    (GUIDE) How to add Super Mario 64 PC to Retropie(Pi4 and Pi3b)
    mariomario 64nintendo 64sm64sm64pc
    150 Posts 23 Posters 72.6k Views
      A Former User @zerojay
      @zerojay
      Thanks man. I really wanted to try making a scriptmodule for it, but I've been away and I have zero knowledge there. Anyway thanks. I put that up in the instructions.
        Tyberkid
        @luddo183 does this work for rpi 3b? (not 3b+) also could it work on the 0 w?
        ? 2 Replies Last reply Reply Quote 0
          A Former User @Tyberkid
          @tyberkid
          No. Sorry about getting back late, but only the 3B+ and 4 can run it.
            @tyberkid
            But maybe the 3B can run it, I'm not sure
            Stuart2773S 1 Reply Last reply Reply Quote 0
            • Stuart2773S
              Stuart2773 @A Former User
              Has anyone been able to get this running on pi4 with the new render96 v2.1 textures ?
                burt111 @zerojay
                @zerojay i would love if you added external data support this runs well on my pi4 2gb with piboy dmg case requires xboxdrv and a script involving the controls
                  Speedsnipe
                  Could someone please elaborate on how you get the controls working on the PiBoy DMG, this guy on YouTube seems to have it working but doesn't mention it, he just linked this page in his description.
                  • DolphinCubeD
                    DolphinCube
                    anyone figured out how to add this mod into SM64ex? It adds sonic the hedgehog into it. I have no idea why it isnt working (not creating an executable for some reason)
                    https://sm64pc.info/forum/viewtopic.php?f=13&t=101
                      A Former User @DolphinCube
                      @theautisticgamer
                      Maybe you made a mistake somewhere? Go check your steps and see if you did anything wrong.
                      DolphinCubeD 1 Reply Last reply Reply Quote 0
                      • DolphinCubeD
                        DolphinCube @A Former User
                        @luddo183 well it does have a patch file and it says to put it in the "Patches" folder. I created one but It didnt do anything at all
                          @theautisticgamer
                          Hmmm.... how are you building it?
                          • DolphinCubeD
                            @luddo183 here is what I did
                            Step 1: Get the essental files for configuring
                            Step 2: Get SM64ex
                            Step 3: Build it then delete everything in the build folder
                            Step 4: Drag and drop everything to the SM64EX root folder
                            Step 5: Build it again and everything starts to show up EXECPT for the executable
                            Please help me!
                            Oh! And here are the folders It comes with:
                            -levels
                            -sound
                            -textures
                            and a patch file also. I think something is in the wrong place
                              @theautisticgamer
                              2 things:
                              Did you run
                              rm -rf build
                              and did you run it with external data 1?
                                sglueckspilz @A Former User
                                Hey there,
                                maybe you have a Tipp for me.
                                I am playing arround with my PI 4.
                                I installed Retropie 4.7. and updated to 4.7.9 yesterday.
                                I have installed Mario64 in default Emulator.
                                Running good.
                                The I have installed the SM64PC Version.
                                Also is running good.
                                Then I haved installed die SM64EX Version with sm64redrawn-master
                                I have tried in different ways.
                                Also with - git checkout 685efc81c
                                Mario is starting, but it is unplayable slow. Audio is also lagging.
                                Have you any tipps for me? Have I forgottend something. I have read some post, that I have to enable opengl options???
                                I have done:
                                sudo apt install build-essential git python3 libaudiofile-dev libglew-dev libglfw3-dev libusb-1.0.0 libsdl2-dev
                                git clone --single-branch --branch nightly https://github.com/sm64pc/sm64ex.git
                                Copy Mario Rom + redawn package to
                                <pre>sm64ex
                                ┗ build
                                ┗ us_pc
                                ┗ res
                                ┗ gfx
                                ┣ actors
                                ┣ levels
                                ┗ textures</pre>
                                rm -rf build
                                And startet the Game with
                                #!/bin/bash
                                /home/pi/sm64ex/build/<ROM=REGION>_pc/sm64.us.f3dex2e.arm %U
                                Do you know why is the game so slow and the normal PC Version running good?
                                Thanks you!
                                  A Former User @sglueckspilz
                                  @sglueckspilz
                                  It might be OpenGL but otherwise I see no problems.
                                    @sglueckspilz
                                    Actually @Krakatoa showed these instructions for sm64 redrawn:
                                    Build sm64ex with the sm64redrawn texture pack - Assumes you are building us versions
                                    Step 1: Run this command
                                    Sudo apt install build-essential git python3 libaudiofile-dev libglew-dev libglfw3-dev libusb-1.0.0 libsdl2-dev
                                    Step 2: Git clone sm64ex
                                    Step 3: Take your .z64 file of Super Mario 64 and put it in the files. Note change the code to your rom name in your roms directory.
                                    cp RetroPie/roms/n64/Mario.z64 sm64ex/baserom.us.z64
                                    Step 4: Build
                                    cd sm64ex
                                    make VERSION=us TARGET_RPI=1 -j4
                                    Step 5: rm -rf build
                                    Step 6: Create a build folder and a gfx and res folder under the sm64ex folder
                                    build\us_pc\res\gfx
                                    <pre>sm64ex
                                    ┗ build
                                    ┗ us_pc
                                    ┗ res
                                    ┗ gfx
                                    ┣ actors
                                    ┣ levels
                                    ┗ textures</pre>
                                    <b>(Master Clone)</b>
                                    If you git clone the master you can just copy the gfx folder into your res directory and that's it.
                                    Step 7: download the zip package sm64redrawn sm64redrawn and unzip
                                    step 8: copy the contents of the gfx folder and alt folder from the extracted sm64redrawn zip into the res folder created in step 6 (alt folder contains icon updates etc.)
                                    step 9: cd sm64ex
                                    Step 10:
                                    make VERSION=us TARGET_RPI=1 -j4 EXTERNAL_DATA=1
                                    Step 9: Create a .sh file, name it sm64pc.sh, and put the following code in it:
                                    #!/bin/bash
                                    /home/pi/sm64ex/build/us_pc/sm64.us.f3dex2e.arm %U
                                    Step 10: Move the .sh file into /home/pi/RetroPie/roms/ports
                                      @luddo183
                                      Thanks!
                                      I have rebuild again. This it is running a little little better now. mmmhh
                                      I noticed if I switch to windowed mo de, the game is running already in normal speed.
                                      But then it is only in the left corner. 640*480 on an Full HD Screen :-(
                                      Maybe I will setup the pi 4 complety new.
                                      Are there some checks that I can do?
                                      Thank you
                                        @sglueckspilz
                                        For what?
                                        • vic-viper-001V
                                          vic-viper-001
                                          I usually fail at pi-related installations, but managed to get this working on my first try. Major kudos for these instructions! I do have one question however...
                                          I have splashscreens for everything in my Retropie setup. It's the splashscreens from this post:
                                          https://retropie.org.uk/forum/topic/4611/runcommand-system-splashscreens
                                          Has anybody found a way to change this initial screen:
                                          Into something like this:
                                          • retropieuser555R
                                            retropieuser555
                                            So I recently got ahold of the Retroflag GPI case which runs a pi 0 w. Out of sheer curiosity, if I attempted to build this, will it just fail outright? Has anyone tried it yet (granted I expect a slow framerate but I'm curious how slow)
                                            Pi 5 4GB
