    Television sound output incompatible with my Retropie
    televisionsound issuesoundincompatibilityretropie
    20 Posts 3 Posters 2.9k Views
    • JirynJ
      Jiryn
      Pi Model or other hardware: Pi 4 4GB
      Power Supply used: Official PI 4 USB-C AC Adapter
      RetroPie Version Used: 4.7.17 Built From: Retropie site, updated through system
      USB Devices connected: 2 8bitdo arcade sticks
      Controller used: 2 8bitdo arcade sticks https://www.8bitdo.com/arcade-stick/
      This is long but pls read!
      After months of posts, thinking it was an emulation issue or something..
      I finally figured out what the issue is...
      My TV doesn't like the retropi's sound output.
      Whenever I try to play a game, especially arcade games like Mame and FBNeo, the sound cuts out constantly like someone is hitting mute on my TV.
      I figured it out because my stream was getting full audio, while my TV was cutting in and out.
      Examples
      Steam
      Live (Had to capture on phone since video capture would give full sound)
      I then tested it on every other TV in the house, and there were no issues. I just replaced the motherboard on the TV and the issues still persist.
      No other console hooked up via HDMI has these issues (Switch, PS4, PS5, Xbox Series X, 360, Xbox, Wii U, PS2, RetroTink upscaled systems) the only system it doesn't like is the Wii using this ( https://www.amazon.com/PORTHOLIC-Converter-Wii2HDMI-Adapter-Compatible/dp/B07H3NZ133/ref=sr_1_4?dchild=1&keywords=wii%2Bhdmi&qid=1627540032&sr=8-4&th=1 ) Which the company says is a common compatibility issue.
      It seems to only happen with MAME, FB NEO, and Sega 32x
      (Before I thought it was just a problem with Jurassic Park, now all arcade games are doing it)
      I honestly think it's gotten worse...
      So I wonder if there is a work around, maybe the system is over powering my TV's sound driver?
      Maybe it's outputting something that my system doesn't like? Can I change what the output through HDMI is?
      My TV is a VIZIO - 55" Class - LED - M-Series - 2160p - Smart - Home Theater Display with HDR
      (I heard there is a hidden boost option in Retropie?)
      (Years ago I had a similar problem with a different TV. If I set my PS3 to full dolby digital, the sounds would cut out and be distorted, I had to set them to stereo for the tv to work. However that was a decade ago with a Samsung DLP TV, I'm using a Vizio now)
        dankcushions Global Moderator
        as per https://retropie.org.uk/forum/topic/3/read-this-first please supply a verbose log of the issue: https://retropie.org.uk/docs/Runcommand/#launch-with-verbose-logging
        have you tried with a different HDMI cable/adapter?
        JirynJ 1 Reply Last reply Reply Quote 1
        • JirynJ
          Jiryn @dankcushions
          @dankcushions
          I thought I've said this above,
          This is an issue between this specific TV and the PI.
          I've tried different cords and ac and the same issues pops up on this tv.
          HOWEVER, I've tried it on 4 other TVs and it works perfectly
          The videos above were taken at the same time.
          My Pi is hooked up to a splitter which goes to the TV and a Streaming device.
          The Streaming device comes out perfect and all in stream can't hear an issue
          While my TV still has the regularly cutting out and shorting out.
          I'll post the logs in a bit... thank you.
          So I went and bought a new cable, and hooked it directly to the TV, same difference.
          put a new motherboard into the TV and same difference.
          The shorting out constantly happens.
          It's as if the TV cannot process the signal, and apparently is an issue with Vizios?
          https://www.reddit.com/r/VIZIO_Official/comments/g427xg/audio_cutting_out_often_vizio_m55d0/
          Still, it wasn't originally this bad and has gotten noticeably worse since I posted last year... thinking it was an emulation.
          I don't think it's an error with the Retropi, just an incompatibility with some form of sound processing/signal..
            mitu Global Moderator @Jiryn
            @jiryn said in Television sound output incompatible with my Retropie:
            On Pi3 and older there was the config_hdmi_boost option in config.txt, but for a Pi4 I don't think it's supported anymore (see https://www.raspberrypi.org/documentation/configuration/config-txt/video.md). You can try it out and see if it makes a difference.
            What resolution are you running your system ? Is the TV running in 'game mode' ?
            • JirynJ
              Jiryn @mitu
              1080p, and no.
              I turned off all post-processing crap to remove as much lag as I can.
              I'll try game mode now, see if it fixes it.
              Update
              Tried game mode, didn't change a thing.
              Here's the log
              Parameters:
              Executing: /opt/retropie/emulators/retroarch/bin/retroarch -L /opt/retropie/libretrocores/lr-fbneo/fbneo_libretro.so --config /opt/retropie/configs/fba/retroarch.cfg "/home/pi/RetroPie/roms/fba/moomesauac.zip" --verbose --appendconfig /dev/shm/retroarch.cfg
              [INFO] RetroArch 1.9.5 (Git 6738fa5)
              [INFO] Capabilities: NEON VFPv3 VFPv4
              [INFO] Built: Jun 21 2021
              [INFO] Version: 1.9.5
              [INFO] Git: 6738fa5
              [INFO] [Input]: Found input driver: "x".
              [INFO] [Core]: Loading dynamic libretro core from: "/opt/retropie/libretrocores/lr-fbneo/fbneo_libretro.so"
              [INFO] [Overrides]: No core-specific overrides found at "/home/pi/.config/retroarch/config/FinalBurn Neo/FinalBurn Neo.cfg".
              [INFO] [Overrides]: No content-dir-specific overrides found at "/home/pi/.config/retroarch/config/FinalBurn Neo/fba.cfg".
              [INFO] [Overrides]: No game-specific overrides found at "/home/pi/.config/retroarch/config/FinalBurn Neo/moomesauac.cfg".
              [INFO] [Remaps]: Remap directory: "/opt/retropie/configs/fba/".
              [INFO] [Overrides]: Redirecting save file to "/home/pi/RetroPie/roms/fba/moomesauac.srm".
              [INFO] [Overrides]: Redirecting save state to "/home/pi/RetroPie/roms/fba/moomesauac.state".
              [INFO] [Environ]: GET_LOG_INTERFACE.
              [INFO] [Environ]: GET_MESSAGE_INTERFACE_VERSION.
              [INFO] [Environ]: SET_AUDIO_BUFFER_STATUS_CALLBACK.
              [INFO] [CONTENT LOAD]: Content loading skipped. Implementation will load it on its own.
              [INFO] [Environ]: GET_SAVE_DIRECTORY.
              [libretro INFO] Setting save dir to /home/pi/RetroPie/roms/fba/
              [INFO] [Environ]: SYSTEM_DIRECTORY: "/home/pi/RetroPie/BIOS".
              [libretro INFO] Setting system dir to /home/pi/RetroPie/BIOS
              [INFO] [Environ]: SET_CONTROLLER_INFO.
              [libretro INFO] Initialize DIP switches.
              [INFO] [Environ]: GET_CORE_OPTIONS_VERSION.
              [INFO] [Environ]: RETRO_ENVIRONMENT_SET_CORE_OPTIONS_INTL.
              [libretro INFO] [FBNeo] Searching all possible locations for romset moomesauac
              [libretro INFO] [FBNeo] No patched romset found at /home/pi/RetroPie/BIOS/fbneo/patched/moomesauac
              [libretro INFO] [FBNeo] Romset found at /home/pi/RetroPie/roms/fba/moomesauac
              [libretro INFO] [FBNeo] No romset found at /home/pi/RetroPie/BIOS/fbneo/moomesauac
              [libretro INFO] [FBNeo] No romset found at /home/pi/RetroPie/BIOS/moomesauac
              [libretro INFO] [FBNeo] Using ROM with known crc 0x10555732 and name 151c01.q5 from archive /home/pi/RetroPie/roms/fba/moomesauac
              [libretro INFO] [FBNeo] Using ROM with known crc 0x52ae87b0 and name 151uac02.q6 from archive /home/pi/RetroPie/roms/fba/moomesauac
              [libretro INFO] [FBNeo] Using ROM with known crc 0xa5cb137a and name moomesauac.nv from archive /home/pi/RetroPie/roms/fba/moomesauac
              [libretro INFO] [FBNeo] Using ROM with known crc 0xc896d3ea and name 151a03.t5 from archive /home/pi/RetroPie/roms/fba/moomesa
              [libretro INFO] [FBNeo] Using ROM with known crc 0x3b24706a and name 151a04.t6 from archive /home/pi/RetroPie/roms/fba/moomesa
              [libretro INFO] [FBNeo] Using ROM with known crc 0xcde247fc and name 151a07.f5 from archive /home/pi/RetroPie/roms/fba/moomesa
              [libretro INFO] [FBNeo] Using ROM with known crc 0xbc616249 and name 151a05.t8 from archive /home/pi/RetroPie/roms/fba/moomesa
              [libretro INFO] [FBNeo] Using ROM with known crc 0x38dbcac1 and name 151a06.t10 from archive /home/pi/RetroPie/roms/fba/moomesa
              [libretro INFO] [FBNeo] Using ROM with known crc 0x376c64f1 and name 151a10.b8 from archive /home/pi/RetroPie/roms/fba/moomesa
              [libretro INFO] [FBNeo] Using ROM with known crc 0xe7f49225 and name 151a11.a8 from archive /home/pi/RetroPie/roms/fba/moomesa
              [libretro INFO] [FBNeo] Using ROM with known crc 0x4978555f and name 151a12.b10 from archive /home/pi/RetroPie/roms/fba/moomesa
              [libretro INFO] [FBNeo] Using ROM with known crc 0x4771f525 and name 151a13.a10 from archive /home/pi/RetroPie/roms/fba/moomesa
              [libretro INFO] [FBNeo] Using ROM with known crc 0x962251d7 and name 151a08.b6 from archive /home/pi/RetroPie/roms/fba/moomesa
              [libretro INFO] [FBNeo] No missing files, proceeding
              [libretro INFO] [FBNeo] Samplerate set to 48000
              [libretro INFO] [FBNeo] Applied dipswitches from core options
              [libretro INFO] [FBNeo] Initialized driver for moomesauac
              [libretro INFO] [FBNeo] Adjusted audio buffer to match driver's refresh rate (60.000000 Hz)
              [libretro INFO] [Cheevos] System RAM set to 0xaa691088, size is 241699
              [INFO] [Environ]: SET_ROTATION: 0
              [INFO] [Environ]: SET_PIXEL_FORMAT: XRGB8888.
              [libretro INFO] [FBNeo] Driver moomesauac was successfully started : game's full name is Wild West C.O.W.-Boys of Moo Mesa (ver UAC)
              [INFO] [SRAM]: Skipping SRAM load..
              [INFO] Version of libretro API: 1
              [INFO] Compiled against API: 1
              [INFO] [Audio]: Set audio input rate to: 48000.00 Hz.
              [INFO] [Video]: Video @ 1920x1080
              [INFO] [Video]: Starting threaded video driver ...
              [INFO] [DRM]: Found 1 connectors.
              [INFO] [DRM]: Connector 0 connected: yes
              [INFO] [DRM]: Connector 0 has 39 modes.
              [INFO] [DRM]: Connector 0 assigned to monitor index: #1.
              [INFO] [DRM]: Mode 0: (3840x2160) 3840 x 2160, 30.000000 Hz
              [INFO] [DRM]: Mode 1: (4096x2160) 4096 x 2160, 30.000000 Hz
              [INFO] [DRM]: Mode 2: (4096x2160) 4096 x 2160, 29.970001 Hz
              [INFO] [DRM]: Mode 3: (4096x2160) 4096 x 2160, 25.000000 Hz
              [INFO] [DRM]: Mode 4: (4096x2160) 4096 x 2160, 24.000000 Hz
              [INFO] [DRM]: Mode 5: (4096x2160) 4096 x 2160, 23.976000 Hz
              [INFO] [DRM]: Mode 6: (3840x2160) 3840 x 2160, 29.970001 Hz
              [INFO] [DRM]: Mode 7: (3840x2160) 3840 x 2160, 25.000000 Hz
              [INFO] [DRM]: Mode 8: (3840x2160) 3840 x 2160, 24.000000 Hz
              [INFO] [DRM]: Mode 9: (3840x2160) 3840 x 2160, 23.976000 Hz
              [INFO] [DRM]: Mode 10: (1920x1080) 1920 x 1080, 60.000000 Hz
              [INFO] [DRM]: Mode 11: (1920x1080) 1920 x 1080, 59.940201 Hz
              [INFO] [DRM]: Mode 12: (1920x1080i) 1920 x 1080, 30.000000 Hz
              [INFO] [DRM]: Mode 13: (1920x1080i) 1920 x 1080, 29.970100 Hz
              [INFO] [DRM]: Mode 14: (1920x1080) 1920 x 1080, 50.000000 Hz
              [INFO] [DRM]: Mode 15: (1920x1080) 1920 x 1080, 30.000000 Hz
              [INFO] [DRM]: Mode 16: (1920x1080) 1920 x 1080, 29.970100 Hz
              [INFO] [DRM]: Mode 17: (1920x1080) 1920 x 1080, 25.000000 Hz
              [INFO] [DRM]: Mode 18: (1920x1080) 1920 x 1080, 24.000000 Hz
              [INFO] [DRM]: Mode 19: (1920x1080) 1920 x 1080, 23.976080 Hz
              [INFO] [DRM]: Mode 20: (1280x720) 1280 x 720, 60.000000 Hz
              [INFO] [DRM]: Mode 21: (1280x720) 1280 x 720, 59.940201 Hz
              [INFO] [DRM]: Mode 22: (1280x720) 1280 x 720, 50.000000 Hz
              [INFO] [DRM]: Mode 23: (1024x768) 1024 x 768, 75.028580 Hz
              [INFO] [DRM]: Mode 24: (1024x768) 1024 x 768, 70.069359 Hz
              [INFO] [DRM]: Mode 25: (1024x768) 1024 x 768, 60.003841 Hz
              [INFO] [DRM]: Mode 26: (800x600) 800 x 600, 75.000000 Hz
              [INFO] [DRM]: Mode 27: (800x600) 800 x 600, 72.187569 Hz
              [INFO] [DRM]: Mode 28: (800x600) 800 x 600, 60.316540 Hz
              [INFO] [DRM]: Mode 29: (720x576) 720 x 576, 50.000000 Hz
              [INFO] [DRM]: Mode 30: (720x576i) 720 x 576, 25.000000 Hz
              [INFO] [DRM]: Mode 31: (720x480) 720 x 480, 60.000000 Hz
              [INFO] [DRM]: Mode 32: (720x480) 720 x 480, 59.940060 Hz
              [INFO] [DRM]: Mode 33: (720x480i) 720 x 480, 30.001110 Hz
              [INFO] [DRM]: Mode 34: (720x480i) 720 x 480, 29.970030 Hz
              [INFO] [DRM]: Mode 35: (640x480) 640 x 480, 75.000000 Hz
              [INFO] [DRM]: Mode 36: (640x480) 640 x 480, 60.000000 Hz
              [INFO] [DRM]: Mode 37: (640x480) 640 x 480, 59.940475 Hz
              [INFO] [DRM]: Mode 38: (720x400) 720 x 400, 70.081665 Hz
              [INFO] [GL]: Found GL context: kms
              [INFO] [GL]: Detecting screen resolution 1920x1080.
              [INFO] [EGL] Found EGL client version >= 1.5, trying eglGetPlatformDisplay
              [INFO] [EGL]: EGL version: 1.4
              [INFO] [EGL]: Current context: 0xa783b0a8.
              [INFO] [KMS]: New FB: 1920x1080 (stride: 7680).
              [INFO] [GL]: Vendor: Broadcom, Renderer: V3D 4.2.
              [INFO] [GL]: Version: OpenGL ES 3.1 Mesa 19.3.2.
              [INFO] [GL]: Using resolution 1920x1080
              [INFO] [GL]: Default shader backend found: glsl.
              [INFO] [Shaders]: Configuration file shader set to .
              [INFO] [Shader driver]: Using GLSL shader backend.
              [WARN] [GL]: Stock GLSL shaders will be used.
              [INFO] [GLSL]: Found GLSL vertex shader.
              [INFO] [GLSL]: Found GLSL fragment shader.
              [INFO] [GLSL]: Linking GLSL program.
              [INFO] [GL]: Using 4 textures.
              [INFO] [GL]: Loaded 1 program(s).
              [WARN] [udev]: Couldn't open any keyboard, mouse or touchpad. Are permissions set correctly for /dev/input/event*?
              [INFO] [udev]: Pad #0 (/dev/input/event0) supports force feedback.
              [INFO] [udev]: Pad #0 (/dev/input/event0) supports 16 force feedback effects.
              [INFO] [Video]: Found display server: null
              [INFO] [ALSA]: Using floating point format.
              [INFO] [ALSA]: Period size: 768 frames
              [INFO] [ALSA]: Buffer size: 3072 frames
              [INFO] [ALSA]: Can pause: no.
              [INFO] [Display]: Found display driver: "gl".
              [INFO] [Environ]: SET_SUBSYSTEM_INFO.
              [libretro INFO] [FBNeo] Unknown device type for port 0, forcing "Classic" instead
              [libretro INFO] [FBNeo] Unknown device type for port 1, forcing "Classic" instead
              [libretro INFO] [FBNeo] Unknown device type for port 2, forcing "Classic" instead
              [libretro INFO] [FBNeo] Unknown device type for port 3, forcing "Classic" instead
              [INFO] [Playlist]: Loading history file: [/opt/retropie/configs/fba/content_history.lpl].
              [INFO] [Playlist]: Loading history file: [/opt/retropie/configs/fba/content_music_history.lpl].
              [INFO] [Playlist]: Loading history file: [/opt/retropie/configs/fba/content_video_history.lpl].
              [INFO] [Playlist]: Loading history file: [/opt/retropie/configs/fba/content_image_history.lpl].
              [INFO] [Playlist]: Loading favorites file: [/opt/retropie/configs/fba/content_favorites.lpl].
              [INFO] [Playlist]: Written to playlist file: /opt/retropie/configs/fba/content_history.lpl
              [INFO] [Environ]: SET_INPUT_DESCRIPTORS:
              [INFO] [Core]: Content ran for a total of: 00 hours, 02 minutes, 34 seconds.
              [INFO] [Core]: Unloading game..
              [INFO] [Core]: Unloading core..
              [INFO] [Core]: Unloading core symbols..
              [INFO] [Core Options]: Saved core options file to "/opt/retropie/configs/all/retroarch-core-options.cfg"
              [INFO] Threaded video stats: Frames pushed: 9295, Frames dropped: 1.
                Can you try adding hdmi_safe=1 to config.txt and see the audio is cut ? It will change your resolution also, but for the sake of the test, just run with it temporarily.
                JirynJ 2 Replies Last reply Reply Quote 1
                • JirynJ
                  Jiryn @mitu
                  It say "Pemission Denied?"
                  (Sorry kinda new to the editing)
                  • JirynJ
                    Jiryn @mitu
                    Got it edited, the sound issue persists. (Figured out how to edit remotely through command line)
                    It's only in the emulators like MAME, FBNEO, and now even the GBA.
                    I enabled the "Force HDMI instead of DVI" to test it, since it references sound compatibility in monitors, and it also did nothing.
                    JirynJ 1 Reply Last reply Reply Quote 0
                    • JirynJ
                      Jiryn @Jiryn
                      @dankcushions @mitu
                      The answer has been found, and there is nothing I can do about it for now.
                      Back in May/June Vizio released a firmware patch that screwed up all their middle/high end TVs across the board.
                      What I am experiencing is a very small portion of the issues the firmware caused.
                      They posted a notice on various sites saying they'd fix it... but it's been a month and nothing has happened, they've gone silent.
                      https://www.reddit.com/r/VIZIO_Official/comments/o0juho/tv_firmware_update_to_1201817/
                      • JirynJ
                        Jiryn
                        HUGE UPDATE AND I HOPE SOMEONE READS THIS!
                        @dankcushions @mitu (Sorry you guys were helping so much!!!)
                        I went and bought a brand new TV
                        a 2021 LG 55" NanoCell 4K UHD Smart LED HDR TV - 55NANO75
                        The sound issues persist.
                        The sound cuts out regularly on most games, and extremely frequently with Jurassic Park (mame2010), which was my originally complaint.
                        I once again tried it on my older TVs and it worked without an issue or sound cutting out.
                        So it has to do something with modern sound hardware and the PI.
                        The LG detects the pi as PCM.
                          dankcushions Global Moderator @Jiryn
                          @jiryn
                          i have an lg 4k OLED which works fine so i am sure it’s an issue with your specific hardware, cables or configuration. i would start from the beginning again - ideally with a fresh default image, and then all the usual stuff like a verbose log, the config.txt, and so on.
                          mame2010 is not a recommend emulator, and i don’t use it, so i would replicate the issue with something far more generic like a game on a console system that your pi can be guaranteed to emulate well, at full speed. sound dropping out is a classic symptom of a game that pushes the hardware too much.
                          • JirynJ
                            Jiryn @dankcushions
                            @dankcushions
                            That's what I'm getting at is weird though.
                            The sound doesn't drop or hitch at all on a 4 of the 6 TVs in my house hold.
                            It runs perfectly, even Jurassic Park.
                            Even when captured through my system capture card, the sound is perfect.
                            Yet the signal to the TV still cuts out (See original post of the side by side Jurassic park videos)
                            This problem has been cropping up in everything on the PI. Mame 2003, FBNeo, Neo Geo, 32X, Virtual Boy, etc etc.
                            A Fresh Install is the only thing I've not tried, but why would it work perfectly for 4 of 6 TVs?
                            Once again, this is how it sounds on those TVs and on my stream
                            Mame 2010
                            This is how it sounds on the LG Nanocell and Vizio M55-E0
                              @jiryn it’s all i can suggest. removing all extraneous factors. in addition to the default image and basic game, also not going via an micro hdmi converter, no hdmi capture devices or audio devices devices in the chain, a name brand cable, and so on.
                              my suspicion is your cable or something in between your pi4 and the tv is interfering with the signal. as to why it works with other tvs - either the setup isn’t identical or older hdmi versions are less sensitive.
                              • JirynJ
                                Jiryn @dankcushions
                                @dankcushions said in Television sound output incompatible with my Retropie:
                                As I said, I connected it directly to both TVs that it's not working on and had the same issue.
                                The cables I am using are the Blue Rigger HDMI - Micro HDMI, and the Monoprice HDMI to Micro HDMI
                                I am not using an adapter of any sort.
                                  @jiryn ok, well like i said, the other steps (default image, trivial game, etc) are what i would do to diagnose the issue. good luck
                                  • JirynJ
                                    Jiryn @dankcushions
                                    @dankcushions
                                    Yep! Doing a fresh install and transfer of games as we speak.
                                    The reason I use Jurassic Park as the benchmark is because it always fails at the same time if the sound is going to cut out.. unlike the other games which are random and patchy.
                                    Right now the system works on a Vizio E370VL, Vizio M471J-A2, Vizio V505-G9 (2019 model), and a 32 inch Samsung
                                    It doesn't work on a Vizio M55-E0 (2017 Model) and an LG Nanocell 55NANO75
                                    Thank you for your help all the way!
                                    I just want to squash this issue..
                                    • JirynJ
                                      Jiryn @dankcushions
                                      @dankcushions
                                      Everything is reinstalled, but how do I set the resolution to 1080p 60hz?
                                      When I enter Raspberry config, everything is TINY and I can't read it on 4k, and my streaming software only supports up to 1080/60.
                                      I got to Raspi-config -> Display Options -> Resolution
                                      But all it does is blink and come back
                                        @jiryn https://retropie.org.uk/docs/Pi4/#issues-using-a-4k-tv
                                        • JirynJ
                                          Jiryn @mitu
                                          @mitu @dankcushions
                                          It is working perfectly now thank you!
                                          Your suggestion in the 4k post helped a lot!
                                          Even Jurassic Park!
                                          The only (minor) issues are
                                          #1. whenever I load anything it says
                                          "lul0: Volume Control ::inut() -Failed To Find Mixer Element!"
                                          #2. I forgot how to make them perfectly full screen as I had before.
                                          Spoke too soon, something is really messing up FBneo.
                                          Fixed the mixer by making it HDMI
                                          I am also randomly losing controller connection on a wired controller. When I updated Retropie Setup.
                                          When I tell Retroarch to reset defaults, I lose all controller access.
                                          Final edit, got the sound working again.
                                          Oddly it's related to something I did with the video output on FB Neo that caused the sound issues, by setting it back to default it works perfectly.
                                          It was something in the scaling and video options causing the LG and Vizio sound to screw up
                                          It began to happen with FBNeo as I began to screw with Integer and ratio... when I set it back to default (core) it worked perfect again. No clue why it affected the sound on those TVs.
                                            @jiryn we only get email notifications for your first version of the first version of your post, FYI.
                                            yeah don’t do this. retroarch defaults are not retropie defaults and will not work.
