    lr-mame/lr-mess source code changes and/or will not compile
    lr-messcompilingsource codechangeslr-mame
    20 Posts 4 Posters 1.7k Views
    • FollyF
      Folly
      Hi @mitu,
      @Ashpool and I both tried to install lr-mess from source but many attempts fail :
      https://retropie.org.uk/forum/topic/29682/development-of-module-script-generator-for-lr-mess-lr-mame-and-mame-standalone/1371
      Can you have a look ?
      I tried to install lr-mess from source on 3 different VM's.
      • Debian Buster x86
      • Debian Bullseye x86_64
      • Ubuntu 22.04 x86_64
      All fail directly at start after compressing =/- 80 files.
      Buster has other issues and stops directly in the beginning.
      An says :
      GCC 8.3.0 detected
      fatal: No names found, cannot describe anything.
      Cleaning genie
      Cleaning...
      make: invalid option -- 'a'
      make: invalid option -- 'c'
      make: invalid option -- '='
      # No 'vpath' search paths.
      # No general ('VPATH' variable) search path.
      The others say :
      Compressing src/mame/layout/zapcomputer.lay...
      Compressing src/mame/layout/zodiac.lay...
      Compressing src/mame/layout/zoo.lay...
      make: *** [makefile:1333: build/projects/retro/mamemess/gmake-linux/Makefile] Segmentation fault (core dumped)
      If you need more information then let me know.
        Yes, it seems an upstream change causes the mess subtarget to fail. I haven't had a change to see where this broke, but I'll try to bisect it unless upstream fixes it in the meantime.
        FollyF 2 Replies Last reply Reply Quote 1
        • FollyF
          Folly @mitu
          Good to know that it's probably an upstream failure.
          Again, thanks for looking.
          • FollyF
            Folly @mitu
            @mitu said in lr-mess will not compile / 17 may 2023:
            I removed the subtarget but doesn't make a difference, still not compiling.
            Edit :
            Seems good :
            https://github.com/libretro/mame/tree/cd5f7d077cdab2eac09faf642ddd121d80f3ad1b
            So it's a change something in between.
            ps :
            I did above manually but I want to specify the tree it in the lr-mess module-script.
            Is this the correct way of using a specific tree ? (commit ?) :
            rp_module_repo="git https://github.com/libretro/mame.git master cd5f7d077cdab2eac09faf642ddd121d80f3ad1b"
            mituM 1 Reply Last reply Reply Quote 1
              mitu Global Moderator @Folly
              @Folly said in lr-mess will not compile / 17 may 2023:
              Is this the correct way of using a specific tree ? :
              Yes, it's correct, you specify the branch and the commit (tree ? what's that ?).
              • FollyF
                Folly @mitu
                Ok, good to know that it's correct, I will test.
                Github specifies it as a "tree" in it's url so I guessed it was called like that.
                (mame/tree/cd5f7d077cdab2eac09faf642ddd121d80f3ad1b)
                Though, calling it commit will do, if we mean the same, no problem.
                • FollyF Folly referenced this topic on
                • FollyF
                  Folly @mitu
                  Opened an issue :
                  https://github.com/libretro/mame/issues/362
                  mituM AshpoolA 2 Replies Last reply Reply Quote 1
                    @Folly You should have waited - the issue may be with the build options set by the Retropie-Setup scriptmodule.
                    • AshpoolA
                      Ashpool @Folly
                      @Folly Seem to be fixed now ;) I just tried again in Ubu 22.04 (VM) and the compile went fine.
                      • FollyF
                        Folly @mitu
                        Sorry, sometimes I am a bit too hasty, Will remember next time ;-)
                        • FollyF
                          Folly @Ashpool
                          @Ashpool said in lr-mess will not compile / 17 may 2023:
                          Didn't have time to test it yet.
                          Nice to hear that the issue has been solved ;-)
                          • FollyF
                            Folly @mitu
                            I renamed the topic name a bit to :
                            Seems to be more suitable to what is happening to lr-mess/lr-mame these days.
                            I am doing some tests on the 0255 test branch now.
                            Latest news about that is that :
                            • for now compiling with SUBTARGET=arcade, SUBTARGET=mess is a thing of the past unless you request it again upstream or to select multiple source files or multiple directories for custom builds
                              (I have asked adding SUBTARGET=arcade, SUBTARGET=mess again but I doubt it will be honoured)
                            • some fixes aren't yet in the 0255 test branch, like these ones, but should be merged when the test branch merges into the master-branch.
                              (I have tried to add the Better max geometry fix to the 0255 test branch but for now it will not compile.
                            I think all in all something to be aware of and slowly discuss.
                              Thanks for the updates. When they'll show up in the main branch, we'll tackle them.
                              As a personal observation, I find it annoying and rude when users comment on a WIP PR/branch - especially to report 'issues' when things are still being tested and worked on.
                              • FollyF
                                Folly @mitu
                                @mitu said in lr-mame/lr-mess source code changes and/or will not compile:
                                Ok very reassuring.
                                I get it.
                                • H
                                  HoJo215 @Folly
                                  Keep in mind lr-mame's last official 0.251 is the last one that plays cave's akai katana and dodonpachi saidojou.
                                  These were supposed to be taking out a while back at 0.240 but lr-mame's update progress left them in.
                                  Their officially removed in lr-mame 0.255 coming up.
                                  So you might want to back up 0.251 and have it run
                                  as a secondary option renamed mamearcade_cave_libretro.so
                                  I took a look at the diff's and tried editing them back into 0.255's cv1k.cpp and mame.lst but no dice.
                                  Might be a rendering thing with the newer blitter delay, but the above files are all I see changed.
                                  FollyF H 3 Replies Last reply Reply Quote 1
                                  • FollyF
                                    Folly @HoJo215
                                    @HoJo215
                                    Thanks for the info.
                                    The hope the future of lr-mame/lr-mess will be bright but project seems to be under pressure.
                                    All we can do is wait and see what happens.
                                    Btw .
                                    Do you know why plays cave's akai katana and dodonpachi saidojou ?
                                    Seems very strange removing something that works.
                                    Though I have seen it before with a handheld driver.
                                    • FollyF
                                      Folly @HoJo215
                                      @HoJo215
                                      Seems that today 0.255 test branch got many fixes where we were waiting for.
                                      It's probably time to test it again.
                                      • H
                                        HoJo215 @HoJo215
                                        This post is deleted!
                                        • H
                                          HoJo215 @Folly
                                          @Folly said in lr-mame/lr-mess source code changes and/or will not compile:
                                          @HoJo215
                                          Btw .
                                          It was a c&d from exarcadia who has a license from cave for these two games for they're arcade machine..
                                          • FollyF
                                            Folly
                                            Libretro mame master branch has been updated to 0255.
                                            Compiling for arcade and mess sub-targets has been implemented again.
                                            Hopefully everything will work like it did before.
