    (GUIDE) How to add Super Mario 64 PC to Retropie(Pi4 and Pi3b)
    mariomario 64nintendo 64sm64sm64pc
    150 Posts 23 Posters 66.5k Views
      pjft
      It's probably /home/pi/sm64ex/build/us_pc/sm64.us.f3dex2e.arm for the nightly build.
      • Stuart2773S
        Stuart2773 @Krakatoa
        @Krakatoa said in (GUIDE) How to add Super Mario 64 PC to Retropie(Pi4 and Pi3b):
        @Stuart2773 said in (GUIDE) How to add Super Mario 64 PC to Retropie(Pi4 and Pi3b):
        line 2: /home/pi/sm64pc/build/us_pc/sm64.us.f3dex2e.arm
        Does the file "sm64.us.f3dex2e.arm" exist in the path? also is the path correct?
        @pjft said in (GUIDE) How to add Super Mario 64 PC to Retropie(Pi4 and Pi3b):
        im not sure what i need to do or where to check :(
        ? 2 Replies Last reply Reply Quote 0
          A Former User @Stuart2773
          @Stuart2773
          It is in /home/pi/sm64ex/build/us_pc
          Stuart2773S 1 Reply Last reply Reply Quote 0
            @Stuart2773
            Create a .sh file with this inside:
            #!/bin/bash
            /home/pi/sm64ex/build/us_pc/sm64.us.f3dex2e.arm %U
            Put it in /home/pi/RetroPie/ports
              A Former User
              @skj
              Are the mods working? Just asking
              • Stuart2773S
                Stuart2773 @A Former User
                @Luddo183 said in (GUIDE) How to add Super Mario 64 PC to Retropie(Pi4 and Pi3b):
                @Stuart2773
                i dont have that folder "build/us_pc"
                would i need to change steps 3 & 4 to sm64ex instead of sm64pc ?
                  @Stuart2773
                  Then what do you you have in the build folder
                  • Stuart2773S
                    @Stuart2773
                    there is no folder called build :(
                    im totally confused by the setup steps to install the packs,
                      @Stuart2773
                      What did you do and where are you looking
                        @Stuart2773
                        Yes, you should change steps 3 and 4 to sm64ex instead of sm64pc
                        • Stuart2773S
                          Stuart2773
                          @Luddo183
                          is this the correct steps with the correct folder names:-
                          sudo apt install build-essential git python3 libaudiofile-dev libglew-dev libglfw3-dev libusb-1.0.0 libsdl2-dev
                          git clone --single-branch --branch nightly https://github.com/sm64pc/sm64ex.git
                          or
                          git clone --single-branch --branch nightly https://github.com/sm64ex/sm64ex.git
                          cp RetroPie/roms/n64/Mario.z64 sm64ex/baserom.us.z64
                          cd sm64ex
                          make VERSION=us TARGET_RPI=1 -j4 EXTERNAL_DATA=1
                          rm -rf build
                          #!/bin/bash
                            pjft @Stuart2773
                            @Stuart2773
                            Whether step 2 and 4 are correct or not (because of the "us" part) only depends on your version of the ROM, but you'll get an error if that's not right.
                            • Stuart2773S
                              Stuart2773 @pjft
                              @Stuart2773
                              the rom im using is Super Mario 64 (U) [!].z64
                              (which i renamed to Mario.z64)
                                pjft
                                One note: it seems that the nightly build is the one that is messed up in terms of speed.
                                The original one (the one you don't use mods in) runs fine at the right speed!
                                Stuart2773S A 2 Replies Last reply Reply Quote 0
                                • Stuart2773S
                                  Stuart2773 @pjft
                                  After step 4, delete the build folder:
                                  rm -rf build
                                  Copy the content of the patch to the folder.
                                  Then run
                                  make VERSION=ROM_REGION TARGET_RPI=1 -j4 EXTERNAL_DATA=1
                                  where ROM_REGION is the region of your ROM, as in the first time you compiled it.
                                  thats where im getting stuck with the content of the patch folder ???
                                  the texture pack i download is called version1.1hotfix
                                    pjft @Stuart2773
                                    @Stuart2773 I'm sorry. Different patches may have different instructions - I don't know.
                                    I shared the instructions for the patch corresponding to one of the videos you shared, copied from the discord channel linked in that video - just because that was the one I also used.
                                    What are the instructions where you download that patch from? Do they have a discord or forum? That might shed some light for that specific pack.
                                    The content of the patch, in my case, is the content of the uncompressed zip file. I also ran into one which was a .pak file, but I had no idea what to do with it and, honestly, didn't bother much to follow up on it.
                                    Hope these help somewhat.
                                    S Stuart2773S 2 Replies Last reply Reply Quote 0
                                      pjft
                                      A final note before logging off: if you want to use a patch that requires the nightly build, after checking out the code enter the folder and run
                                      git checkout 685efc81c
                                      which is the last good commit before the frame rate issues.
                                      Hope it helps.
                                        AdamBeGood @pjft
                                        This post is deleted!
                                          AdamBeGood
                                          Which texture pack do people recommend? I imagine I will manage to make a pig's ear of installing whichever one I go for, might as well make sure it is a recommended one.
                                          I managed to get this working unmodded without consulting the forum with issues, which is a first for me.... I am sure I won't be so lucky with the mod.
                                            skj @pjft
                                            What patch file did you use? What was the name of it? Ive seen a few on discord but unsure wich one to get.
