    PCSX-ReARMed controls do not work
    pcsx-rearmedlr-pcsx-rearmedcontrolscontroller
    13 Posts 3 Posters 6.7k Views
      ScyllaBus
      I honestly have no idea what's wrong. Controls work on other emulators, just not PSX.
      Quick Menu > Options: Set all Pad Type's to default, standard, and analog. Didn't work.
      Quick Menu > Controls: Set all User # Device Type's to RetroPad and RetroPad w/ Analog. Didn't work. Set all User # Analog To Digital to Left Analog, didn't work.
      Tried redoing the inputs for my controller on RetroPie.
      Controls worked before but I remember having a PCSX-ReArmed file somewhere (might've been somewhere in /opt/retropie/emulators?) and I deleted it as I was having trouble getting the analog stick to work and saw that this was recommended.
      Not sure if this is it, but I don't even remember where it was. A solution where I don't have to reflash RetroPie to the SD card would be ideal since I don't have an SD Card reader.
      I kind of just want to reset all my control / emulator config settings but I have no idea how to do that without reinstalling retropie onto the SD using win32diskimager.
      Raspberry Pi 3
      RetroPie v4.3 (official)
      USB Devices Connected:
      • N64 iNNEXT Gamepad
      • Keyboard
      I've read online that you can just delete config files and it should all reset, but I'm not sure which folder(s) to delete. I don't care if I lose all my controller settings, I'll redo them. Just which folders do I delete to reset all the settings?
        I think if you delete the es_input.cfg from within the /home/pi/.emulationstation folder, you can start from scratch with the controller configurations in ES.
          ScyllaBus @mitu
          The controller settings in ES work fine. I'm talking about RetroArch emulators (mainly PSX but I don't mind if they all get wiped).
          What folder(s) can I delete to reset all emulator settings (all settings) ?
          jonnykeshJ mituM 2 Replies Last reply Reply Quote 0
          • jonnykeshJ
            jonnykesh @ScyllaBus
            @scyllabus The controller configuration in ES is copied over to the RetroArch cores automatically. So if you follow the advice given above it should rewrite any corrupted RetroArch controller configs you have.
              mitu Global Moderator @ScyllaBus
              @scyllabus https://retropie.org.uk/docs/Playstation-1/ - see what's the controller config locations - probably /opt/retropie/configs/psx/pcsx.cfg for the non-lr emulator and /opt/retropie/configs/psx/retroarch.cfg for the libretro version.
                ScyllaBus @jonnykesh
                @jonnykesh Deleted (renamed) the entire /opt/retropie/configs folder.
                When I try launching a PSX game: "No config found for system psx"
                I rebooted as well. Nothing.
                  @scyllabus Re-install the psx emulator and the - default - configs will be re-created.
                    ScyllaBus @mitu
                    @mitu I ran the RetroPie-setup script and that seemed to fix it.
                    The only thing I'm having a problem with now is I can't get Final Fantasy 7 to work. The controls just don't respond no matter what I do.
                    Other games work fine though.
                      @scyllabus Silly question, but do you have the BIOS installed ? Maybe FF7 is a different region ROM and needs the corresponding BIOS file - check out https://retropie.org.uk/docs/Playstation-1/.
                        I tried loading Final Fantasy 7 - the ROM name is Final Fantasy VII (USA), and the controls definitely work. Used a standard WiiU Pro Controller, connected via bluetooth.
                        Starting PCSX-ReARMed
                        Running PCSX Version 1.9 (Sep 17 2017).
                        psxMap: warning: wanted to map @80000000, got 0x74290000
                        Init new dynarec
                        testing if we can run recompiled code..
                        test passed.
                        warning: RAM is not directly mapped, performance will suffer
                        Mapped (RAM/scrp/ROM/LUTs/TC):
                        77000000/1f800000/1fc00000/08000000/74e53000
                        found BIOS file: scph5501.BIN
                        RGB565 supported, using it
                        plugin: plugins/builtin_gpu
                        plugin: plugins/builtin_spu
                        plugin: plugins/builtin_pad
                        Plugins loaded.
                        Loaded CD Image: /home/pi/RetroPie/roms/psx/Final Fantasy VII (USA) (Disc 1).cue[+cue].
                        Track 01 (DATA) - Start 00:02:00, Length 70:37:12
                        selected sound output driver: libretro
                        CD-ROM Label: FINALFANTASY7
                        Check the Runcommand log to spot any obvious errors.
                          ScyllaBus @mitu
                          pi@retropie:~ $ sudo cat /dev/shm/runcommand.log
                          Parameters:
                          Executing: SDL_VIDEO_EGL_DRIVER=/opt/vc/lib/libEGL.so SDL_VIDEO_GL_DRIVER=/opt/vc/lib/libGLESv2.so /opt/retropie/emulators/retroarch/bin/retroarch -L /opt/retropie/libretrocores/lr-pcsx-rearmed/libretro.so --config /opt/retropie/configs/psx/retroarch.cfg "/home/pi/RetroPie/roms/psx/Final Fantasy VII (USA) (Disc 1).cue" --appendconfig /dev/shm/retroarch.cfg
                          Running PCSX Version 1.9 (Nov 10 2017).
                          psxMap: warning: wanted to map @80000000, got 0x741fc000
                          Init new dynarec
                          test passed.
                          77000000/1f800000/1fc00000/08000000/74dbf000
                          found BIOS file: SCPH1001.BIN
                          Plugins loaded.
                          CD-ROM ID: SCUS94163
                          CD-ROM EXE Name: SCUS_941.63;1
                            @scyllabus The only difference I see is the bios filename ( scph5501.BIN vs SCPH1001.BIN). Can you enable verbose logging via the Runcommand launch menu (https://retropie.org.uk/docs/Runcommand/#runcommand-launch-menu) and try using the controller, then paste the log file on pastebin.com ? Maybe we spot some errors there.
                              ScyllaBus @mitu
                              @mitu I've already reinstalled retropie like 4 times and I swear, every time I touch the controls and attempt to enable the analog stick on FF7, the controls just break forever. Even if I don't save anything. It's so incredibly weird.
                              I've reinstalled for the fourth time and it's working (without analog) on FF7, so I'm just going to not even touch the settings. I really don't want to redo my RetroPie image anymore.
                              I'm just honestly baffled I'm the only person that's ever had this problem with FF7 on RetroPie.
