    Sega model 3 #segamodel3
    sega model 3supermodel
    304 Posts 23 Posters 107.7k Views
    • DTEAMD
      DTEAM @mechafatnick
      @mechafatnick said in Sega model 3 #segamodel3:
      Excitedly i've just found that the MPEG board emulation works well with an underclocked CPU, so we can have music in Scud race!
      Could it work also for Spikeout. We don't have the soundtrack with Spikeout. We only have the punch sound (action sounds)
      For game like Daytona USA 2, is there a way to preset game assigments like LINK ID to SINGLE and for some other games the country? Is It in Games.xml?
      @Folly, is It something to cover in the Script or it's on @mechafatnick side.
        mechafatnick @DTEAM
        @dteam I think it's actually coming from the ROM itself. WIthout redumping the simplest thing to do would be:
        -Work out all of the games affected
        -load the ROMs and set them to single machines
        -Have the install script copy the files created into the nvram folder at install.
        Then the emulator should find the nvram file to begin with and set it up correctly. Easy!
        I think Spikeout is another game that streams from the Mpeg board. This was frustrating as a lot of it is perfectly fine but it has some quite wicked slowdown in places. Definitely worth trying is with the DSB on and the CPU underclocked to a couple of different values
        DTEAMD FollyF 2 Replies Last reply Reply Quote 2
        • DTEAMD
          DTEAM @mechafatnick
          @Folly
          When I used your script. From the menu I had to select "help" (only option) and after that the install option appears with the help option below. Is this normal?
          BTW, at the end, it works. It's just a question about the menu itself.
          • FollyF
            Folly @DTEAM
            @dteam said in Sega model 3 #segamodel3:
            @Folly
            The module-script doesn't have a menu by itself.
            The menu is build up by the RetroPie-Setup.
            If you have a bad internet connection then you don't see install or update, for that matter.
            Could also be something different, will have a look at that.
            It tested it a couple of times. (btw I have RP-Setup 4.7.11)
            I could not find any problems at the moment.
            Would like to see a picture of the problem, can you post one ?
            • FollyF
              Folly @mechafatnick
              I read your post a couple of times.
              I think you mean :
              • collect all the NVRAMs of the games with the "correct" settings
              • add them into the NVRAM directory in the source code
              • when installing the emulator, you already have "good" NVRAM files from the source so no need of creating them in the first place
              Am I right ?
              Or do you mean something different ?
                mechafatnick
                Sorry that was round about way of saying it wasn't it?
                Yes that's exactly right. If we can gather the 'correct' nvram settings together in the source code we can just copy them into the emulators nvram folder at build time
                I've already erm tweaked a lot of mine :D
                • FollyF
                  Folly @mechafatnick
                  Perfect !
                  Good idea !
                  (but I have to accommodate the module-script for that)
                  We can do the same with the initial save-states idea from my post 104
                  Gather them too and add them in the Saves directory as an initial starter too speed things up.
                  (I have to change the module-script a bit, because it now searches in the root supermodel rom directory)
                    mechafatnick @Folly
                    @folly :D
                    FollyF 1 Reply Last reply Reply Quote 2
                    • FollyF
                      Folly @mechafatnick
                      @mechafatnick @DTEAM
                      I have made all the changes to the module-script.
                      I will have to do some tests tomorrow, when I think it ready I will push it to github.
                      Changes :
                      • moved the emulator binary to /opt/retropie/emulators/supermodel-mechafatnick
                      • reduced the run-lines, removing the path to the emulator binary, now ./supermodel
                      • removed the -no-dsb in the underclock run-lines
                      • it will preserve the changes made in Supermodel.ini when emulator is reinstalled
                      • it will move the NVRAM and Saves directories from the source code to /opt/retropie/emulators/supermodel-mechafatnick
                      • the initial save state uses now the %BASENAME%.st in /opt/retropie/emulators/supermodel-mechafatnick/Saves
                      An example of the initial save state is:
                      • you make a savestate from, for example, scud.zip, it will become scudau.st0
                      • then rename it to scud.st
                      • on next game boot scud.st will be loaded as initial state
                      So basically if all NVRAM.nv and all Saves.st files come in the source-code.
                      No settings will have to be made and we can skip the initial boot sequence, for the roms with a slow startup.
                      How does this sound ?
                        mechafatnick @Folly
                        @folly WIll people want to skip the initial boot sequence? That might be part of the fun. Hmm.
                        I've been thinking about your approach of putting everything into the ini and i think this is the right approach. Going forward I think we should:
                        -have two ( or three?) options in emulator.cfg:
                        supermodel (which will be at native res)
                        supermodel high-res (800 x 600)
                        supermodel very high-res (1024 x 768)
                        Then, we can handle the settings for the individual games in supermodel.ini (so whether to enable the DSB, how far to underclock CPU.) That way we'll have optimal settings for each game without the user having to alter anything. Sound good? I've made sections for each game in the ini file. I think i might be developing carpel tunnel...
                        EDIT: Ok! We can all chip in!
                        Add these lines to the global section of supermodel.ini (under your controls:)
                        ;Our non input settings...
                        EmulateDSB = 0
                        MusicVolume = 60
                        SoundVolume = 60
                        Stretch=1
                        VSync=0
                        Throttle=0
                        GameXMLFile= /opt/retropie/emulators/supermodel/bin/Config/Games.xml
                        New3DEngine=0
                        now, in emulators.cfg we only need to set the res in the command line (if you want to have different options)
                        Supermodel = "XINIT:/opt/retropie/emulators/supermodel/bin/supermodel %ROM%"
                        Now all we need to do, as a group, is come up with the optimal settings for each game as a group. I've made a start below (copy this into supermodel.ini - below the global section)
                        ;daytona 2 power edition
                            [ dayto2pe ]
                        ;daytona 2: battle to the edge
                            [ daytona2 ]
                          ;Dirt Devils (Export, Revision A)
                        	[dirtdvls]
                        ;Dirt Devils (Australia, Revision A)
                            [ dirtdvlsa ]
                        ;Dirt Devils (German)
                            [ dirtdvlsg ]
                        ;Dirt Devils (Japan, Revision A)
                        	[ dirtdvlsj ]
                        ;Emergency Call Ambulance (Export)
                            [ eca       ]
                        ;Emergency Call Ambulance (Japan)
                            [ ecaj      ]
                        ;Emergency Call Ambulance (US location test?)
                            [ ecap      ]
                        ;Emergency Call Ambulance (USA)
                            [ ecau      ]
                        ;Fighting Vipers 2 (Japan, Revision A)
                            [ fvipers2 ]
                        ;Fighting Vipers 2 (?)
                            [ fvipers2o ]
                        ;Get Bass (?)
                            [ getbass ]
                        ;Harley-Davidson and L.A. Riders (Revision B)
                            [ harley ]
                        ;Harley-Davidson and L.A. Riders (Revision A)
                            [ harleya ]
                        ;L.A. Machineguns: Rage of the Machines (Japan)
                            [ lamachin ]
                        ;Le Mans 24 (Revision B)
                            [ lemans24 ]
                         ;The Lost World (Japan, Revision A)
                            [ lostwsga ]
                        ;The Lost World (Original Revision)
                            [ lostwsgo ]
                        PowerPCFrequency = 30
                        ;Magical Truck Adventure (Japan)
                            [ magtruck ]
                        ;The Ocean Hunter (?)
                            [ oceanhun ]
                        ;Scud Race (Australia, Twin)
                            [ scud ]
                        PowerPCFrequency = 35
                        MusicVolume = 200
                        EmulateDSB = 1
                        ;Scud Race (Export, Twin)
                            [ scuda ]
                        MusicVolume = 200
                        EmulateDSB = 1
                        ;Scud Race (Japan, Deluxe)
                            [ scudj ]
                        MusicVolume = 200
                        EmulateDSB = 1
                        ;Scud Race Plus (Revision A)
                            [ scudplus ]
                        MusicVolume = 200
                        EmulateDSB = 1
                        ;Scud Race Plus (?)
                            [ scudplusa ]
                        MusicVolume = 200
                        EmulateDSB = 1
                        ;Ski Champ (Japan)
                            [ skichamp  ]
                        ;Spikeout Final Edition (?) - too slow on pi
                            [ spikeofe  ]
                        PowerPCFrequency = 45
                        EmulateDSB = 1
                        ;Spikeout (Revision C)
                            [ spikeout  ]
                        EmulateDSB = 1
                        ;Sega Rally 2 (?)
                            [ srally2   ]
                        ;Sega Rally 2 (Prototype)
                            [ srally2p  ]
                        ;Sega Rally 2 (Prototype Version A)
                            [ srally2pa ]
                        ;Sega Rally 2 (Deluxe)
                            [ srally2x  ]
                        ;Star Wars Trilogy Arcade (Revision A)
                            [ swtrilgy  ]
                        ;Star Wars Trilogy Arcade (?)	-not working on pi
                            [ swtrilgya ]
                            [ swtrilgyp ]
                        ;Virtua Fighter 3 (Revision D)
                            [ vf3       ]
                        PowerPCFrequency = 40
                        ;Virtua Fighter 3 (Revision A)
                            [ vf3a      ]
                        ;Virtua Fighter 3 (Revision C)
                            [ vf3c      ]
                        ;Virtua Fighter 3 Team Battle (?)
                            [ vf3tb     ]
                        ;Virtual On 2: Oratorio Tangram (Revision B)
                            [ von2      ]
                        ;Virtual On 2: Oratorio Tangram (Ver 5.4g)
                            [ von254g   ]
                        ;Virtual On 2: Oratorio Tangram (Revision A)
                            [ von2a     ]
                        ;Virtual On 2: Oratorio Tangram (?)
                            [ von2o     ]
                        ;Virtua Striker 2 (Step 2.0) - no special settings
                            [ vs2       ]
                        ;Virtua Striker 2 (Step 1.5) -  no special settings
                            [ vs215     ]
                        ;Virtua Striker 2 (Step 1.5, older) -  no special settings
                            [ vs215o    ]
                        ;Virtua Striker 2 '98 (Step 2.0) -  no special settings
                            [ vs298     ]
                        ;Virtua Striker 2 '98 (Step 1.5) - no special settings
                            [ vs29815   ]
                        ;Virtua Striker 2 '99 (?)
                            [ vs299     ]
                        ;Virtua Striker 2 '99 (Step 1.5)
                            [ vs29915   ]
                        ;Virtua Striker 2 '99 (Revision A)
                            [ vs299a    ]
                        ;Virtua Striker 2 '99 (Revision B)
                            [ vs299b    ]
                        ;Virtua Striker 2 '99.1 (Revision B)
                            [ vs2v991   ]
                        I'm gathering initialised nv ram too :D
                        FollyF Red_TrevR 5 Replies Last reply Reply Quote 0
                        • FollyF
                          Folly @mechafatnick
                          I will have to take some time to process this information.
                          Not for fun.
                          I think they do want it, especially for lemans24, because it will take 1 minute to get the first good screen and be playable.
                          I think there will be more.
                          We don't have to put all save states in there, only the ones with slow startup :D
                          • FollyF
                            Folly @mechafatnick
                            @mechafatnick
                            We should take it step by step.
                            Can you put your collected NVRAMs into the source code and add an empty Saves directory ?
                            Then I can test the module-script.
                            From there we can take more steps.
                            Agreed ?
                            Btw. adding the optimal game options into the Supermodel.ini sounds very good ;-)
                            • DTEAMD
                              DTEAM @Folly
                              @folly said in Sega model 3 #segamodel3:
                              Not for fun.
                              for the purist it can be frustrating to cut the scene at the beginning..
                              I don’t know. If you save after that scene and load your savestate the next time. It could be ok?
                              • FollyF
                                Folly @DTEAM
                                Not for fun.
                                Perhaps I am not clear, no scenes are cut.
                                Only the menu saying it is "single" etc. and booting the rom that produces strange screens etc.
                                DTEAMD 1 Reply Last reply Reply Quote 2
                                • DTEAMD
                                  DTEAM @Folly
                                  @folly
                                  Ok, now i understand. Good idea!
                                  If you do that, can you set the good country to switch japanese to english when it’s available.
                                  • FollyF
                                    Folly @DTEAM
                                    @folly
                                    We have to test, don't know.
                                    But I think that can work.
                                    • FollyF
                                      Folly @mechafatnick
                                      @mechafatnick
                                      I made a fork of the source-code.
                                      That way I can do some push-requests if needed.
                                      I am still learning with that part so perhaps we can learn from each other about :
                                      • syncing/fetching upstream
                                      • do pull requests
                                      • etc.
                                      • FollyF
                                        Folly @mechafatnick
                                        I just found that we don't need the NVRAMs if we don't want to.
                                        I made some save-states and booted with them, removing the NVRAMs before the boot made them boot directly without the need of a nvram file.
                                        Something to take into account.
                                          mechafatnick
                                          That's good to know! worth noting that save states are 30mb each though so i'm not sure we should deploy them when we don't have to (i've used one with Skichamp though, to get round an annoying drive board error)
                                          I've updated my repo with the Nvram files and Save state i've created so far + my ini file with my collection of game-related settings (I use Visual Studio Code for source control if that helps)
                                          DTEAMD FollyF 2 Replies Last reply Reply Quote 1
                                          • DTEAMD
                                            DTEAM @mechafatnick
                                            @mechafatnick @Folly
                                            Maybe you should create a new thread like we did for Development of module-script generator for lr-mess and mame standalone . Like this, you could start with a small crash cours on how to install and use the script and continue with showing where you are in the developpement process.
                                            Because, right now, you don't have the control of the first post in this thread.
                                            Do you think it's a good idea?
