    How to restart ES from a script?
    scriptessystems.cfgrestart
    111 Posts 5 Posters 41.7k Views
    • TMNTturtlguyT
      TMNTturtlguy @cyperghost
      @cyperghost @BuZz Ok, so I did the ps -a and killed the largest emulationstatio and i can at least navigate the menus again....so yes the pkill is causing the issue,
      Next issue is after the setup script update my script gives an error saying that '/opt/retropie/configs/all/emulationstation/es_systems.cfg' is write protected and the script errors out.
        BuZz administrators @TMNTturtlguy
        @TMNTturtlguy if your script wants to edit that file it will need to use sudo as user scripts are no longer run as root.
        • TMNTturtlguyT
          TMNTturtlguy @BuZz
          @BuZz thanks that seems to work. New issue. When running
          touch /tmp/es-restart
          pkill -f "/opt/retropie/supplementary/.*/emulationstation$"
          the script works great, but when i press start and go to QUIT, the screen flashes back to my script and ES restarts. I can't navigate to exit or shutdown. I immediately see the script blue screen and restart ES. So this is not killing the /tmp/es-restart
            cyperghost
            you can please check permission of your Restart Script in retropiemenu.
            It must be set to pi.
            • TMNTturtlguyT
              @cyperghost another beginner questions, how do i check that?
                cyperghost @TMNTturtlguy
                @TMNTturtlguy
                Because the sh und rp files are called via bash. I'm not 100% sure if this can cause errors. if you never entered SSH as root it's very unlikely you have the wrong permission set.
                Sorry late here
                ls -al in retropiemenue
                • TMNTturtlguyT
                  @cyperghost everything is set to pi
                  • TMNTturtlguyT
                    TMNTturtlguy @TMNTturtlguy
                    @TMNTturtlguy @cyperghost @BuZz so i can confirm that
                    Is still not killing all 3 PID. I had to go in and kill, when i did this i got the same blue screen with error text as i posted above using @meleu script. I just tried running this with sudo in front, same effect. Once it is run, entering into the start menu and the retropie menu causes me to immediately flash to the script screen and then restart ES.
                      @TMNTturtlguy it's not supposed to kill all the processes - 2 are scripts to launch es which should be left running. Also see above regarding using ps so you can see the full names.
                      • TMNTturtlguyT
                        TMNTturtlguy @BuZz
                        @BuZz
                        • TMNTturtlguyT
                          TMNTturtlguy
                          @BuZz @cyperghost when I killed 1162 from the above list, ES restated and now everything is functioning correctly. I then ran my script again, it worked, pressed start and went to menu, quit, and same thing occurs, a flash of my script menu and an restart of ES. This time i kill the highest number of ES, Es restarts and i get a message that /tmp/es-restart cannot be removed. Is this a permissions issue within the script? I am running the latest touch restart command from above with sudo now and it has no affect.
                          Edit: i added tried this:
                          sudo rm /tmp/es-restart
                          This gets rid of the auto restart, but when I go to start, quit I can now select restart, when i do this it reruns the my script and defaults to the first option from my menu. I don't get the can't remove /tmp/es-restart message anymore. When i kill the largest number emulationstatio it exits to the same blue screen with weird text as posted above. The sudo rm /tmp/es-restart everything is back to normal again.
                            wazzup guys!
                            in front of my RetroPie it is a way easier! Here is my one liner to restart ES with no issues (at least it works fine here):
                            touch /tmp/es-restart && pkill -f "/opt/retropie/supplementary/.*/emulationstation([^.]|$)"
                            Yes, the only difference is those / chars before and after .* in the regex. It's working fine thanks to this commit on RetroPie-Setup.
                            That one liner is able to restart ES even if the user is running a testing ES branch ( @TMNTturtlguy knows what I'm saying) and/or the user launched ES with some --arguments.
                            @TMNTturtlguy I hope it helps you.
                            Cheers!
                            TMNTturtlguyT BuZzB 3 Replies Last reply Reply Quote 2
                            • TMNTturtlguyT
                              TMNTturtlguy @meleu
                              @meleu thank you! Unfortunately we just left for a family weekend and I won't be home until Sunday evening. I will test it out right away. Thanks again! P.s. I brought my computer with to make your mame row logo! Will get that created and send you a download link!
                                cyperghost
                                I made a thread of all bash ideas oft the restart.
                                https://retropie.org.uk/forum/topic/11050/restart-es-via-bash-script/
                                  BuZz administrators @meleu
                                  @meleu why "/opt/retropie/supplementary/.*/emulationstation([^.]|$)" rather than "/opt/retropie/supplementary/.*/emulationstation$" ? A use case I have missed ?
                                    meleu @BuZz
                                    @BuZz yep. If the user launch emulationstation with some --argument the regex ending with emulationstation$ don't match. :-)
                                    Example: emulationstation --debug
                                    BuZzB 1 Reply Last reply Reply Quote 1
                                      @meleu aha. Thanks. Didn't consider that.
                                        cyperghost @BuZz
                                        @BuZz @meleu
                                        Changes are registered to Restart ES via batch thread
                                        added meleu as "slight" updater
                                        This was easy - wasn't it? EUREKA
                                        For @TMNTturtlguy what the difference between mine and @BuZz @meleu script.
                                        1. They doing all the same: killing one specific process
                                        but
                                        The script of meleu and BuZz
                                        specifies to kill all emulationstation scripts which can found in path "/opt/retropie/supplementary/"
                                        Mine just kills the latest call of any emulationstation call. That's the reason why I wrote ... Keep care of future updates of ES
                                        The the kind of "specification" makes the difference.
                                        Annother tipp for you: Every command has a help section ... just write --help as parameter
                                        If the program manis installed you can get more detailed help by man [command] for ex. man ls
                                        • TMNTturtlguyT
                                          @cyperghost question for you,
                                          I am currently running the main branch EmulationStation updated from source. I have however run several different builds of emulationstation for testing out new updates of ES. As I am now running the main branch as updated from the setup script shouldn't I be running form /opt/supplementary/ ? Are you suggesting that because I have run the test branches when the main install of ES is killed by @BuZz and @meleu command another instance of ES from another location runs?
                                            @cyperghost
                                            This is not true. My last solution above kills only the "real" ES binary. Only one process. And don't do anything with the scripts.
                                            My solution is also able to kill/restart any of the ES mods we (I, @TMNTturtlguy and other guys) are testing. It's also able to kill emulationstation if it's launched with some --argument.
                                            I didn't analyze the solution proposed by @cyperghost to be able to give my opinion, but I'm pretty sure that my solution works pretty fine for what @TMNTturtlguy wants to do in the OP.
