    How to restart ES from a script?
    scriptessystems.cfgrestart
    111 Posts 5 Posters 42.6k Views
      cyperghost @BuZz
      @BuZz said in How to restart ES from a script?:
      pkill -f "/emulationstation$"
      That let's restart just 2 PIDs... Does not work!
      touch /tmp/es-restart; killall -e "/opt/retropie/supplementary/emulationstation/emulationstation"
      runs fine all 3 PIDs are up to date
      Man ... I even wrote use the tty1 outputs. So indeed the relauch script was killed
      BuZzB TMNTturtlguyT 2 Replies Last reply Reply Quote 0
        BuZz administrators @cyperghost
        @cyperghost said in How to restart ES from a script?:
        Worked here when I just tested.
          cyperghost @BuZz
          @BuZz Wait I post output in a few minutes...
          pi@retropie:~ $ ls /tmp
          es-restart  omxplayerdbus.root  omxplayerdbus.root.pid
          pi@retropie:~ $ ps -a
            PID TTY          TIME CMD
            862 tty1     00:00:00 bash
            867 tty1     00:00:00 bash
            868 tty1     00:00:00 emulationstatio
            874 tty1     00:00:00 emulationstatio
            877 tty1     00:00:13 emulationstatio
            990 pts/0    00:00:00 ps
          The command pkill
          pi@retropie:~ $ pkill -f -e "/emulationstation$"
          emulationstatio killed (pid 868)
          emulationstatio killed (pid 877)
          check with ps -a
            PID TTY          TIME CMD
           1001 tty1     00:00:08 emulationstatio
           1071 pts/0    00:00:00 ps
          worked now... sorry... but 2 PIDs alive
          If PID 874 in my current setup will be killed than ES is wrecked.
          Thank you
            @cyperghost use ps -fa as you can't tell what they are from that. probably parent bash scripts (which is correct - they shouldn't be killed).
            • TMNTturtlguyT
              TMNTturtlguy @cyperghost
              @BuZz @cyperghost
              When i use this in my script, it runs the first time. The second time i try to run it, the script crashes with error "cant remove /tmp/es-restart
              cyperghostC BuZzB 2 Replies Last reply Reply Quote 0
                cyperghost
                @BuZz
                Thank you I will remember that command!
                Very usefull :)
                  cyperghost @TMNTturtlguy
                  @TMNTturtlguy I will check....
                  I tested all scripts 2 two 3 times... all runing fine
                    BuZz administrators @TMNTturtlguy
                    @TMNTturtlguy said in How to restart ES from a script?:
                    @BuZz @cyperghost
                    because custom retropie scripts are actually run as root - ill change that I think, but just make sure you create it owned by pi for now.
                    sudo -u pi touch /tmp/es-restart
                    cyperghostC 2 Replies Last reply Reply Quote 0
                      cyperghost @BuZz
                      @BuZz Solid work!
                      Thank you
                        cyperghost @BuZz
                        @BuZz What is your prefered method?
                        pkill or killall? I think pkill offers more room for changes.
                          BuZz administrators
                          I have updated retropie-setup so user scripts will now be launched as a normal user without elevated permissions (can use sudo in a script if needed).
                            @cyperghost pkill so it can kill emulationstation running from any path.
                              cyperghost
                              @BuZz
                              Ufff... that was hard stuff!
                              • TMNTturtlguyT
                                @cyperghost @BuZz i updated retropie-setup and now i can't run my script, and i also cannot do anything within the retropie setup script either. I enter restropie setup, it freezes up for a bit and then exits back to the retropie menu.
                                  cyperghost
                                  Wait a moment...
                                    @TMNTturtlguy did you reboot ? you may want to sudo rm /tmp/es-restart also.
                                      BuZz administrators
                                      There is a problem after launching the first time. Will check.
                                        cyperghost @BuZz
                                        @BuZz There seems to be a problem with the one lost PID!
                                        I did not update but I'm facing the same problem!
                                          cyperghost
                                          No the first killall script runs in best condition!
                                          All 3 PIDs are running there!
                                          and I can execute @TMNTturtlguy script like usual behavior.
                                            @cyperghost the pkill isn't working as it also kills a needed parent process as the pattern matches a bash line which I missed.
                                            pkill -f "/opt/retropie/supplementary/.*/emulationstation$"
                                            should sort it
