin bar. I'm thinking about buying an 8bitdo controller if I can get this to work.
        With MoltenGamePad? Yeah, I just got MoltenGamePad from git and followed the directions and set up the wiimote with the pi's internal bluetooth. I forget what pairing option it needed but pretty sure it was in the directions. This was just shortly after 4.2 was released. It worked as easy as can be.
        The only problem I had with it is that I had to uninstall moltengamepad when I eventually hooked up a Wii U Pro controller as it didn't play nice with it.
        • O
          ogbuehi
          I know for my Wii U controller, I couldn't get RetroArch hotkey shortcuts to work as I wanted until I went into the config file and manually added the start button as the "exit" button. But it took me awhile at first to understand how the hotkeys worked (didn't know what hotkey option meant when I set up the controller in emulation station because it didn't do that in my Reys image).
