    2.2k Posts 36 Posters 6.1m Views
    • F
      Folly @DTEAM
      @Folly
      MAME 0.271 is released
      265-in-1 Handheld Game (SPG2xx based) [David Haywood, TeamEurope] (All in 1)
      I updated everything to 0271.
      Again this was quite some work.
      To give you an idea here I added a readme on how I do that (just scroll down):
      https://github.com/FollyMaddy/RetroPie-Share/tree/main/00-databases-00/sorted_info_creation/0XXX
      I also added this so others can join in if they want.
      Hope everything works like expected.
      Only the mame0271 aarch64 binary has been added to the gdrive
      X86_64 binaries are still missing
      lr-mess/lr-mame binaries are also still missing.
      Will see if I have the time this week to add more binaries.
      edit1:
      X86/X86_64 binaries have been added.
      edit2:
      lr-mess_0.271_x86_64_BuildBot_gccXX_PC_generic_full_mame.7z has been updated with the hash table that I forgot to add (24-11-2024)
      • TPRT
        TPR @Folly
        @TPR said in Development of module-script generator for lr-mess, lr-mame and mame standalone:
        @Folly I'm considering adding FM Towns to my Pi 5 build. What would be the best steps to follow to get that set up?
        I would start with installing the fmtowns from my script.
        My script will add 6M of ram to the runcommand.
        More ram will mean that games will run that need that extra ram.
        Then get the bios roms and the chd's and place them in the correct folders.
        If you want to test some others then you can also try :
        Driver fmtowns (FM-Towns (Model 1 / 2)):
        Driver fmtownsftv (FM-Towns II FreshTV):
        Driver fmtownshr (FM-Towns II HR):
        Driver fmtownsmx (FM-Towns II MX):
        Driver fmtownssj (FM-Towns II SJ):
        Driver fmtownsux (FM-Towns II UX):
        Driver fmtownsv03 (FM-Towns (unknown, V03 L01 00 91/07/09)):
        Driver fmtmarty (FM-Towns Marty):
        Driver fmtmarty2 (FM-Towns Marty 2):
        Driver carmarty (FM-Towns Car Marty):
        For the fmtmarty's 4M will be added.
        I believe carmarty has issues and no ram will be added by my script.
        Up and running! Thank you!
        I did notice that .chd and .cue/.bin seem to work okay but a .zip just hung on the FM Towns Marty screen.
        • F
          Folly @TPR
          @TPR
          Nice, good job ;-)
          TPRT 4 Replies Last reply Reply Quote 1
          • TPRT
            TPR @Folly
            @TPR
            Nice, good job ;-)
            With your help! Thank you!
            • TPRT
              TPR @Folly
              @TPR
              Nice, good job ;-)
              Question for you. I got the games that require a blank floppy disk running by following your instructions here:
              https://retropie.org.uk/forum/topic/27806/tutorial-fujitsu-fm-towns-marty-with-lr-mess/36?_=1732340369432
              But is there a way to load the game with already having the flop inserted into the drive when the game loads? Is there something I can add to a game specific command line in emulators.cfg that will pre-load the floppy so I don't have to into the mame menu and load it when I boot up a game?
              • TPRT
                TPR @Folly
                @Folly Nevermind, I figured it out. My command line looks like this now:
                lr-mess-fmtmarty-carmen = "/opt/retropie/emulators/retroarch/bin/retroarch --config /opt/retropie/configs/fmtmarty/retroarch.cfg --appendconfig /opt/retropie/configs/fmtmarty/retroarch.cfg.add -S /home/pi/RetroPie/roms/fmtmarty -s /home/pi/RetroPie/roms/fmtmarty -v -L /opt/retropie/libretrocores/lr-mess/mamemess_libretro.so 'fmtmarty -ram 4M -rompath /home/pi/RetroPie/BIOS/mame;/home/pi/RetroPie/roms/fmtmarty/ -cfg_directory /opt/retropie/configs/fmtmarty/lr-mess -c -ui_active -flop /home/pi/RetroPie/roms/fm_towns_disks/carmen.mfi -cdrm %ROM%'"
                and I added:
                which pointed to the disk and the game loaded with the floppy already in the drive!
                • F
                  Folly
                  Just added the lr-mame and lr-mess binaries for aarch64 too.
                  (Versions 0.271)
                  TPRT 1 Reply Last reply Reply Quote 0
                  • TPRT
                    TPR @Folly
                    @Folly Was Tomy Tutor ever a consideration for your script?
                    • TPRT
                      TPR @Folly
                      @Folly I'm finding a few games hanging on the Marty intro blue screen. For example, "Yuuwaku (Japan)" - I've tried both the cue/bin version and a chd and none of them seem to load. Anything but the cdrm command line kicks me back to emulationstation. Any ideas on some of these to get them to load up?
                      TPRT F 2 Replies Last reply Reply Quote 0
                      • TPRT
                        TPR @TPR
                        @Folly Samurai Spirits is another one. Tried both chd and cue/bin and no matter what options in emulators.cfg I choose it just hangs on this screen:
                        F 3 Replies Last reply Reply Quote 0
                        • F
                          Folly @TPR
                          Not specifically.
                          The consideration was that it could install and use all mame drivers if possible.
                          Basically that what it does depending on the database.
                          Mostly the rest depends on mame if the drive works or not.
                          For some drivers I added some patches in the script in order to let them work better.
                          I just tested tutor and this seems to work OOB ;-)
                          • F
                            Folly @TPR
                            @TPR
                            If I have the time to do so then I might install fmtowns to see what it does on my computer.
                            • F
                              Folly @TPR
                              I found the file Yuwaku (1996)(T2)(Jp)[+UserDisk].zip.
                              Just running the .cue with the -cdrm runcommand the fmtowns driver started up but didn't find the cd.
                              However it did not kick me back !
                              You might want to check you /dev/shm/runcommand.log.
                              I manually added the .bin user disk in the UI and restarted mame with F3 then it booted into the game.
                              Seems like adding the user disk is the solution.
                              I never added patches for fmtowns to load cdrom + floppy in one go but could be something to think about as more games use user/data disks.
                              However that said, not directly sure what simple fix/patch this should be as every method has it's own advantages or dis-advantages.
                              Edit:
                              Above method is obviously not the basename/softlist way but the -cdrm (-flop) method.
                              However, looking at the softlist files the fmtowns_cd holds the bootdisks needed to get the chd's loaded.
                              It should therefor be possible to load the disk via basename and then the chd cd image should automatically be found.
                              My runcommands have the BIOS/mame and of-course the roms/fmtowns paths in them to search in.
                              This line in the runcommand.log :
                              yuuwaku (japan).chd NOT FOUND (tried in fmtowns_cd/yuuwaku yuuwaku fmtowns_cd
                              reveals that you could place the "yuuwaku (japan).chd" in :
                              BIOS/mame/fmtowns_cd/yuuwaku
                              or
                              roms/fmtowns/fmtowns_cd/yuuwaku
                              If you are lucky it should load in 1 go.
                              • F
                                Folly @TPR
                                I got the boot-disk (sspirit.zip) from the mame-sl softlist in fmtowns_cd.
                                Tried to get samurai spirits (japan).chd from the mame-chd set but it wasn't there so I got my file from elsewhere and pasted in :
                                ~/RetroPie/BIOS/mame/fmtowns_cd/sspirits/samurai spirits (japan).chd
                                Then I ran sspirit.zip from roms/fmtowns with a basename loader and got it running.
                                I did this now on a 2.6Ghz intel I5 and it was a bit stuttering so I used some frameskipping to improve the speed in mame standalone.
                                I did some fighting and it did not freeze in the time I played with it.
                                I think this game might be too heavy for the pi4 or pi5.
                                Here is my picture :
                                • F
                                  Folly @TPR
                                  @TPR
                                  This page might be interesting for you :
                                  https://arcade.vastheman.com/minimaws/softwarelist/fmtowns_cd
                                  BTW:
                                  I did all the tests on fmtowns not fmtmarty.
                                  • TPRT
                                    TPR @Folly
                                    Not specifically.
                                    Oh! If tutor works, if you could point me in the right direction to get it running that would be appreciated!
                                    As for the other fmtowns stuff, that all seems to make sense to me and I'll give it all a try this week.
                                    Thank you!
                                    • TPRT
                                      TPR @Folly
                                      @Folly Using the boot disk, this is what worked for me:
                                      Lr-mess-fmtowns-sspirits = "/opt/retropie/emulators/retroarch/bin/retroarch --config /opt/retropie/configs/fmtowns/retroarch.cfg --appendconfig /opt/retropie/configs/fmtowns/retroarch.cfg.add -S /home/pi/RetroPie/roms/fmtowns -s /home/pi/RetroPie/roms/fmtowns -v -L /opt/retropie/libretrocores/lr-mess/mamemess_libretro.so 'fmtowns -ram 6M -rompath /home/pi/RetroPie/BIOS/mame;/home/pi/RetroPie/roms/fmtowns/ -cfg_directory /opt/retropie/configs/fmtowns/lr-mess -c -ui_active -cdrm /home/pi/RetroPie/roms/fm_towns_disks/sspirits.chd -flop1 %ROM%'"
                                      Thanks again for your help!
                                      • F
                                        Folly @TPR
                                        Not specifically.
                                        Thank you!
                                        Install tutor from my script.
                                        Place the bios file tutor.zip in BIOS/mame
                                        Extract the file tutor.zip from the mame softlist set and place these files in roms/tutor.
                                        You can check all drivers in my database.
                                        It's downloaded to your computer when using the script (/opt/retropie/emulators/mame/mame0xxx_systems_sorted_info)
                                        or check these files with a text editor :
                                        https://github.com/FollyMaddy/RetroPie-Share/tree/main/00-databases-00/mame
                                        You can use direct and quick install from my script and just enter tutor or whatever you want to install.
                                        Remember default installs are focused on non-arcade drivers.
                                        Arcade drivers can also be inserted but the script will check if it belongs to a category and install the most obvious category.
                                        • TPRT
                                          TPR @Folly
                                          @Folly Gotcha, I didn’t realize it was already part of your script but that’s probably because I was looking in the suggested console list and not the full list of every possible rom. I’ll give that a try tomorrow!
                                          • F
                                            Folly @TPR
                                            The script depends heavily on the database.
                                            tutor doesn't have the tag @game_console :
                                            Driver tutor (Tomy Tutor): @computer@good@home_system@non-arcade@
                                            That's why it's not listed in the game_console list
                                            The tags mostly depend on the progettosnaps data.
                                            Probably not added because it has a keyboard and can be used as regular computer that's why it has the tag @home_system.
                                            For you I added the predefined list for home systems, look here :
                                            https://github.com/FollyMaddy/RetroPie-Share/commit/da0b6070816126d340e5690c66ff374eaa589eae
                                            Let me know if you understand how it works.
