    Guide: Advanced Controller Mappings
    joystickcontrollermappingxboxdrvscummvm
    626 Posts 35 Posters 564.0k Views
      MadHorse
      Doh!, me dumb, you are absolutely right, ABS_RZis wrong, the correct one is ABS_RX. Now the right stick is working correctly, the strange thing is that the left stick still acting strange making the pointer disappear. Adding --ui-axismap x1=void,y1=void at the bottom of my configuration doesen't change anything.
      Any other advise ?
        mediamogul Global Moderator @MadHorse
        @MadHorse
        That is strange. So, the left stick makes the cursor disappear when nudged? Does it disappear for good? Since, you've already tried voiding it, you could try mapping it to an unused key to see how it behaves. Something like --ui-axismap x1=KEY_HOME:KEY_HOME,y1=KEY_HOME would be worth trying. Also, not mapping the left stick at all under --evdev-absmap might give you the desired effect as well.
          MadHorse
          @mediamogul
          Thank you for your fast reply, it seems to disappear when i move the left stick and reappear always at the top left when i move back to center.
          Yes you are right, if i map the left stick to --ui-axismap x1=KEY_LEFT:KEY_RIGHT,y1=KEY_DOWN:KEY_UP stop acting strange and work like the arrow keys.
          You are also right, if i don't map the left stick under --evdev-absmap it disable the left stick.
          I will use one of the solution as a workaround but i will try to investigate futher on why is acting like this.
          Thank you very much
            MadHorse
            Hello again,
            i have another questions about joypad configuration for individual emulators.
            For emulators that start using a shell script like scummVM and amiga it's easy, but for others emulators like for example jzintv what should i do?
            The emulators.cfg is
            jzintv="/opt/retropie/emulators/jzintv/bin/jzintv -p /home/pi/RetroPie/BIOS -q %ROM%"
            default="jzintv"
            I should create a shell script like scummVM and change emulators.cfg to point the the script or there is an easy way ?
            Thank you for any help.
              @MadHorse
              There's really no one right answer to that. Sometimes you can just add the xboxdrv command to the emulators.cfg and others by pointing to a shell script.
                MadHorse
                Hi all,
                i'm just making some test but it's seems to work well.
                Create a runcommand-onstart.sh
                nano /opt/retropie/configs/all/runcommand-onstart.sh
                the script will contain a casestatement where it will execute the xboxdrv configuration according to the emulator launched.
                The following is just an example, everyone should change the configuration based on their own controller
                #!/bin/sh
                case $1 in
                        fba)
                        daphne)
                        scummvm)
                                sudo killall >/dev/null xboxdrv
                                /opt/retropie/supplementary/xboxdrv/bin/xboxdrv \
                                        >/dev/null \
                                        --evdev /dev/input/event2 \
                                        --silent \
                                        --detach-kernel-driver \
                                        --force-feedback \
                                        --mimic-xpad \
                                        --dpad-as-button \
                                        --evdev-absmap ABS_X=x1,ABS_Y=y1,ABS_Z=x2,ABS_RX=y2 \
                                        --evdev-keymap KEY_#302=a,KEY_#301=b,BTN_DEAD=x,KEY_#300=y,BTN_THUMB=tl,BTN_THUMB2=tr,BTN_BASE5=lb,BTN_BASE6=rb,BTN_TRIGGER=back,KEY_#720=guide,BTN_TOP=start,BTN_TOP2=du,BTN_PINKIE=dr,BTN_BASE=dd,BTN_BASE2=dl,BTN_BASE3=lt,BTN_BASE4=rt \
                                        --calibration x1=-32767:0:32767,y1=-32767:0:32767,x2=-32767:0:32767,y2=-32767:0:32767 \
                                        --axismap -Y1=Y1,-Y2=Y2 \
                                        --ui-axismap x1=REL_X:10,y1=REL_Y:10 \
                                        --ui-buttonmap b=BTN_LEFT,a=BTN_RIGHT,start=KEY_F5 \
                                        --ui-buttonmap guide=void,x=void,y=void,lb=void,rb=void,tl=void,tr=void,lt=void,rt=void,back=void \
                                        --ui-axismap x2=void \
                        intellivision)
                                        >/dev/null \
                                        --force-feedback \
                                        --dpad-as-button \
                                        --trigger-as-button \
                                        --deadzone-trigger 15% \
                                        --deadzone 4000 \
                                        --silent \
                                        --evdev-absmap ABS_X=x1,ABS_Y=y1,ABS_Z=x2,ABS_RX=y2,ABS_HAT0X=dpad_x,ABS_HAT0Y=dpad_y \
                                        --evdev-keymap BTN_THUMB2=a,BTN_THUMB=b,BTN_TOP=x,BTN_TRIGGER=y,BTN_BASE3=back,BTN_BASE4=start,BTN_TOP2=lb,BTN_PINKIE=rb,BTN_BASE5=tl,BTN_BASE6=tr,BTN_BASE=lt,BTN_BASE2=rt \
                                        --ui-axismap X1=KEY_S:KEY_D,Y1=KEY_E:KEY_X,X2=KEY_1:KEY_2,Y2=KEY_3:KEY_4,lt+X2=KEY_5:KEY_6,lt+Y2=KEY_7:KEY_8,rt+X2=KEY_9:KEY_0,rt+Y2=KEY_MINUS:KEY_EQUAL \
                                        --ui-buttonmap a=KEY_LEFTSHIFT,b=KEY_HOME,x=KEY_LEFTCTRL,y=KEY_LEFTALT,lb=KEY_F1,rb=KEY_F12,lt=KEY_HOME,rt=KEY_HOME,tl=KEY_HOME,tr=KEY_HOME,du=KEY_E,dd=KEY_X,dl=KEY_S,dr=KEY_D,start=KEY_PAUSE \
                                        --ui-buttonmap back=cycle-key:KEY_F6:KEY_F5 \
                                        --ui-buttonmap guide=void \
                esac
                Make the script exacutable
                sudo chmod +x /opt/retropie/configs/all/runcommand-onstart.sh
                Now we need to create the onend script to kill the xboxdrv, otherwise when we exit the emulator the driver remain active
                nano /opt/retropie/configs/all/runcommand-onend.sh
                #!/bin/sh
                sudo chmod +x /opt/retropie/configs/all/runcommand-onend.sh
                I have to do some more test, and maybe create a more complex script with a base configuration for all the emulators and the just the different configuration specific for every emulators.
                Also i think it will be possible to create a specific configuration not only for the emulator used but also for the games.
                Will share any new info, maybe next week.
                Now i need to rest, it was a very long day.
                mediamogulM 1 Reply Last reply Reply Quote 3
                  @MadHorse
                  What a great idea! It's a mark improvement over editing each run command. I look forward to trying this out later.
                    Pyjamarama
                    You guys are making wonders here. You take ES to next level of functionality
                      MadHorse
                      Hello everybody,
                      i made some more test and it seems to work very well.
                      All the xboxdrv parameters are assigned to variables, this way the case statement is more readable.
                      Create the runcommand-onstart.sh
                      This is my configuration used for test
                      #!/bin/sh
                      ## Uncomment one or all of the following if you need to find some information about the emulator or roms
                      ## Name of the emulator
                      #echo $1 >> /dev/shm/runcommand.log
                      ## Name of the software used for running the emulation
                      #echo $2 >> /dev/shm/runcommand.log
                      ## Name of the rom
                      #echo $3 >> /dev/shm/runcommand.log
                      ##Executed command line
                      #echo $4 >> /dev/shm/runcommand.log
                      ### The FUN begins
                      #Get ROM name striping full path
                      rom="${3##*/}"
                      ### Set variables for your joypad and emulator
                      ### Basic Configuraions - Standard controller mappings
                      basicPS3="/opt/retropie/supplementary/xboxdrv/bin/xboxdrv >/dev/null \
                      	--silent \
                      	--force-feedback \
                      	--mimic-xpad \
                      	--dpad-as-button \
                      	--evdev-keymap KEY_#302=a,KEY_#301=b,BTN_DEAD=x,KEY_#300=y,BTN_THUMB=tl,BTN_THUMB2=tr,BTN_BASE5=lb,BTN_BASE6=rb,BTN_BASE3=lt,BTN_BASE4=rt,BTN_TRIGGER=back,BTN_TOP=start,BTN_SOUTH=guide,BTN_TOP2=du,BTN_PINKIE=dr,BTN_BASE=dd,BTN_BASE2=dl
                      	--calibration x1=-32767:0:32767,y1=-32767:0:32767,x2=-32767:0:32767,y2=-32767:0:32767"
                      ### Extended Configurations
                      ### Specific emulator configuration or any other parameters you will need only for some emulators
                      scummVM="--axismap -Y1=Y1,-Y2=Y2 \
                      	--ui-buttonmap a=BTN_LEFT,b=BTN_RIGHT,start=KEY_F5,back=KEY_ESC \
                      	--ui-axismap x2=void"
                      amiga="--axismap -Y1=Y1,-Y2=Y2 \
                      	--ui-axismap x2=REL_X:1,y2=REL_Y:1 \
                      	--ui-axismap x1=KEY_LEFT:KEY_RIGHT,y1=KEY_DOWN:KEY_UP \
                      	--ui-buttonmap du=KEY_UP,dd=KEY_DOWN,dl=KEY_LEFT,dr=KEY_RIGHT \
                      	--ui-buttonmap lt=BTN_LEFT,rt=BTN_RIGHT,start=KEY_ESC,back=KEY_LEFTCTRL,y=KEY_SPACE,a=KEY_LEFTCTRL,b=KEY_LEFTALT,x=KEY_LEFTSHIFT \
                      	--ui-buttonmap guide=void,tl=void,lt=void,rt=void,back=void \
                      fourway="--four-way-restrictor"
                      invert="--ui-buttonmap du=KEY_DOWN,dd=KEY_UP"
                      ### Kill Command
                      xboxkill="sudo killall >/dev/null xboxdrv"
                      ### Execute the driver with the configuration you need
                      # $1 is the name of the emulation, not the name of the software used
                      # it is intellivision not jzintv
                      case $1 in
                      	mame-libretro)
                      	fba)
                      		case $rom in
                      			"amidar.zip"|"atetris.zip"|"puckman.zip") # Configuration used only for these ROMs
                      				$xboxkill
                      				joycommand="$basicPS3 $fourway &"
                      				eval $joycommand
                      			*) # Configuration for every other ROMs on this emulator
                      				$xboxkill
                      				joycommand="$basicPS3 &"
                      				eval $joycommand
                      		esac
                      	daphne)
                      	scummvm)
                      		$xboxkill
                      		joycommand="$basicPS3 $scummVM &"
                      		eval $joycommand
                      	amiga)
                      		$xboxkill
                      		joycommand="$basicPS3 $amiga &"
                      		eval $joycommand
                      	intellivision)
                      esac
                      We assign to the joycommand variable, the list of variables that contains the parameters we need for example joycommand="BasicVAR var1 var2 var3 $". The Basic variables must be the first, and & must be the last.
                      Make the script executable
                      For some emulators we could face some problem, i have a PS3 controller recognized as input device event2, when i execute xboxdrv the controller is recognized as input device event3. The system now see 2 controller device, the PS3 as controller with id 0 and an Xbox360 controller with id 1, for the emulator you are now using the controller for player2 and this will cause some problem, for example you can only start a 2 players game, you can't quit the emulation pushing select+start. To solve the problem we have to specify on retroarch.cfg the id of the controller used by player1 and player2.
                      This is the configuration for Final Burn Alpha, we have to add input_playerx_joypad_index = "x" for every controller between input_remapping_directory = "/opt/retropie/configs/fba/" and #include "/opt/retropie/configs/all/retroarch.cfg" where the first X is the player number, and the secon X is the controller ID
                      input_player1_joypad_index = "1"
                      input_player2_joypad_index = "0"
                      input_player2_analog_dpad_mode = 1
                      If you want this configuration for every retroarch emulators, you have to edit nano /opt/retropie/configs/all/retroarch.cfg
                      Now we need to kill xboxdrv when we exit from the emulator, we do this with the onend script
                      #!/bin/sh
                      and make it executable
                      Sorry for my english, let me know if something is unclear, i will try to explain better, and if you are trying it, please let me know if it's working.
                      Hope you find it usefull.
                      @mediamogul
                      If you think it could be of help, maybe you could add it to the first post.
                      mediamogulM meleuM J 4 Replies Last reply Reply Quote 3
                        @MadHorse
                        This is fantastic! I added an introduction and link in section 3 that directs right to your post. This way you can maintain control if anything needs to be changed or you think of any other improvements. Again, this is really streets ahead!
                          meleu @MadHorse
                          @MadHorse just sharing a runcommand-onstart.sh info to simplify your script:
                          All the error messages from these scripts (onstart and onend) will be logged in runcommand.log. If you want to log something more you just have to redirect the output to the standard error. This way:
                          echo "message to log" >&2
                          I've just updated the runcommand wiki with this info. ;-)
                            meleu @MadHorse
                            @MadHorse
                            Oh! I've just realized that you suggest the use of runcommand.log to get infos about emulator/roms. But all these infos are already available at /dev/shm/runcommand.info.
                            This file has the following structure:
                            • line #1 - the system (eg: atari2600, nes, snes, megadrive, fba, etc).
                            • line #2 - the emulator (eg: lr-stella, lr-fceumm, lr-picodrive, pifba, etc).
                            • line #3 - the full path to the rom file.
                            • line #4 - the full command line used to launch the emulator.
                            To get a specific line from a file I'm used to use this sed trick:
                            sed '1!d' file # to get the 1st line
                            sed '2!d' file # 2nd line
                            sed '3!d' file # 3rd line
                            sed '4!d' file # 4th line
                              meleu @mediamogul
                              @mediamogul This guide would be really nice on the wiki, huh? ;-)
                                mediamogul Global Moderator @meleu
                                @meleu
                                I originally thought it might be a bit too long and involved for a wiki entry, but maybe it should go there.
                                  meleu @mediamogul
                                  @mediamogul I think it is a bit too long and involved for a forum topic. LOL! :D
                                  I think it fits nice in the "Advanced Configuration" section.
                                    @meleu
                                    I might try to pair it down to something more manageable at some point and post it as a wiki.
                                    RionR 1 Reply Last reply Reply Quote 3
                                      jrmymllr
                                      Great guide. I'm getting more comfortable with xboxdrv and it should work well.
                                      I'll have two different types of controllers, either one (not both) may be connected. How will xboxdrv and ES handle this? I'm hoping that when the controller mapped to xboxdrv is attached, xboxdrv will run, and ES will see the virtual Xbox controller and use that, and when the other controller is attached, xboxdrv will fail, and ES will see the non-Xbox controller and use that. Is that basically accurate?
                                        mediamogul Global Moderator @jrmymllr
                                        @jrmymllr
                                        xboxdrv can't detect when a controller is connected when used in the way this guide details, so the command must be executed after the controller is connected. Even when the configuration command is added to /etc/rc.local, your controller must be connected at startup or it will fail. Provided that you've mapped both your xboxdrv controller and the secondary controller you mentioned, Emulation Station should have no problem reading either.
                                          jrmymllr @mediamogul
                                          @mediamogul
                                          Right, I'd have to reboot then immediately change controllers. That was my thought too.
                                            @jrmymllr
                                            There are ways to create a daemon that would see when a controller is connected and execute a command like you would need for xboxdrv, but all information I've found on the subject is either conflicting or outdated. If successfully implemented, it could also tell when a controller is disconnected and stop xboxdrv.
