    Sega model 3 #segamodel3
    sega model 3supermodel
    304 Posts 23 Posters 113.9k Views
    • FollyF
      Folly @DTEAM
      @dteam
      Still not sure what these settings really do.
      In the test menu I did not seem to see any difference.
      I will try again soon.
      • DTEAMD
        DTEAM @Folly
        @folly
        It is essentially the same as what I have already discussed above.
        I'll play with sensitivity. I'm sure my problem is with this parameter like It was with N64 and CDi.
        • FollyF
          Folly @DTEAM
          @dteam
          Ok, understood.
          • DTEAMD
            DTEAM @Folly
            @folly
            I will try after the endless download of MAME 0.233 😂
              mechafatnick
              Sorry, i was distracted by the pinball bartop i've been setting up (it makes mame configuration look easy! :D )
              The automated resolution is a good idea in theory, but my only worry is that our hardware can't really handle going far beyond the Model 3's native res.
              I worry that the average user is going to think they can't run it above something like 640 x 480 wheh in reality you can have it look ok and run ok by rendering low and stretching.
              • FollyF
                Folly @mechafatnick
                @mechafatnick said in Sega model 3 #segamodel3:
                If you don't set a resolution when booting the emulator, it will use the regular resolution. But if you do it will take that resolution.
                I would recommend to test it first.
                If doesn't work we can always revert it back to the original 3 lines.
                  phialek
                  Is daytona 2 playable now? If so I will try the model 3 emulator on my pi. But that it runs at all is still awesome.
                  • FollyF
                    Folly @phialek
                    @phialek
                    I just tested Daytona2 for you.
                    I played a few minutes, it should work !
                    2021-08-05-135037_800x600_scrot-resized.png 2021-08-05-134623_800x600_scrot-resized.png 2021-08-05-134615_800x600_scrot-resized.png 2021-08-05-134551_800x600_scrot-resized.png
                      phialek @Folly
                      @folly
                      Thats awesome!
                      • FollyF
                        Folly @phialek
                        @phialek
                        Try my module-script, let me know how it goes.
                          phialek @Folly
                          @folly
                          Is the file "supermodel-mechafatnick.sh" all i need to get it to install? I have tried the instructions on mechafatnicks site, but couldn't get it to work. I just read that it needs a lib2 dev upgrade, that and a typo where the folder in the roms was wrong spelled didn't let me go further.
                          I think i will delete everything i have done so far and just use your script "supermodel-mechafatnick.sh"
                          • FollyF
                            Folly @phialek
                            @phialek
                            The "supermodel-mechafatnick.sh" is all you need and should be fine.
                              phialek @Folly
                              @folly
                              it didnt start
                              here is the log:
                              Parameters:
                              Executing: xinit /dev/shm/retropie_xinitrc -- vt1 -keeptty
                              X.Org X Server 1.20.4
                              X Protocol Version 11, Revision 0
                              Build Operating System: Linux 5.10.17-v8+ aarch64 Raspbian
                              Current Operating System: Linux retropie 5.10.52-v7l+ #1441 SMP Tue Aug 3 18:11:56 BST 2021 armv7l
                              Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 video=HDMI-A-1:1920x1080M@60 smsc95xx.macaddr=E4:5F:01:37:FC:DD vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 console=ttyS0,115200 console=tty1 root=PARTUUID=2aba0d10-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait loglevel=3 consoleblank=0 plymouth.enable=0
                              Build Date: 19 April 2021 03:23:36PM
                              xorg-server 2:1.20.4-1+rpt3+deb10u3 (https://www.debian.org/support)
                              Current version of pixman: 0.36.0
                              Before reporting problems, check http://wiki.x.org
                              to make sure that you have the latest version.
                              Markers: (--) probed, (**) from config file, (==) default setting,
                              (++) from command line, (!!) notice, (II) informational,
                              (WW) warning, (EE) error, (NI) not implemented, (??) unknown.
                              (==) Log file: "/home/pi/.local/share/xorg/Xorg.0.log", Time: Sun Aug 8 14:19:06 2021
                              (==) Using system config directory "/usr/share/X11/xorg.conf.d"
                              modprobe: FATAL: Module g2d_23 not found in directory /lib/modules/5.10.52-v7l+
                              xrandr: Failed to get size of gamma for output default
                              Set mode 1920x1080@60Hz on default
                              Executing (via xinit): pushd /opt/retropie/emulators/supermodel-mechafatnick
                              /dev/shm/retropie_xinitrc: line 5: ./supermodel: No such file or directory
                              /dev/shm/retropie_xinitrc: line 6: pushd: /opt/retropie/emulators/supermodel-mechafatnick: No such file or directory
                              /dev/shm/retropie_xinitrc: line 6: ./supermodel: No such file or directory
                              xinit: connection to X server lost
                              waiting for X server to shut down (II) Server terminated successfully (0). Closing log file.
                              can you see whats not right?
                              • FollyF
                                Folly @phialek
                                @phialek
                                Hi,
                                I removed my earlier post.
                                Indeed, I discovered that the latest version seems to have an issue with the auto-resolution when running the normal way.
                                I have to investigate why it isn't working the way it should.
                                Can you de-install the latest version and then install this older version ? :
                                https://raw.githubusercontent.com/FollyMaddy/RetroPie-Share/bcc1bfb9ef00ded0b060f70df06d10c6660f07f1/00-scriptmodules-00/emulators/supermodel-mechafatnick.sh
                                It will produce 3 lines in emulators.cfg with different resolution.
                                I hope this will work for you.
                                  phialek @Folly
                                  @folly
                                  thank you, now i could choose a resolution, howeever it didnt run the game. here is the log:
                                  (==) Log file: "/home/pi/.local/share/xorg/Xorg.0.log", Time: Sun Aug 8 20:51:02 2021
                                  • FollyF
                                    Folly @phialek
                                    @phialek
                                    I can't directly see what wrong.
                                    It looks like the same log from earlier.
                                    I would expect to see some -res parts for the resolution but I don't see that.
                                    Do you use a pi4 ?
                                    Is the binary of supermodel in this directory : /opt/retropie/emulators/supermodel-mechafatnick ?
                                      mechafatnick @Folly
                                      @folly @phialek
                                      If the binary is there, could it be a permission issue? is it worth running:
                                      chmod -R 755 /opt/retropie/emulators/supermodel-mechafatnick
                                      just to be on the safe side?
                                      • FollyF
                                        Folly @mechafatnick
                                        @mechafatnick
                                        Good suggesting.
                                        I am confident it should run one way or another.
                                        @phialek
                                        After you did the permission part.
                                        Can you then check if you can run the binary manually ?
                                        cd  /opt/retropie/emulators/supermodel-mechafatnick
                                        ./supermodel
                                        You should then get the help/usage output of the emulator and then we know the binary is working.
                                          phialek @Folly
                                          thanks for all the help
                                          the bin is not here:
                                          how do i get it there? i thought the script would do it on its own.
                                          and yes im using a pi4
                                            phialek @phialek
                                            its in the supplementary folder. i will change its location now.
                                            after changing the location daytona 2 is running. but super slow about 20% of original speed. is there a way to make it faster? the audio works great though.
