    Controller not working with lr-fbalpha
    retropiecontroller
    15 Posts 3 Posters 3.7k Views
      kousuke @edmaul69
      @edmaul69 I uninstalled and reinstalled, same issue still. :(
        edmaul69 @kousuke
        @kousuke did you delete the retroarch.cfg i mentioned you needed to delete?
          kousuke @edmaul69
          @edmaul69 yeah, i deleted the cfg file, then removed the emulator, and installed it back again. :(
            edmaul69 @kousuke
            @kousuke do you have joystick selection installed in the retropie menu? If so look under fba and see what is set as the controller in there. If there is a controller or it is set to disabled just set it to unset.
              kousuke @edmaul69
              @edmaul69 how do I see if I have joystick selection installed?
              K edmaul69E 2 Replies Last reply Reply Quote 0
                kousuke @kousuke
                my /opt/retropie/configs/fba/retroarch.cfg file looks like this:
                https://pastebin.com/rmQrK7X4
                  edmaul69 @kousuke
                  @kousuke if you go into the retropie menu in emulationstation you should see joystick select with all the other settings. If it isnt there, go into the runcommand in that list and enable it. Then you can actually assign your controller to fba forcing it to use your controller. If that doesnt work, in lr-fbalpha if you hit the tab key it might give you an options menu. If so you can probably assign the keys in there.
                    dankcushions Global Moderator
                    i'm still convinced lr-fbalpha isn't being run, and instead it's pifba. is lr-fbalpha set as the default emulator for fba? you can check via the runcommand. if you change it, check that it stays that way by checking again after.
                      kousuke @dankcushions
                      @dankcushions forcing my snes controller to be player 1 works in the emulator now but the I can no longer start game from the snes controller anymore. I have to use the keyboard to start it.
                        kousuke @edmaul69
                        @edmaul69 I went to configure edit, configure basic libretro emulator options, configure additional options for fba, choose joypad order, and 0 for my snes controller.
