      bbilford83
      @Folly sorry for all the questions but something more random/discrete, I am getting this very odd screen message on one game only for FM Towns Marty. The game is Cameltry (floppy game). This comes on not long after I get the game into its main screen:
      It has an in-game option to change the CRT mode from 15khz to 30khz, and when I change it to that the message changes to this:
      Nothing I do seems to make it go away, and when I searched the message all I found was something specific to FM Towns emulation in mame. Any ideas?
      • FollyF
        Folly @bbilford83
        @bbilford83
        If I have the time I will look at it in the coming week, can't promise though.
        • FollyF
          Folly
          I did a simple version update to 0262.00.
          Seems I added and changed too much to my test version.
          Somehow it seems there is a mistake inside the script which I can't find right now.
          Hopefully I can add the intended stuff later.
          Edit:
          Added some stuff to 0262.01 :
          • fix adding predefined options installing a driver from DEFAULT to all runcommands
          • also fixes the c64gs install adding "-joy2 joybstr" to all runcommands from DEFAULT
          • add extra ram to FM-Towns drivers when installing from DEFAULT
          Marty's get 4M and Towns 6M
            Retrodade @Folly
            @Folly I'm envy what's he emulator config script launching ctvboy?
            • FollyF
              Folly @Retrodade
              @Retrodade
              Installing should now be possible for you.
              Just update the script and install ctvboy and get the game roms.
              No BIOS is needed.
              Just use the installed basename runcommands.
              • FollyF
                Folly @bbilford83
                Got the same message using Cameltry, fmtmarty and fmtmarty2 using Cameltry from the original floppies.
                On fmtowns there is no massage shown, seems to be specific to the marty's.
                Can't find anything up until now.
                  bbilford83 @Folly
                  Got the same message using carmarty, fmtmarty and fmtmarty2 using cameltry from the original floppies.
                  Thank you for trying! What a strange quirk.
                  • FollyF
                    Folly @bbilford83
                    @bbilford83
                    Seems they added the popup messages in the sourcecode :
                    https://github.com/mamedev/mame/blob/master/src/mame/fujitsu/fmtowns.cpp#L407-L423
                    Perhaps for debugging or just for informing.
                    Though if it's the last then the message should go after a few seconds, I think.
                    Could be an issue in that perspective.
                    Edit :
                    I think they just forgot to remove the popmessage :
                    https://github.com/search?q=repo%3Amamedev%2Fmame+popmessage&type=commits
                      bbilford83
                      @Folly an update on my problems I was having with the FM Towns Marty games. There are some games that definitely need a full keyboard to work, esp. the RPGs, but I figured out that at least some seem to be 1) not playable with the marty or standard FM towns pads, 2) but playable with a mouse, WITHOUT a keyboard. The only one I tested that is like this so far is the first Secret of Monkey Island, but for obvious reason I expect this will work for the other "Point and Click" games at least that weren't working. And I used the trick you taught me for C64GS to create an emulator option in the runcommand menu that autoloads "mouse" into -pad1, so no tweaking is required after I assigned that emulator. Yay!
                      • FollyF
                        Folly
                        Added the new stuff :
                        https://github.com/FollyMaddy/RetroPie-Share/commit/20be1069949e7f2b306a472dbc712f89a38225a2
                          bbilford83
                          @Folly and for posterity, all of these work on FMT Marty with mouse but not pad.
                          Castles
                          Castles II
                          Indiana Jones and the Last Crusade*
                          Loom*
                          Populous and the Promised Lands
                          The Secret of Monkey Island
                          Zak McKracken and the Alien Mindbenders*
                          *These games did something weird with the pad where every time you moved at all it would demand you load or save, but they work fine with the mouse. Funny enough in the mouse mode I don't think you can get to the load or save menu (maybe it's escape or something), so that's not ideal, but you could still do a playthrough of the games. Maybe save states would work too?
                          I still can't get the following games to work with mouse or pad, though:
                          CyberCity
                          Lemmings
                          Lemmings 2 (there's an English translation)
                          Operation Wolf
                          Powermonger
                          RAC Rally**
                          **You technically can play this without a keyboard by loading it with a mouse and a joypad if you have two controllers connected. The default controls are keyboard, so you can't skip the super-long loading credits, but then finally when they are over you can use the mouse to change the control settings from keyboard to joypad, and then I think you could play with the controller you have assigned as a joypad. Way too much work obviously.
                          • FollyF
                            Folly @bbilford83
                            @bbilford83
                            I only tested Lemmings and had it working.
                            I used mame standalone using driver fmtowns with these mouse settings :
                              bbilford83 @Folly
                              @bbilford83
                              Interesting, thank you for sharing. You have both the pad and the mouse plugged in, maybe that is what's necessary (there is one game, Palamedes, that only plays with a pad plugged in to pad 2 slot). I was only using one or the other plugged into pad one. I will try your way later tonight.
                              Edit: At least for Lemmings that was it! Just to be clear I am trying to use the controller rather than an actual mouse, but it works the same as yours if I map the mouse functions to the controller 1. It just needed the mouse plugged into the second port. I will go back and test again the others of mine that weren't working with the mouse in port 2. I added another emulator line to auto-load the mouse in port 2 and that is working great it seems.
                              Edit 2: Operation Wolf took some doing but I got it to work too, and automated. I still don't know how to "un-map" the first pad with a command line emulator entry - I think you also tried and couldn't figure that out at one point - but I was able to get it auto-loading correctly with this:
                              -pad1 vaus -pad2 mouse -rs232c keyboard
                              I'm never going to use the "vaus" mapping option so I just mapped everything in there to other stuff on my controller I don't need (right analog, trigger buttons, etc.). This way, the game loads with the mouse in pad2 slot, the keyboard in a keyboard slot (which doesn't get used at all, I just knew from youtube it needs to be plugged in for some reason), and with something plugged in to pad1 that doesn't interfere with the mouse mappings. If you leave a normal pad (marty or towns) in -pad1, the mouse won't work because it's taking over the usual inputs. But with those in the command line it is working perfectly.
                              • FollyF
                                Folly
                                There seems to be an issue with the gdrivedl script, added an issue over here :
                                https://github.com/matthuisman/gdrivedl/issues/33
                                  bbilford83 @Folly
                                  @Folly one last FM Towns update, I found a great resource (here) that helped me get a lot more games working. So now I am done and my gamelist has now grown from 34 games to 82! There are quite a few that are weird in a variety ways that I have described in my gamelist... like two games (Legend of Kyrandia I and II) will only play in english if you use/emulate a mouse and press both buttons at the same time on a particular loading screen. But a lot of these are great... like Loom and the Indiana Jones games and such. And almost all can run without a keyboard (my personal criteria for emulating consoles). Long backstory to asking, do you want me to share my gamelist and art for this? Technically it can scrape in some places, but the info is generally terrible and lacking art. One game even (AD&D: Heroes of the Lance) all the scrapers and even redump don't even have, like it doesn't exist, but I can confirm it does work and is in English. What do you think?
                                  FollyF R 2 Replies Last reply Reply Quote 1
                                  • DTEAMD
                                    DTEAM @Retrodade
                                    @Retrodade said in Development of module-script generator for lr-mess, lr-mame and mame standalone:
                                    @Folly I started to look at the two Brick Game handhelds and if you'd take some feedback, I am not entirely sure they really belong as "classich" rather than "allin1." They seem more like the bittboy and such, no? The brke23p2 one dates to 1993 and says it is 96 in 1. The "Echo Key" one I can't find an original publication year but it also looks much later than the classich ones, no? I think it is also a multiple-games-in-one kind of thing.
                                    Ok I'll do my gamelist with videos in the category "allin1"
                                    • DTEAMD
                                      DTEAM @DTEAM
                                      @Folly here are my scrapes i made for CTVBoy only missing video until I get system working, but I think you should like the scrapes you can grab it here
                                      https://mega.nz/file/0A9V1bbK#wSGU5qCFAhLTG_Y9iSQmFMdL4zD-_HfPOXMWUXX21F8
                                      Your scrape is now on my Gdrive . I added .7z extension in the gamelist file and videos in the media folder.
                                      R 2 Replies Last reply Reply Quote 2
                                        Retrodade @DTEAM
                                        @DTEAM nice thanks
                                        • FollyF
                                          Folly
                                          @DTEAM @bbilford83
                                          There seems to be a quota limit on the gdrives, go figure !
                                          That is why the gdrivedl script of Matt. which is used from our script, got a Type-error.
                                          Still not sure about if it will skip such a file when the limit is reached.
                                          Also not sure when the limit is being reset again.
                                          It probably will and say that the quota has been exceeded and skip the file.
                                          So we will see what happens.
                                          What it probably does say is that al lot of people are downloading the stuff.
                                          So it's basically a luxury problem ;-)
                                            Retrodade @Folly
                                            @Folly thank you kindly for this, I have it working now.
