    ScummVM Controlller Issues
    scummvm
    168 Posts 3 Posters 29.1k Views
    • ExarKunIvE
      ExarKunIv @escc1986
      @escc1986
      so the way i do things now is i have a command that gets ran when i pick a certain game, unlike the way we where just playing with. that way is always running in the back ground in a way waiting for a game that needs is to start and away it goes.
      so im hoping that i can get my way to work and we can go from there, cuz i think even with what ever settings or naming that has been done it will not matter.
      plus if you get to any other games that need something custom like the games in PORTS. it is very easy to copy and past from one to the other
      • E
        escc1986
        Fascinating ... i hope you way , will be the way to go :)
        • ExarKunIvE
          ExarKunIv @escc1986
          @escc1986
          ok here goes, from what i was able to test it does work on my system and it does over ride whatever preconfiged controls
          in the rom/scummvm folder open the +start scummvm.sh and add this line under the #!/bin/bash but before anything else
          sudo /opt/retropie/supplementary/xboxdrv/bin/xboxdrv >> /dev/shm/runcommand.log 2>&1 --evdev /dev/input/event0 --config /opt/retropie/configs/all//xdrive/scumm.cfg &
          dont forget to change the event number to match yours
          now in the config folder go to the all folder and make a new folder named xdrive
          in there make a new file called scumm.cfg
          in there paste this
          [xboxdrv]
          silent=true
          deadzone=4000
          deadzone-trigger=15%
          dpad-as-button=false
          trigger-as-button=true
          detach-kernel-driver=true
          #force-feedback=true
          mimic-xpad=true
          [evdev-absmap]
          ABS_X=x1
          ABS_Y=y1
          ABS_Z=x2
          ABS_RZ=y2
          ABS_HAT0X=dpad_x
          ABS_HAT0Y=dpad_y
          [evdev-keymap]
          BTN_SOUTH=a
          BTN_EAST=b
          BTN_NORTH=x
          BTN_WEST=y
          BTN_TL=lb
          BTN_TL2=lt
          BTN_TR=rb
          BTN_TR2=rt
          BTN_SELECT=back
          BTN_START=start
          BTN_THUMBL=tl
          BTN_THUMBR=tr
          [ui-axismap]
          x1=KEY_LEFT:KEY_RIGHT
          y1=KEY_DOWN:KEY_UP
          dpad_x=REL_X:10
          dpad_y=REL_Y:10
          [ui-buttonmap]
          a=BTN_LEFT
          b=KEY_LEFTCTRL
          x=KEY_ENTER
          y=KEY_R
          lb=KEY_C
          lt=KEY_A
          rb=KEY_SPACE
          rt=KEY_D
          back=KEY_F5
          start=KEY_ESC
          tr=KEY_K
          tl=KEY_Y
          # EOF #
          now of corse you need to change the buttons to mactch your controller.
          these are from my setup
          there will be some fine tuning that you will need to do, but this i hope should get you to work.
          • E
            escc1986
            Question :
            How do you create a new folder "xdrive" in command ?
            I made a mistake and
            Sudo nano xdrive ( sudo nano means txt from what I found out )
            How do you create a new folder ?
            • ExarKunIvE
              ExarKunIv @escc1986
              @escc1986
              mkdir /opt/retropie/configs/all/xdrive
              to make the config file
              then sudo nano /opt/retropie/configs/all/xdrive/scumm.cfg
              i just network into mine from the computer and use explorer to do most of everything
              so i just right click for everything, lol
              • E
                escc1986
                @ExarKunIv said in ScummVM Controlller Issues:
                [xboxdrv]
                silent=true
                deadzone=4000
                mimic-xpad=true
                [evdev-absmap]
                ABS_X=x1
                ABS_Y=y1
                ABS_Z=x2
                ABS_RZ=y2
                ABS_HAT0X=dpad_x
                ABS_HAT0Y=dpad_y
                [evdev-keymap]
                BTN_SOUTH=a
                BTN_EAST=b
                BTN_NORTH=x
                BTN_WEST=y
                BTN_TL=lb
                BTN_TL2=lt
                BTN_TR=rb
                BTN_TR2=rt
                BTN_SELECT=back
                BTN_START=start
                BTN_THUMBL=tl
                BTN_THUMBR=tr
                [ui-axismap]
                y1=KEY_DOWN:KEY_UP
                dpad_x=REL_X:10
                dpad_y=REL_Y:10
                [ui-buttonmap]
                a=BTN_LEFT
                b=KEY_LEFTCTRL
                x=KEY_ENTER
                y=KEY_R
                lb=KEY_C
                lt=KEY_A
                rb=KEY_SPACE
                rt=KEY_D
                back=KEY_F5
                start=KEY_ESC
                tr=KEY_K
                tl=KEY_Y
                EOF
                [evdev-absmap]
                ABS_X=x1
                ABS_Y=y1
                ABS_Z=x2
                ABS_RZ=y2
                ABS_HAT0X=dpad_x
                ABS_HAT0Y=dpad_y
                i dont understand ... how to change it to mine , can you help me
                ExarKunIvE 2 Replies Last reply Reply Quote 0
                • ExarKunIvE
                  ExarKunIv @escc1986
                  @escc1986
                  that part you dont have too. i tested it with my dpad since they where call the same as yours
                  • E
                    escc1986
                    BTN_SOUTH=a
                    BTN_EAST=b
                    BTN_NORTH=x
                    BTN_WEST=y
                    BTN_TL=lb
                    BTN_TL2=lt
                    BTN_TR=rb
                    BTN_TR2=rt
                    BTN_SELECT=back
                    BTN_START=start
                    BTN_THUMBL=tl
                    BTN_THUMBR=tr
                    --evdev-keymap KEY_#304=a,KEY_#305=b,KEY_#307=x,KEY_#308=y,KEY_#310=tl,KEY_#311=tr,KEY_#312=select,KEY_#313=start
                    i just replace with my numbers
                    example: Key_#304=a
                    • ExarKunIvE
                      ExarKunIv @escc1986
                      @escc1986
                      that should work,
                      if not
                      this is what the buttons are called when you press then vs what you are pressing.
                      example you dont want this
                      BTN_START=start. you want this BTN_TR2=start
                      [evdev-keymap]
                      BTN_SOUTH=a
                      BTN_EAST=b
                      BTN_NORTH=x
                      BTN_WEST=y
                      BTN_TL=lb
                      BTN_TL2=lt
                      BTN_TR=rb
                      BTN_TR2=rt
                      BTN_SELECT=back
                      BTN_START=start
                      BTN_THUMBL=tl
                      BTN_THUMBR=tr
                      and
                      this is what you want the buttons to do
                      [ui-buttonmap]
                      a=BTN_LEFT
                      b=KEY_LEFTCTRL
                      x=KEY_ENTER
                      y=KEY_R
                      lb=KEY_C
                      lt=KEY_A
                      rb=KEY_SPACE
                      rt=KEY_D
                      back=KEY_F5
                      start=KEY_ESC
                      tr=KEY_K
                      tl=KEY_Y
                      now i have a bunch of things you dont need so just delete them as you go.
                      • E
                        escc1986
                        [xboxdrv]
                        silent=true
                        deadzone=4000
                        mimic-xpad=true
                        [evdev-absmap]
                        ABS_X=x1
                        ABS_Y=y1
                        ABS_Z=x2
                        ABS_RZ=y2
                        ABS_HAT0X=dpad_x
                        ABS_HAT0Y=dpad_y
                        [evdev-keymap]
                        KEY_#304=a
                        KEY_#305=b
                        KEY_#307=x
                        KEY_#308=y
                        =lb
                        =lt
                        =rb
                        =rt
                        KEY_#312=back
                        KEY_#313=start
                        KEY_#310=tl
                        KEY_#311=tr
                        [ui-axismap]
                        y1=KEY_DOWN:KEY_UP
                        dpad_x=REL_X:10
                        dpad_y=REL_Y:10
                        [ui-buttonmap]
                        a=BTN_LEFT
                        b=BTN_RIGHT
                        x=KEY_ENTER
                        y=
                        lb=
                        lt=
                        rb=
                        rt=
                        back=KEY_F5
                        start=KEY_ESC
                        tr=
                        tl=
                        # EOF #
                        How does it look by you ?
                        if this looks ok ....
                        where do i put this config in the scumm.config
                        then what would i need to do
                        reboot and try game , right ?
                        • E
                          escc1986
                          this method didnt work for me
                          it was the same like before
                          dpad didnt work
                          L = space
                          R= f2
                          • E
                            escc1986
                            let me try the other way you suggeted
                            • E
                              escc1986
                              unfortunately
                              same as before
                              dpad didnt work
                              L = space
                              R= f2
                              Anything Else we could try
                              • E
                                escc1986
                                +start scummvm.sh
                                #!/bin/bash
                                game="$1"
                                pushd "/home/pi/RetroPie/roms/scummvm" >/dev/null
                                /opt/retropie/emulators/scummvm/bin/scummvm --fullscreen --joystick=0 --extrapath="/opt/retropie/emulators/scummvm/extra" $game
                                while read id desc; do
                                    echo "$desc" > "/home/pi/RetroPie/roms/scummvm/$id.svm"
                                done < <(/opt/retropie/emulators/scummvm/bin/scummvm --list-targets | tail -n +3)
                                popd >/dev/null
                                this is my +Start ScummVM.sh
                                • E
                                  escc1986
                                  i tried this method many times , no luck
                                  i hope im doing it right
                                  • ExarKunIvE
                                    ExarKunIv @escc1986
                                    @escc1986
                                    you put scumm.cfg in the xdrive folder
                                    and you +Start ScummVM.sh looks good leave it
                                    Remove everything that you don,t have a key assigned to for both the keymap and buttonmap
                                    i will try you config tomroow when im at work, thats where my system is at. and ill let you know what i find out
                                    [evdev-keymap]
                                    KEY_#304=a
                                    KEY_#305=b
                                    KEY_#307=x
                                    KEY_#308=y
                                    =lb
                                    =lt
                                    =rb
                                    =rt
                                    KEY_#312=back
                                    KEY_#313=start
                                    KEY_#310=tl
                                    KEY_#311=tr
                                    [ui-axismap]
                                    y1=KEY_DOWN:KEY_UP
                                    dpad_x=REL_X:10
                                    dpad_y=REL_Y:10
                                    [ui-buttonmap]
                                    a=BTN_LEFT
                                    b=BTN_RIGHT
                                    x=KEY_ENTER
                                    y=
                                    lb=
                                    lt=
                                    rb=
                                    rt=
                                    back=KEY_F5
                                    start=KEY_ESC
                                    tr=
                                    tl=
                                    • E
                                      escc1986
                                      alright , no problem
                                      still hasnt worked for me
                                      thank you for trying to help me
                                      i'll talk to you tommrow
                                      • ExarKunIvE
                                        ExarKunIv @escc1986
                                        @escc1986
                                        all i did was remove the empty buttons
                                        this is what i ended up with
                                        this is the scumm.cfg. that is in the config/all/xdrive folder
                                        [xboxdrv]
                                        silent=true
                                        deadzone=4000
                                        mimic-xpad=true
                                        [evdev-absmap]
                                        ABS_X=x1
                                        ABS_Y=y1
                                        ABS_Z=x2
                                        ABS_RZ=y2
                                        ABS_HAT0X=dpad_x
                                        ABS_HAT0Y=dpad_y
                                        [evdev-keymap]
                                        KEY_#304=a
                                        KEY_#305=b
                                        KEY_#307=x
                                        KEY_#308=y
                                        KEY_#312=back
                                        KEY_#313=start
                                        KEY_#310=tl
                                        KEY_#311=tr
                                        [ui-axismap]
                                        y1=KEY_DOWN:KEY_UP
                                        dpad_x=REL_X:10
                                        dpad_y=REL_Y:10
                                        [ui-buttonmap]
                                        a=BTN_LEFT
                                        b=BTN_RIGHT
                                        x=KEY_ENTER
                                        back=KEY_F5
                                        start=KEY_ESC
                                        # EOF #
                                        and it works for me.
                                        so as long as you have your +Start ScummVM.sh looking like this that is in the roms/scummvm folder
                                        #!/bin/bash
                                        game="$1"
                                        popd >/dev/null
                                        and the button maps named as scumm.cfg and saved in configs/all//xdrive
                                        everything should work fine. other then that i dont know.
                                        when you start a game run
                                        cat /proc/bus/input/devices
                                        you should have your controller and then a new one called Microsoft X-Box 360 pad then you know the file is starting.
                                        if not then it is not seeing something.
                                        we'll go from there
                                        • E
                                          escc1986
                                          Hi , Good Morning
                                          so i revised the changes ...
                                          changed everything how it should be
                                          i reboot
                                          now i enter the game in scumm and it doesnt run
                                          it doesnt start , any idea ?
                                          (wait i belive i made a mistake , when you mentioned the scumm.sh file , where is that file located ?)
                                          • ExarKunIvE
                                            ExarKunIv @escc1986
                                            @escc1986
                                            it should be in the config/all/xdrive folder.
                                            (now you can have it where ever you want in the all folder. you will just have to tell the start-scumm.sh where to look
