    Is there a simple way to make DragonRise controllers work with Daphne??
    daphnecontrollersdragonrise
    69 Posts 17 Posters 16.3k Views
    • F
      fxvielander
      I thought that was the case but previous posts had me questioning myself.
      Unfortunatley I’ve not found any other place to get the files for this fix. Any ideas how I can locate the files? Alternatively, should the files still be on my Pi from when I ran it before, possibly? Last night I got errors when I tried to use this fix by skipping the line pulling Daphne down from GitHub, but I’m wondering that maybe I could install an older version of Daphne (one that works with this fix)? Or, as part of this am I in fact installing Daphne? Sorry for the questions…
      DirtBagXonD 1 Reply Last reply Reply Quote 0
      • DirtBagXonD
        DirtBagXon @fxvielander
        @fxvielander said in Is there a simple way to make DragonRise controllers work with Daphne??:
        You could try hypseus, it's in the experimental packages.
        It offers far more flexibility in configuration over the original Daphne.
        https://retropie.org.uk/docs/Daphne/
        Hypseus Singe for RetroPie: https://github.com/DirtBagXon/hypseus-singe
        Hypseus Singe Games: https://github.com/DirtBagXon/hypseus_singe_data
        Hypseus Discord: https://discord.gg/dgCsCfmRfJ
        • F
          fxvielander
          I installed and tried hypseus, it solved the problem! My DragonRise controller works well again. Thank you!
          DirtBagXonD 1 Reply Last reply Reply Quote 1
          • DirtBagXonD
            I have had a few people ping me about more complex Joystick setups with hypseus recently. So I have written a small helper utility to ease the +1 calculations and multiple joystick config gotchas.
            I hope this proves useful.
            In RetroPie, I suggest the CLI version (over ssh) would be the way to go.
            https://github.com/DirtBagXon/hypjsch
            2 joystick(s) found
            Microsoft X-Box 360 pad:        Button: 001     - KEY_QUIT = SDLK_ESCAPE 0 001
            Microsoft X-Box 360 pad:        Axis: 002       - KEY_DOWN = SDLK_DOWN 0 0 +002
            DragonRise Inc. Generic:        Button: 106     - KEY_QUIT = SDLK_ESCAPE 0 106
            DragonRise Inc. Generic:        Axis: 103       - KEY_DOWN = SDLK_DOWN 0 0 +103
            There is also a GUI version for desktop users.
            hypjsch
            • I
              insx
              Should these build instructions still work? I got prompted for a username and password at the git clone... stage but even after supplying a github username and password I got told that password authentication is not supported.
              • DirtBagXonD
                DirtBagXon @insx
                @insx said in Is there a simple way to make DragonRise controllers work with Daphne??:
                It sounds like you are trying to clone from the "SSH" url, rather than the "HTTPS" url, of the repo. You don't need any auth on the HTTPS endpoint.
                • I
                  insx @DirtBagXon
                  @DirtBagXon
                  I'm pretty sure I did exactly this, I tried it several times to make sure I hadn't typed something wrong.
                  git clone https://github.com/grant2258/daphne-emu.git tmp/build/daphne
                  W DirtBagXonD 2 Replies Last reply Reply Quote 0
                  • W
                    Wampa @insx
                    @insx
                    That particular repo by grant2258 hasn't existed for a long time:
                    https://github.com/grant2258?tab=repositories
                    • DirtBagXonD
                      DirtBagXon @insx
                      @DirtBagXon
                      Let me append to my previous answer.
                      ...or the repo doesn't exist :)
