    shell scripting topic
    shellshell scriptprogramming
    191 Posts 10 Posters 92.6k Views
      cyperghost @meleu
      @meleu Yes... therefore the runcommand-onstart. $1 shows current used system. So there is a way to set an overlay for a specfic system ... ;)
        @meleu @cyperghost I had this to start with:
        sed -i 's/01.png/08.png/g' overlay.cfg
        Something feels missing, not sure what at the moment.
          meleu @lilbud
          @lilbud where is placed the script with that line of code? maybe you have to use the full path to the overlay.cfg.
            lilbud @meleu
            @meleu I believe it is placed in the overlay directory.
            opt/retropie/configs/all/retroarch/overlay
              cyperghost @lilbud
              @lilbud Just start coding use echo commands to show results in your bash
              You can test sedcommands directly from CLI and results will be marked red.
              Don't use -i parameter for testing... it will directly write to input file and may give unwantend results. If you want create altered files then work with direction > output-file first.
              If all works then use -i
                lilbud @cyperghost
                @cyperghost Ok, I can get the original command to replace the text, but only if both fields are specified.
                This works fine, 01.png is replaced with 08.png. But what would I put in the first field if the overlay name is not 01.png. Something like this?:
                sed -i 's/${FILENAME}.png/08.png/g' overlay.cfg
                mituM cyperghostC 2 Replies Last reply Reply Quote 0
                  mitu Global Moderator @lilbud
                  @lilbud You can use a wildcard:
                  sed -i 's/.*.png/08.png/g' overlay.cfg
                  Note that this will replace any <filename>.png in the file with 08.png.
                    cyperghost @lilbud
                    @lilbud I'm still not sure what your goal is.
                    Anwer yourself:
                    1. Where is the overlay.cfg located?
                    2. In which case do you want to alter overlays?
                    3. Is there a "system" in altering names (Maybe $EMU-$ROMNAME-$TAG.png?)
                    Imho ... here's is a good script that writes several information in /boot/config.txt and checks existance of data before.
                    For graphics menu layout you can use this it uses arrays for graphics menu and here is a Howto for dialog/whiptail usage.
                    Here is the RetroPie wiki and how to input paramters into your script.
                    lilbudL meleuM 2 Replies Last reply Reply Quote 0
                      lilbud @cyperghost
                      @cyperghost okay
                      • Overlay.cfg located in default directory, /opt/retrofit/configs/all/retroarch/overlay
                      • The point of the script is to provide a way a to switch and choose the overlay from the retropie menu in ES.
                      • So choosing overlay named, '08.png, will do a few things. It will check for an overlay in use. If one is found, then the cfg file will be modified to show the path of the wanted overlay.png, (/my/awesome/overlay/8.png).
                      • Once the overlay is selected, the main retroarch.cfg will be modified with the viewport settings and the overlay.
                      Anything else needing further explanation?
                        cyperghost @lilbud
                        @lilbud No I understood.
                        All the links I've provided to you will help you to code this.
                        Just start over with the selection menu ;)
                          lilbud @cyperghost
                          @cyperghost If I can find a way to get the script done during class, I'll see if I can work on it.
                          I think there is bash on my school computer...
                            cyperghost @lilbud
                            @lilbud
                            Bash? School computer?
                            Code on your Pie!
                            All you need is a SSH terminal and nanoas editor
                            So you I would do the following.
                            1. You write a selection menu that provides a layout for selected system and save it to config
                            2. You write an "enabler" that sets overlay according to choosen system
                              lilbud @cyperghost
                              @cyperghost I don't have access to my pi in school, besides, the schools network is locked to any device that isn't a school issued computer.
                                meleu @cyperghost
                                @cyperghost said in shell scripting topic:
                                I'm afraid that a scriptmodule isn't a good example for starters ;-)
                                @lilbud said in shell scripting topic:
                                Yes, post your code in ghostbin or something so we can give more effective guidance.
                                lilbudL cyperghostC 2 Replies Last reply Reply Quote 0
                                  lilbud @meleu
                                  @meleu I'll have to redo it today, I'll post a link later.
                                    cyperghost @meleu
                                    @meleu Yes but for the sake of coding style
                                    choice=$(dialog --command1 --command2 --menulist \
                                            1 Option 1 \
                                            2 Option 2 \
                                            redirection to ....)
                                    is better coded in this script menu example ;)
                                    dialogcmd=(dialog --command1 --command2 --menu)
                                    dialogoptions=("1" "Option 1" "2" "Option 2")
                                    choice=$("${dialogcmd[@]}" "${dialogoptions[@]}" redirection to)
                                    And it will be much easier for bug hunting. Because structur here is clear. And this was my intention to bring this script module into game.
                                    dialogcmd sets the structure of how the menu will looks like as array
                                    dialogoptions is the data array for selection
                                    and now with choice you put cmd and options together.
                                    And I think this is a good example of clean coding ;)
                                    Of course @lilbud will choose his own flavour later
                                      @meleu @cyperghost Here is my plan for the script: https://ghostbin.com/paste/6bbsa
                                      not much in the way of code since I don't have a way to write/test it on my school computer.
                                      • hiulitH
                                        hiulit
                                        Hi there!
                                        I've created my first shell script and I'd like your opinion, codewise.
                                        It's a script to install some extras for RetroPie themes (icons, splashscreens and launching images).
                                        The code is here: https://github.com/hiulit/es-theme-extras/blob/master/es-theme-extras.sh
                                        I've created a post on this forum https://retropie.org.uk/forum/topic/13344/extras-for-retropie-themes-icons-splashscreens-and-launching-images-es_theme_extras-shell-script You can check it out to see more details.
                                        Thanks! :)
                                        My little contributions to the RetroPie project:
                                        • Shell-Script-Boilerplate
                                        • Fun-Facts-Splashscreens
                                        • Limit-Last-Played-Games
                                          meleu @hiulit
                                          @hiulit I saw that post. That's a pretty cool idea. I'm just a little busy with RL stuff, but I'll take a look at that soon. ;-)
                                          hiulitH 1 Reply Last reply Reply Quote 1
                                          • hiulitH
                                            hiulit @meleu
                                            @meleu I'm glad you think it's a good idea! :D I think so too, but it would need every theme creator to get involved. We'll see if more people find it useful.
