    Is there a simple way to make DragonRise controllers work with Daphne??
    daphnecontrollersdragonrise
    69 Posts 17 Posters 18.3k Views
      kmorreison
      that work on retropie 4.5.15??? i try this on one image but get some errors wen try install.... need make this on empy?? out installation??
      pls help me? im new on this and have this same problem =(
        kmorreison
        @grant2258 pls sir can u help me??? I have last bersion retropie and have daphne installed, wen tri use this comands two first work and download or install anything... But wen use built and install have some error say not find file or way. Sorry for my english... I need make this for use joy =(
        My retropie are 5. 1.15
          grant2258 Banned
          looks like updates would be needed to compile for the latest pi. Ill look into this when i have time.
          K 2 Replies Last reply Reply Quote 1
            kmorreison @grant2258
            @grant2258 i have pi3B and retropie version 5.1.15.
            I love u if have time for this!! Hehe very thanks sir really. Thanks for u time and u work!
            And i need have installed for use this or not need daphme installed?
              @grant2258 i join this tread 10 times per hour now hahaha. Thanks for u time.
              That my first machine...
                kmorreison
                I am excited to be able to play the Dl saga in the little machine, I do not see the day that I can do it one of my illusions is to play these games and it is bad luck that these usb controllers fail ...
                  grant2258 Banned
                  im testing now is compiling will let you know soon.
                  edit i had no issues it compiled and installed fine all i can think of something could be going wrong with your copy and paste do one line at a time.
                    kmorreison
                    Do I have to have daphne installed before doing it or completely deleted ??
                    I don't have to activate anything else from the raspberry setup or something ??
                    That night at house i check anything.
                    Not are posible send me a file compiled?
                    Thanks again sir
                      grant2258 Banned
                      no need to install anything the instructions will compile and install. I would suggest you set your controller again as it trigger a script to set your controller config for daphne after you install it.
                        kmorreison
                        When I get home I will try again, I use a full version that already had daphne installed, I will try to uninstall it better before doing so. Right?
                          grant2258 Banned
                          no need to uninstall it does an install anyway
                            kmorreison
                            When I get home I will try again and if it gives me any problems I will try to put some image around here. Thanks for u time
                            What program use to connect for ssh?? Need that for copy paste rigth?
                              grant2258 Banned @kmorreison
                              @kmorreison yes I use a program called putty
                                kmorreison
                                I hope it is not very complicated to use putty, I have never used any of this
                                  kmorreison
                                  @grant2258 Greetings again, the truth I am a little sad because I do not know what is happening and it is frustrating lol. It seems that everything is installing well until a moment comes to a stop and tells me this, I attach the photo.
                                  https://imgur.com/a/1zbJFMH
                                  Sorry but it seems that I will not add photos to be seen in the forum ...
                                  That finish say /tmp/build/daphne/daphne.bin not found, and stoped...
                                  I know that you are the only person who can help me in this world and I am super grateful for the time dedicated.
                                  Wouldn't it be possible somehow to pass me the already compiled files or folders to see if I would make it work? I don't understand why it gives me that failure = (
                                    This post is deleted!
                                      @kmorreison if you paste all them lines at the same time it will fail. Paste one at a time
                                        @grant2258 i just paste one for one and wen ise build line get that fail after some minuts. I paste one at a time allways. Yesterday i use putty for copy and paste lines.
                                        Now I am already at work, I paste one by one and when I use the one of install, after who seems to be compiling everything well, after a few minutes that phrase comes out. U check screen?
                                        Wouldn't it be possible to try to pass the files to me? I would be eternally grateful to him.
                                        If not, I don't know what else to do, try to install a retropie from scratch and try.
                                          kmorreison
                                          The case is that doing it line by line that when I launch the install ends up giving that problem after working a long time.
                                          I give u my email if are needed to help me pls.
                                            @grant2258 wen use install that copy all files from /tmp... to /opt/emulators but wen try find a daphne.bin cant found that file. Thanks again
