      shift @Folly
      @Folly A question: I tried to use the mame for the Philips CD-i and also for the FM Towns, and I saw that I have to pass the .cue file to it first (even if the size is 0 bytes I saw that it works), but not Is it possible to use the mame directly with .chd files without necessarily having to use the name of the "rom" (8 digits) in .cue format?
      • FollyF
        Folly @shift
        @shift
        Have you installed it with my script ?
        If you have a good mame binary running, that doesn't have the CHD issue, then you can load that CHD or even .CUE directly with the use of the media option.
        My script creates these runcommands too using the media option -cdrm.
        That should work.
          shift @Folly
          @Folly You're right, I was using the old script, now that I have installed the mamedev.sh it works perfectly even launching the .chd file directly. Thank you!
          • FollyF
            Folly @shift
            @shift
            Good to hear !
            What is your all over first impression now using the new script ?
              shift @Folly
              The new script is easier to use and is really intuitive, I added the new machine in a second!
              • FollyF
                Folly @shift
                @shift
                Thanks for the feedback.
                Good to hear that you find it intuitive, that is one of my main goals.
                A guide should not be necessary.
                  bbilford83 @Folly
                  @DTEAM @bbilford83
                  I have added standalone mame version detection 265.17.
                  So the database will be more in sync with mame.
                  Can you both test it and let me know if you find this an improvement.
                  Hi @Folly. Correct me if I'm wrong but won't it not work for me unless I update my overall OS? I thought 265 was the crossover point.
                  • FollyF
                    Folly @bbilford83
                    @DTEAM @bbilford83
                    It's an update that you still can use older mame versions.
                    The script will check what version you have and will enable that database if present.
                    If not you have to pick a close database version.
                    That version is shown in the right corner.
                    Then the script will only show and install drivers that were on that version of mame.
                    Do you understand it now ?
                    Edit :
                    Earlier on you were able to switch between databases manually.
                    So you had to know what version you were running and switch it by yourself.
                    That is still possible though.
                    • FollyF
                      Folly @bbilford83
                      Only if you want to use the newer mame 265 version.
                      Edit :
                      The newer script will still work on older OSes but newer mame versions will not.
                      • DTEAMD
                        DTEAM @Folly
                        @Folly
                        MAME 0.266 is released. No new stuff for us.
                        • FollyF
                          Folly @DTEAM
                          @DTEAM
                          Yes I saw, nice !
                          Have build my first x86_64 binary.
                          Computer is now busy with creating the inis.
                          Would like to be completely independent from progettosnaps in the future but that is probably too much work.
                          Ps.
                          Have you had the chance to look at the script updates or is it too much for you ?
                          • DTEAMD
                            DTEAM @Folly
                            Yes, it's working well ! I installed 0.255 with your script
                            New games from Gameking III doesn't work. don't know why
                            • FollyF
                              Folly @DTEAM
                              Is it a typo or is 255 correct.
                              255 is quite old or was it a test on your side to test the script.
                              Which games do not work ?
                              • DTEAMD
                                DTEAM @Folly
                                @Folly
                                (MAME file names) diamond and hemic. All gameking3 games working well excepted those 2 new games
                                Problem with CDI, All CD systems work excepted CDI. Maybe it's on my side for that one.
                                For CDI and GAMEKING3, i used your script.
                                FollyF DTEAMD 2 Replies Last reply Reply Quote 0
                                • FollyF
                                  Folly @DTEAM
                                  @DTEAM
                                  Do you use RPI3 or 4
                                  • DTEAMD
                                    DTEAM @Folly
                                    @Folly
                                    Pi4
                                    • FollyF
                                      Folly @DTEAM
                                      @DTEAM
                                      It's likely due to the version/binary of mame you use.
                                      • FollyF
                                        Folly
                                        I stopped updating the database ini files for 266 and decided that I will skip this version update.
                                        It might be that I will also skip several more version updates that will save me a lot of time.
                                        Seems to me that a large number of users cannot or will not play with mame 265 or higher yet as most are still using older OSes and the users of PI5's seem also limited.
                                        Therefor it makes no real sense to do the version updates.
                                        If someone thinks differently about it then let me know and I can reconsider.
                                        • DTEAMD
                                          DTEAM @DTEAM
                                          CDI works with 0.264 but not with 0.265. I used mame0.265 binary (line 12) from your script. 0.265 has some bugs for some system. For exemple for VIS, I cant use MAME alocated buttons , like exit. but for some systems, everything working well. I came back to 0.264.
                                          Does it exist another precompiled 0.265 compatible with a Pi4?
                                          FollyF 3 Replies Last reply Reply Quote 0
                                          • FollyF
                                            Folly @DTEAM
                                            @DTEAM
                                            Ok interesting that you could somehow use 265 partly.
                                            Did you make a new 64 bits Bookworm image for yourself and installed RetroPie-Setup on top of it ?
                                            No there is not another 265 binary for the PI4.
                                            You should make it yourself.
