    Another case of hotkeys not working..
    hotkey exithotkeysinput issue
    18 Posts 3 Posters 8.2k Views
    • W
      WetpantsMcGee
      Hi everyone!
      First post on the forum, though long-time reader. Thanks to all the contributors for helping me through solving other people's issues!
      I'm sure everyone here is sick and tired of posts about hotkeys, but I've been tearing my hair out for the past 48 hours trying to fix my problem.
      A few months ago I put on a fresh image of Retropie and I noticed that my hotkeys had stopped working. I tinkered with it for a few hours and could not make any progress, so I packed it away as I was moving at the time. Fast forward to today, and I'm right back here with the same problem. I tried updating to the latest version through the GUI and still, the same. The only system that will work is FBA. SNES, NES, Megadrive all will not let me exit or pull up the menu. I'm running a Pi3 Model B and using an iBuffalo SNES controller. Thanks in advance if anyone has any recommendations!
      BuZzB mediamogulM 2 Replies Last reply Reply Quote 0
        BuZz administrators @WetpantsMcGee
        @WetpantsMcGee Please do not post a support request without first reading and following the advice in https://retropie.org.uk/forum/topic/3/read-this-first
          mediamogul Global Moderator @WetpantsMcGee
          @WetpantsMcGee
          Along with the required information above, can you post the contents of /opt/retropie/configs/fba/retroarch.cfg, as well as one of the offending systems like /opt/retropie/configs/snes/retroarch.cfg?
          • W
            WetpantsMcGee @mediamogul
            @mediamogul Can I paste it directly or should I use something like pastebin?
              @WetpantsMcGee
              If either is too long, use pastebin, if short, use code blocks per https://retropie.org.uk/forum/topic/3/read-this-first. The other required information can be posted straight.
              • W
                WetpantsMcGee
                Pi Model or other hardware: Pi3 Model B
                Power Supply used: Yes
                RetroPie Version Used (eg 3.6, 3.8.1, 4.1 - do not write latest): 4.2.4
                USB Devices connected: 1
                Controller used: iBuffalo USB SNES
                Error messages received: None
                Guide used: Every search result on Google for retropie hotkeys not working
                Emulator: NES, SNES, Megadrive (All but FBA actually)
                Attachment of config files:
                How to replicate the problem: Run any emulator except FBA
                • W
                  WetpantsMcGee
                  retroarch.cfg for FBA
                  Settings made here will only override settings in the global retroarch.cfg if placed above the #include line
                  input_remapping_directory = "/opt/retropie/configs/fba/"
                  • W
                    WetpantsMcGee
                    retroarch.cfg for SNES
                    input_remapping_directory = "/opt/retropie/configs/snes/"
                    input_enable_hotkey = "nul"
                    input_enable_hotkey_btn = 8
                    input_exit_emulator_btn = 9
                    input_menu_toggle_btn = 1
                    input_load_state_btn = 2
                    input_save_state_btn = 5
                    input_reset_btn = 3
                    input_state_slot_increase_axis = +0
                    input_state_slot_decrease_axis = -0
                    input_volume_up_axis = -1
                    input_volume_down_axis = +1
                      @WetpantsMcGee
                      It looks like you might currently have, or at one time had 'save on exit' set in RetroArch.
                      Try pasting:
                      into /opt/retropie/configs/snes/retroarch.cfg
                      Then paste:
                      input_remapping_directory = "/opt/retropie/configs/nes/"
                      into /opt/retropie/configs/nes/retroarch.cfg
                      Then paste:
                      input_remapping_directory = "/opt/retropie/configs/megadrive/"
                      into /opt/retropie/configs/megadrive/retroarch.cfg
                      • W
                        WetpantsMcGee
                        Ok, I'll give this a try and report back. Thanks!
                        • W
                          WetpantsMcGee
                          Ok, copied and pasted into the appropriate retroarch.cfg files, but still no luck with the hotkeys :(
                            @WetpantsMcGee
                            Now post the contents of /opt/retropie/configs/all/retroarch.cfg as well as your particular controller config located at /opt/retropie/configs/all/retroarch/autoconfig/ and let's see what shows up there.
                              @WetpantsMcGee
                              Also, open up the retroarch.cfg file for whatever system you just tested to see if what you pasted is still there.
                              • W
                                WetpantsMcGee
                                https://pastebin.com/embed_js/b2LJM1P5
                                • W
                                  WetpantsMcGee
                                  I checked the udev folder under /op/retropie/configs/all/retroarch/autoconfig/ and it is empty :( So I am lacking a .cfg for my particular controller.
                                    @WetpantsMcGee
                                    Try re-configuring your controller through Emulation Station and check to see if it is created at that location.
                                    • W
                                      @mediamogul Looks like that did it! I had tried reconfiguring it before but to no avail. Just tested it on all systems and I have menu access and can exit to ES!
                                      Thanks so much! I feel so much better now.
                                        @WetpantsMcGee
                                        Good to hear. Welcome to the forums btw.
