    (GUIDE) How to add Super Mario 64 PC to Retropie(Pi4 and Pi3b)
    mariomario 64nintendo 64sm64sm64pc
    150 Posts 23 Posters 66.5k Views
      AdamBeGood @pjft
      @pjft said in (GUIDE) How to add Super Mario 64 PC to Retropie(Pi4 and Pi3b):
      I did it for SGI, just follow their instructions, adapting to the ones in the first post in this thread. Step 1 is the different one.
      1. Clone the nightly sm64ex git using git clone --single-branch --branch nightly https://github.com/sm64pc/sm64ex.git
      2. Place your base rom into it
      3. Visit the directory using cd sm64ex
      4. Build it once using make
      5. Delete the build folder
      6. Download the file in #download and drag what's inside into the sm64ex folder (press replace all)
      7. build it using make EXTERNAL_DATA=1
      I tried to follow these instruction but between steps 3 and 4 I also checked out the correct version to avoid the speed issue.
      My texture pack is just 'actors', 'levels' and 'textures' directories (SM64Redrawn - https://github.com/TechieAndroid/sm64redrawn). So that is what I copied over in step 6.
      The sm64.ex file is saying there is no such file or directory, which is fair as there is only level_rules.mk in the us_pc directory. Any thoughts on where I may have gone wrong here? I'm happy to provide more information. Thank you.
      KrakatoaK 1 Reply Last reply Reply Quote 0
      • KrakatoaK
        Krakatoa @AdamBeGood
        @AdamBeGood it wont work with that texture pack, the images are too large so it fails to compile, which results in the file not being generated. Use the texture pack from discord.
        A S 2 Replies Last reply Reply Quote 1
          AdamBeGood @Krakatoa
          @Krakatoa But aside from that, the method seems okay? I see from an earlier post that you used SM64Redrawn - am I looking for a version of that on the Discord or do I need to consider a different pack?
            AdamBeGood
            Also, on my normal build of SM64PC, I am having trouble with the controls.
            When I plug my Xbox One Controller in, Mario defaults to ducking - I can get around this if I move straight after a jump though.
            If I have the keyboard plugged in, and then plug the Controller in, that stops Shift working - so I can no longer get into the Controller Config menu. Has anyone experienced anything similar?
            I'm keen to get this to work, it looks amazing even without texture packs (thanks to everyone who has contributed to this thread, it's great).
            Edit: I used the Nightly version instead of the one at the top of the thread, and selected this version:
            git checkout 685efc81c
            My controller is all good now, no problems anymore.
              skj @Krakatoa
              This post is deleted!
              • Stuart2773S
                Stuart2773 @pjft
                @Stuart2773 I'm sorry. Different patches may have different instructions - I don't know.
                I shared the instructions for the patch corresponding to one of the videos you shared, copied from the discord channel linked in that video - just because that was the one I also used.
                What are the instructions where you download that patch from? Do they have a discord or forum? That might shed some light for that specific pack.
                The content of the patch, in my case, is the content of the uncompressed zip file. I also ran into one which was a .pak file, but I had no idea what to do with it and, honestly, didn't bother much to follow up on it.
                Hope these help somewhat.
                thats where i got the packs from :-
                https://discord.com/invite/QNjJAFH
                https://discord.com/channels/727721825953513472/728264742736494603
                  pjft @Stuart2773
                  @Stuart2773 That's the one I installed as well.
                  • retropieuser555R
                    retropieuser555
                    I installed the HD Luigi pack. I cloned the directory, saved the textures and sound files where they needed to be, ran the apply_patch.sh with HD_luigi.sh then ran make. Works fine for me 👍
                    Pi 5 4GB
                    • Stuart2773S
                      Stuart2773
                      ok finally , ive managed to install the sm64redrawn pack into the main game :)
                      know i need to try and get the game to look like this:-
                      @skj said in (GUIDE) How to add Super Mario 64 PC to Retropie(Pi4 and Pi3b):
                      KrakatoaK 1 Reply Last reply Reply Quote 1
                      • KrakatoaK
                        Krakatoa @Stuart2773
                        @Stuart2773 can you provide instructions? I’d like to use that pack.
                        Stuart2773S 1 Reply Last reply Reply Quote 1
                        • Stuart2773S
                          Stuart2773 @Krakatoa
                          @Krakatoa said in (GUIDE) How to add Super Mario 64 PC to Retropie(Pi4 and Pi3b):
                          ok this is my WORK-AROUND !!!
                          first of all i downloaded this:- https://github.com/TechieAndroid/sm64redrawn/archive/master.zip and extacted the folder to my desktop
                          on my pi4b 4gb i already had the sm64pc installed (without texture packs)
                          using putty :-
                          1. sudo apt install build-essential git python3 libaudiofile-dev libglew-dev libglfw3-dev libusb-1.0.0 libsdl2-dev
                          2. git clone -b nightly https://github.com/sm64pc/sm64ex.git
                          3. cp RetroPie/roms/n64/Mario.z64 sm64ex/baserom.us.z64
                          4. cd sm64ex
                          now on WinSCP
                          in the folder "sm64ex" i noticed i did not have a "build" folder so i copided the "build" folder from "sm64pc" to "sm64ex"
                          and within that build/us_pc folder i created a directory call "res"
                          now in the "res" folder i copied the "gfx" folder that i extracted from the "sm64redrawn-master" on my desktop
                          1. make VERSION=us TARGET_RPI=1 -j4 EXTERNAL_DATA=1
                          2. create the sm64ex.sh file in /home/pi/RetroPie/roms/ports
                            #!/bin/bash
                            /home/pi/sm64ex/build/us_pc/sm64.us.f3dex2e.arm %U
                          then restarted the pi :)
                          • KrakatoaK
                            @Stuart2773 Thank you.
                            did you only use the gfx folder in the zip? I think the other folder is alternative gfx's
                            Also, anyone know how to open the custom menu? It mentions it in the readme for sm64ex.
                            Stuart2773S 1 Reply Last reply Reply Quote 0
                            • Stuart2773S
                              yes i only used the gfx folder but you can copy the other alternative folder there too if you wish
                              • KrakatoaK
                                Krakatoa
                                Build sm64ex with the sm64redrawn texture pack - Assumes you are building us versions
                                Step 1: Run this command
                                Sudo apt install build-essential git python3 libaudiofile-dev libglew-dev libglfw3-dev libusb-1.0.0  libsdl2-dev
                                Step 2: Git clone sm64ex
                                Step 3: Take your .z64 file of Super Mario 64 and put it in the files. Note change the code to your rom name in your roms directory.
                                Step 4: Build
                                cd sm64ex
                                Step 5: rm -rf build
                                Step 6: Create a build folder and a gfx and res folder under the sm64ex folder
                                build\us_pc\res\gfx
                                <pre>sm64ex
                                ┗ build
                                ┗ us_pc
                                ┗ res
                                ┗ gfx
                                ┣ actors
                                ┣ levels
                                ┗ textures</pre>
                                <b>(Master Clone)</b>
                                If you git clone the master you can just copy the gfx folder into your res directory and that's it.
                                Step 7: download the zip package sm64redrawn sm64redrawn and unzip
                                step 8: copy the contents of the gfx folder and alt folder from the extracted sm64redrawn zip into the res folder created in step 6 (alt folder contains icon updates etc.)
                                step 9: cd sm64ex
                                Step 8:
                                Step 9: Create a .sh file, name it sm64pc.sh, and put the following code in it:
                                #!/bin/bash
                                Step 10: Move the .sh file into /home/pi/RetroPie/roms/ports
                                Step 11: Play the game as you imagined it was in the 90
                                  @Krakatoa Can you make it totally noob friendly and be clear when you say "Step 4: Build" please?
                                  Also when you say "create a build folder", is that totally empty (in terms of files) aside from the sm64redrawn files? I assume it is but just want to be sure as Stuart2773 mentioned copying an existing build folder with files within it.
                                  One other thing I've noticed - Step 4 is region-free, Step 8 is US.
                                  • KrakatoaK
                                    @AdamBeGood Sorry I forgot that step. fixed it now.
                                      @Krakatoa I deleted my previous directory, so I was starting from scratch. I am sure I followed this to the letter but mine has built again without the textures. I don't know what I've done wrong.
                                      The textures are still in the build/gfx/res folder, they are sitting there but for some reason they don't appear to be there when I play.
                                      It is right that the SM64Redrawn folders sit under build\gfx\res\actors and so on, isn't it? I think this is going to be where the problem lies. I moved the actors, levels and templates directories to sit under build\gfx\res. I amalgamated the contents of the gfx and alt versions of those directories also. Looking at what Stuart did, that seems quite different - and there isn't usually room for interpretation in these things.
                                      • KrakatoaK
                                        @AdamBeGood It could be an error on my end. I typed it up from memory after playing around with it this morning.
                                          @Krakatoa There is quite a bit of difference and I am very unsure where to put those files. Thank you very much for the guide though - I feel like I am near to it.
                                          Stuart2773 has those files in build/us_pc/res/gfx (and presumably build/us_pc/res/alt), while your guide has them in build/gfx/res.
                                          I am also slightly confused as to whether I copy in a previously made build folder, or if there should only be the SM64Redrawn files in there when I do the final build (I hope that makes sense as a sentence). The instructions suggest the build folder is blank at the point you copy in the SM64Redrawn files but I am pretty sure it shouldn't be.
                                          I guess I will try to do this again, I'll have another punt once work is finished.
                                          • Stuart2773S
                                            Stuart2773 @AdamBeGood
                                            @AdamBeGood said in (GUIDE) How to add Super Mario 64 PC to Retropie(Pi4 and Pi3b):
                                            The only reason i copied the existing build folder was that mine was missing when i complied. As for copying the files to the res folder i just followed the instructions that was in the readme.md file that came with the sm64redrawn.zip
