    2.3k Posts 37 Posters 8.7m Views
      bbilford83 @Folly
      @Folly Thank you very much for jumping in, doesn't seem as straightforward as I would hope. But I didn't know about the Interton VC4000 before and since that has a mame software list I may try to get that working and add a gamelist to my shared gdrive folder. Seems much more straightforward control-wise too.
      • FollyF
        Folly @bbilford83
        @bbilford83
        Indeed, good choice to begin with !
        TPRT 1 Reply Last reply Reply Quote 0
        • TPRT
          TPR @Folly
          @Folly I've been searching around trying to find the answer, but figured you'd be a good one to ask... if I'm wanting to try to get CD-I up and running on a Pi 5 build, where is a good place to start now?
          I haven't seen anyone mention this in a while and I'm not sure how outdated some of the previous information is.
          • FollyF
            Folly @TPR
            @TPR said in Development of module-script generator for lr-mess, lr-mame and mame standalone:
            You can use my script and install cdimono1.
            3 patches are installed to get it working like it should.
            Info is displayed so you can read what they do.
            However there is no guarantee it will work for you.
            Second option is to use the module-script lr-same_cdi.
            The module script is here now (removed it from my repository):
            https://github.com/Exarkuniv/RetroPie-Extra/tree/master/scriptmodules/libretrocores
            lr-samecdi is a patched lr-mess with only the cdimono1 driver compiled.
            It has been a while since I used that, so not sure if it will work better than regular mame and lr-mess
            Can you tell me know what works best ?
            TPRT 2 Replies Last reply Reply Quote 0
            • TPRT
              TPR @Folly
              I will give the lr-samecdi a try first. That one I can wrap my head around easily.
              I'm not exactly sure what I need to install with your script exactly. There's a LOT to go through in this topic and it was a little much for me, not gonna lie.
              • TPRT
                TPR @Folly
                @Folly So looks like lr-same_cdi works pretty well and pretty easily. I assume still no way to get the digital video games running? Aside from that initial tests seem pretty positive!
                • FollyF
                  Folly @TPR
                  @TPR
                  Thanks for the info.
                  Indeed, digital video games do not work.
                  • TPRT
                    TPR @Folly
                    @TPR
                    Then I would say the lr-samecdi script is a success! Thank you!
                    • TPRT
                      TPR @Folly
                      @Folly I have found one game that seems to have a scrambled screen:
                      Adventures of the Space Ship Beagle. Not sure if it's just not emulated well, but I tried two different roms and the same results. This one doesn't require the digital video adapter but I'm going to guess it just isn't emulated in MESS properly?
                      FollyF testudoT 2 Replies Last reply Reply Quote 0
                      • FollyF
                        Folly @TPR
                        @TPR
                        I can't find that game in the cdi.xml hash table so your probably right that it will not work correctly.
                        Edit :
                        Just tried it too and it didn't work on mame 0.266.
                        I think it could be an NTSC-J issue something is described over here :
                        https://retrostuff.org/2020/01/11/philips-cdi470-pal-ntsc-modification/
                        TPRT 1 Reply Last reply Reply Quote 1
                        • TPRT
                          TPR @Folly
                          @TPR
                          Edit :
                          Yep, must be it... I just tested "AIUEO" which is another Japan exclusive and it did the same thing.
                          So far in my testing, all US and EU non-digital video required roms do seem to work perfectly. Also, I added .cue to the es_systems and cue/bin files seem to load up just fine. Not sure if that's something that helps you out or not, but so far I've tested .chd and .cue/bin to work fine.
                          However I did notice that .cue/bin files in a .zip file do not seem to load.
                          • FollyF
                            Folly @TPR
                            I tested "Anniversary - Yuki Saito (Japan)" and does work with a small glitch so I am not yet convinced if it is an NTSC issue.
                            • TPRT
                              TPR @Folly
                              If you figure out any solution for those Japanese games, please let me know! I'll keep trying things on my end too.
                              • DTEAMD
                                DTEAM @TPR
                                @Folly
                                MAME 0.271 is released
                                265-in-1 Handheld Game (SPG2xx based) [David Haywood, TeamEurope] (All in 1)
                                FollyF 2 Replies Last reply Reply Quote 1
                                • FollyF
                                  Folly @DTEAM
                                  @DTEAM
                                  I might update if I have the time for it.
                                  • TPRT
                                    TPR @Folly
                                    @Folly I'm considering adding FM Towns to my Pi 5 build. What would be the best steps to follow to get that set up?
                                    • FollyF
                                      Folly @TPR
                                      I would start with installing the fmtowns from my script.
                                      My script will add 6M of ram to the runcommand.
                                      More ram will mean that games will run that need that extra ram.
                                      Then get the bios roms and the chd's and place them in the correct folders.
                                      If you want to test some others then you can also try :
                                      Driver fmtowns (FM-Towns (Model 1 / 2)):
                                      Driver fmtownsftv (FM-Towns II FreshTV):
                                      Driver fmtownshr (FM-Towns II HR):
                                      Driver fmtownsmx (FM-Towns II MX):
                                      Driver fmtownssj (FM-Towns II SJ):
                                      Driver fmtownsux (FM-Towns II UX):
                                      Driver fmtownsv03 (FM-Towns (unknown, V03 L01 00 91/07/09)):
                                      Driver fmtmarty (FM-Towns Marty):
                                      Driver fmtmarty2 (FM-Towns Marty 2):
                                      Driver carmarty (FM-Towns Car Marty):
                                      For the fmtmarty's 4M will be added.
                                      I believe carmarty has issues and no ram will be added by my script.
                                      • testudoT
                                        testudo @TPR
                                        I saw this listed in the comment section of a YouTube video of the game:
                                        "@MrBurnsObscureGamesTester
                                        1 year ago
                                        There's a handful of discs like this one that was released 1989/1990 that only work on early cdi test/dev/monitor units"
                                        • FollyF
                                          Folly @testudo
                                          @testudo
                                          Can you share the youtube link ?
                                          testudoT 1 Reply Last reply Reply Quote 0
                                          • testudoT
                                            testudo @Folly
                                            @Folly
