    2.3k Posts 37 Posters 9.7m Views
    • FollyF
      Folly @DTEAM
      @DTEAM
      Just tested cdimono1 (philips cdi) and it does work on my PI4 and PI5 with the mame 265 stickfreaks binary.
      Will test VIS too, will let you know.
      Edit :
      Tested VIS with "Americas National Parks (1992)(Multicom)(US)" on my PI4 and the shown EXIT buttons in the game do work.
      Which game did you try ?
      • FollyF
        Folly @DTEAM
        I used mame0.265 binary (line 12) from your script.
        Line 12 is a totally different binary, see here :
        If possible then you should use :
        • DTEAMD
          DTEAM @Folly
          @Folly
          Links Golf
          For MAME I made a mistake, I used 0.255. It was line 12 on your main download page (Experimental one, at risk ) Sorry. I read too fast. Stupid mistake from me. Sorry for wasting your time.
          The stickfreaks file you have is for a 64bit Raspberry Pi OS
          see :
          https://stickfreaks.com/mame/_README.TXT
          I think I need the "armhf"/"armv7l" version for 32bit Rasbperry Pi OS......
          It doesn't exist for 0.265. He has stopped to share this option with MAME 0.260. With retropie, the official 32 bit binary file stop at 0.264.
          Well, I'll have to go with my Pi5 to continue
          • FollyF
            Folly @DTEAM
            @DTEAM
            Ok now I understand,indeed that binary is for RPI1.
            Indeed the stickfreaks website dropped the 32bits/rpi2 versions.
            The 32 bit's 264 mame binary should still be available from the RetroPie-Setup when you install mame from the original mame module-script.
            It is linked in my script or go to experimental packages and install/update from binary instead of source.
            I have never added that one to my gdrive.
            I will see if I still can.
            • DTEAMD
              DTEAM @Folly
              @Folly
              see here
              https://github.com/danmons/mame_raspberrypi_cross_compile/issues/6
              • FollyF
                Folly @DTEAM
                @DTEAM
                I never used cross-compiling but indeed I see some returning news.
                Seems it's best to use a 64bits OS in the future.
                What did strike you the most ?
                • DTEAMD
                  DTEAM @Folly
                  @Folly
                  Not that much. Just the newest additions. 0.264 works well
                  Maybe we are near the end of 32 bit with MAME. I'll do a manual installation of Retropie on my Pi5. I didn't found a recent (0.265 or 0.266) precompiled 32 bit version of MAME
                  FollyF duglorD 3 Replies Last reply Reply Quote 1
                  • FollyF
                    Folly @DTEAM
                    @DTEAM
                    Let me know if it works for you ;-)
                    And if you want you can share it for my gdrive.
                    • FollyF
                      Folly @DTEAM
                      @DTEAM
                      Good news.
                      I used and almost forgotten way of creating a somewhat cross-compiled 64bits binary for RPI3 on my Apple M1(Bookworm VM) in far less than 2 hours.
                      Nice thing it will work on RPI4 and RPI5 too.
                      Added that 266 binary to the gdrive.
                      See here for more info.
                      I used :
                      sudo __platform=rpi3 ./retropie_packages.sh mame
                      p.s.
                      The Apple M1 is 64bits only, think it's not possible to do it for 32bits.
                      Probably only works when you use a 32bits OS, so on the RPI5 it would be possible with a reasonable speed.
                      Edit 1 :
                      Sadly the mame binary only works in desktop mode on the RPI3 and is of-course also slow.
                      (might be that something has to be changed in the config.txt for the RPI3)
                      For the RPI4 and RPI5 it works in both terminal(lite) and desktop mode.
                      I will probably rename the binary for RPI4 and RPI5 only. (Edit : RPI3 is still in the name, using rpi3dt now [dt=desktop])
                      Edit 2 :
                      Got the binary running in "lite-cli-mode" on the zero2w, rpi3a+ and rpi3b+ when installing zram using this :
                      https://ikarus.sg/using-zram-to-get-more-out-of-your-raspberry-pi/
                      https://github.com/StuartIanNaylor/zram-swap-config
                      Got 100% on apple2 (autoframeskip)
                      kgradius runs on 60% (frameskip 10)
                      conclusion the binary is compiled ok for rpi3.
                      • FollyF
                        Folly
                        Wasn't planning to update to 0266 but did it anyway.
                        Among-st others a few new neogeo games have been added.
                          JimmyFromTheBay @Folly
                          @Folly Hey amigo. Noticed this and wondered if it might help me run the Sinclair ZX80 on my RPi4 with Buster. I downloaded both versions:
                          lr-mess_0.265_x86_64_BuildBot_gccXX_PC_generic_full_mame
                          and
                          lr-mess_0.265_x86_32_BuildBot_gccXX_PC_generic_full_mame
                          from your Gdrive and installed them in my Downloads folder as before.
                          Then I tried to run lr-mess-system-zx80-cass with this EMULATORS.CFG:
                          lr-mess-system-zx80-cass = "/home/pi/RetroPie-Setup/scriptmodules/run_mess.sh /opt/retropie/emulators/retroarch/bin/retroarch /home/pi/Downloads/lr-mess265/mamemess_libretro.so /opt/retropie/configs/zx80/retroarch.cfg \zx80 /home/pi/RetroPie/BIOS/mame -autoframeskip -ui_active -cass %ROM%"
                          But it fails with this error log:
                          Parameters:
                          Executing: /home/pi/RetroPie-Setup/scriptmodules/run_mess.sh /opt/retropie/emulators/retroarch/bin/retroarch /home/pi/Downloads/lr-mess265/mamemess_libretro.so /opt/retropie/configs/zx80/retroarch.cfg \zx80 /home/pi/RetroPie/BIOS/mame -autoframeskip -ui_active -cass "/home/pi/RetroPie/roms/zx80/ZX80 4K ROM Kong Loader (Lightning Software, 2010).o" --verbose --appendconfig /dev/shm/retroarch.cfg
                          basename: unrecognized option '--verbose'
                          Try 'basename --help' for more information.
                          [.] parameters dump
                          \t_retroarchbin: /opt/retropie/emulators/retroarch/bin/retroarch
                          \t_messpath: /home/pi/Downloads/lr-mess265/mamemess_libretro.so
                          \t_config: /opt/retropie/configs/zx80/retroarch.cfg (+ /opt/retropie/configs/zx80/retroarch.cfg.add)
                          \t_cfg_directory: /opt/retropie/configs/zx80
                          \t_system: zx80
                          \t_biosdir: /home/pi/RetroPie/BIOS/mame
                          dirname: invalid option -- 'a'
                          Try 'dirname --help' for more information.
                          dirname: invalid option -- 'u'
                          dirname: invalid option -- 'c'
                          \t_romdir: /home/pi/RetroPie/roms/zx80
                          \t/tmp/mess.cmd content: zx80 -rp "/home/pi/RetroPie/BIOS/mame" -cfg_directory /opt/retropie/configs/zx80 "-autoframeskip" "-ui_active" "-cass" "/home/pi/RetroPie/roms/zx80/ZX80 4K ROM Kong Loader (Lightning Software, 2010).o"
                          rm: cannot remove '/home/pi/RetroPie/roms/zx80/.cmd': No such file or directory
                          rm: cannot remove '/opt/retropie/configs/zx80/tmpconfig.add': No such file or directory
                          [.] launching: /opt/retropie/emulators/retroarch/bin/retroarch --verbose --config /opt/retropie/configs/zx80/retroarch.cfg --appendconfig /opt/retropie/configs/zx80/tmpconfig.add -L /home/pi/Downloads/lr-mess265/mamemess_libretro.so /home/pi/RetroPie/roms/zx80/.cmd
                          [WARN] --libretro argument "/home/pi/Downloads/lr-mess265/mamemess_libretro.so" is neither a file nor directory. Ignoring.
                          [INFO] RetroArch 1.8.8 (Git 9552f87)
                          [INFO] Redirecting save file to "/home/pi/RetroPie/roms/zx80/.srm".
                          [INFO] Redirecting save state to "/home/pi/RetroPie/roms/zx80/.state".
                          [INFO] Capabilities:  NEON VFPv3 VFPv4
                          [INFO] Built: Nov  2 2020
                          [INFO] Version: 1.8.8
                          [INFO] Git: 9552f87
                          [ERROR] Frontend is built for dynamic libretro cores, but path is not set. Cannot continue.
                          [ERROR] Fatal error received in: "init_libretro_symbols()"
                          Am I wasting my time here or should it be possible to get this to work?
                          • FollyF
                            Folly @JimmyFromTheBay
                            @JimmyFromTheBay
                            Hi friend,
                            You are wasting your time ;-)
                            The binaries you used are for regular AMD/Intel machines running linux and RetroPie on regular PC's.
                            You need the arm/aarch64 variant for running it on a PI4/PI5.
                            On top of that all versions of mame above 264 need Bookworm to run.
                            For lr-mess/lr-mame this could be different as I have not tested this yet, but my guts say it will not work just like with mame.
                            If you want to run it then you need to install Bookworm on your PI4/PI5 and install RetroPie on top of it.
                            It's advised to use a 64bit Bookworm OS and use the aarch64 binary.
                            J FollyF 2 Replies Last reply Reply Quote 1
                              @Folly Damn my foolish hopes! 😄
                              • FollyF
                                Folly @Folly
                                @JimmyFromTheBay
                                I can create a new topic about this if needed.
                                Anyone : Is there some demand for this ?
                                • FollyF
                                  Folly
                                  @DTEAM @JimmyFromTheBay @bbilford83
                                  Added the latest lr-mess/lr-mame 266 for Bookworm 64bits aarch64 that works on rpi3+4+5.
                                  On the rpi3(1Gb) it even works without desktop environment and is fast enough, just like the old days.
                                  Tried kgradius from konamih and apple2 with good results.
                                  Running it on rpi3(1Gb) in desktop mode does run but is slow so that is probably a no go.
                                  Edit:
                                  The binaries are full mame and therefor big.
                                  The binaries seems to be too big and will not run on the zero2w and rpi3a+ which only have 512Mb.
                                    @Folly Fantastic!
                                      @JimmyFromTheBay
                                      I'm definitely interested, as there's still no "official" Retropie for the Pi5.
                                      DTEAMD FollyF 2 Replies Last reply Reply Quote 1
                                      • DTEAMD
                                        @Folly
                                        I installed your script on my Pi 5 and installed MAME 0.266 with it. It works wonderfully.
                                        FollyF 1 Reply Last reply Reply Quote 2
                                        • FollyF
                                          Folly @DTEAM
                                          @Folly
                                          Is it a 64bits OS or 32bits OS.
                                          Did you create your own binary or did you use mine ?
                                          • FollyF
                                            @JimmyFromTheBay said in Development of module-script generator for lr-mess, lr-mame and mame standalone:
                                            @JimmyFromTheBay
                                            If I have the time then I will have a look.
