    ScummVM Controlller Issues
    scummvm
    168 Posts 3 Posters 36.1k Views
    • E
      escc1986
      im sorry i edited the wrong scumm file
      would you be so kind to send me a copy of the +Start ScummVM.sh file
      im sorry for the mistake
      • E
        escc1986
        i may have not understood ,
        so in my xdrive folder
        /opt/retropie/configs/all/xdrive
        the 2 files i should have are
        scumm.sh
        scumm.cfg
        ( i only have a scumm.cfg)
        i will make a scumm.sh wilth you content you provided , i applogize)
        hope you abel to send me a copy of +Start ScummVM.sh (i messed mine up)
        • ExarKunIvE
          ExarKunIv @escc1986
          @escc1986
          no just the .cfg file
          this will be the +start scummvm.sh that is in the rom/scummvm folder
          #!/bin/bash
          sudo /opt/retropie/supplementary/xboxdrv/bin/xboxdrv >> /dev/shm/runcommand.log 2>&1 --evdev /dev/input/event0 --config /opt/retropie/configs/all//xdrive/scumm.cfg &
          game="$1"
          pushd "/home/pi/RetroPie/roms/scummvm" >/dev/null
          /opt/retropie/emulators/scummvm/bin/scummvm --fullscreen --joystick=0 --extrapath="/opt/retropie/emulators/scummvm/extra" $game
          while read id desc; do
              echo "$desc" > "/home/pi/RetroPie/roms/scummvm/$id.svm"
          done < <(/opt/retropie/emulators/scummvm/bin/scummvm --list-targets | tail -n +3)
          popd >/dev/null
          sorry dont worry about the scumm.sh. thats wrong. i miss typed
          ill edit the about folder to make it easy to under stand
          • ExarKunIvE
            ExarKunIv
            ok i edit the one that i first posted today hope its easyer to understand
            • E
              escc1986
              im sorry for the re-route but my scumm isnt working with the +Start ScummVM.sh you provided
              i do aplogize for the mess up
              • E
                escc1986
                (Sorry for Any Confusion) i originally changed the +Start ScummVM.sh to
                #!/bin/bash
                game="$1"
                popd >/dev/null
                and my games stoped working
                • ExarKunIvE
                  ExarKunIv @escc1986
                  @escc1986
                  no clue.
                  i just copyed what you posted into mine and it works fine
                  your +Start ScummVM.sh is in the roms folder
                  right?
                  • E
                    escc1986
                    interesting .... yeah no clue either ... yes +Start ScummVM.sh
                    well im stumped , im just uninstalling and reinstalling ... i will come back when it reinstalls
                    • ExarKunIvE
                      ExarKunIv @escc1986
                      @escc1986
                      remove this line from the +Start ScummVM.sh
                      before you uninstall, but if you did dont worry about it. get the game to launch again
                      • E
                        escc1986
                        that took along time , sorry about that
                        just installed
                        rebooted
                        scumm games work now
                        what would be the first thing you want me to try
                        (Just made a back up , just incase we have the same probmem with +Start ScummVM.sh)
                        just updated the .config in xdrive folder
                        [xboxdrv]
                        silent=true
                        deadzone=4000
                        deadzone-trigger=15%
                        dpad-as-button=false
                        trigger-as-button=true
                        detach-kernel-driver=true
                        #force-feedback=true
                        mimic-xpad=true
                        [evdev-absmap]
                        ABS_X=x1
                        ABS_Y=y1
                        ABS_Z=x2
                        ABS_RZ=y2
                        ABS_HAT0X=dpad_x
                        ABS_HAT0Y=dpad_y
                        [evdev-keymap]
                        KEY_#304=a
                        KEY_#305=b
                        KEY_#307=x
                        KEY_#308=y
                        KEY_#312=back
                        KEY_#313=start
                        KEY_#310=tl
                        KEY_#311=tr
                        [ui-axismap]
                        x1=KEY_LEFT:KEY_RIGHT
                        y1=KEY_DOWN:KEY_UP
                        dpad_x=REL_X:10
                        dpad_y=REL_Y:10
                        [ui-buttonmap]
                        a=BTN_LEFT
                        b=BTN_RIGHT
                        x=KEY_ENTER
                        back=KEY_F5
                        start=KEY_ESC
                        # EOF #
                        and run the game
                        typed in cat /proc/bus/input/devices
                        and got
                        I: Bus=0005 Vendor=057e Product=2007 Version=0001
                        N: Name="NES Controller (L)"
                        P: Phys=b8:27:eb:7b:bc:a9
                        S: Sysfs=/devices/platform/soc/3f201000.serial/tty/ttyAMA0/hci0/hci0:11/0005:057E:2007.0001/input/input0
                        U: Uniq=ec:c4:0d:a4:92:4a
                        H: Handlers=js0 event0
                        B: PROP=0
                        B: EV=10001b
                        B: KEY=ffff0000 0 0 0 0 0 0 0 0 0
                        B: ABS=3001b
                        B: MSC=10
                        ( i havent touched since restall ScummVM.sh)
                        • E
                          escc1986
                          this is my ScummVM.sh (Before any changes)
                          #!/bin/bash
                          game="$1"
                          popd >/dev/null
                          • ExarKunIvE
                            ExarKunIv @escc1986
                            @escc1986
                            ok good.
                            1 is the xdrive folder in the config/all folder
                            2 all you need to do is add 1 line of code to the +Start ScummVM.sh right under the #!/bin/bash
                            • E
                              escc1986
                              Alright ... i just altered the ScummVM.sh
                              to
                              #!/bin/bash
                              game="$1"
                              popd >/dev/null
                              games work
                              controllers doesnt work
                              well controolers works but same as before
                              dpad not working
                              l = space
                              r =f2
                              • ExarKunIvE
                                ExarKunIv @escc1986
                                @escc1986
                                ummm, there is nothing different with what you are showing me
                                • E
                                  escc1986
                                  @ExarKunIv said in ScummVM Controlller Issues:
                                  just followed your instructions now
                                  it Worked !!!
                                  Thanks Alot !!!!
                                  Your Absoulty Amazing !!!!
                                  with All your hard work , you have Accomplished this Difficult task
                                  so for the future if i want to modfy the buttons what do i do
                                  right now , i think the speed of the dpad is a bit fast , how can i change the speed to half ?
                                  • ExarKunIvE
                                    ExarKunIv @escc1986
                                    @escc1986
                                    there is one last thing
                                    • E
                                      escc1986
                                      sure , whats the last thing
                                      • ExarKunIvE
                                        ExarKunIv @ExarKunIv
                                        @ExarKunIv
                                        we need a runcommand-onend.sh
                                        that has this in it
                                        #!/bin/sh
                                        sudo killall >> /dev/shm/runcommand.log 2>&1 xboxdrv
                                        to make this file run this
                                        nano /opt/retropie/configs/all/runcommand-onend.sh
                                        and paste this
                                        #!/bin/sh
                                        if its not there
                                        once thats done
                                        run
                                        chmod +x /opt/retropie/configs/all/runcommand-onend.sh
                                        • ExarKunIvE
                                          ExarKunIv
                                          to make it slower i think you change the 10 to a higher number. and if that dont work go lower
                                          y1=KEY_DOWN:KEY_UP
                                           dpad_x=REL_X:10
                                          dpad_y=REL_Y:10
                                          • E
                                            escc1986
                                            what does
                                            do ?
