    Nexigo Handheld Controller is detected but buttons won’t work
    retropienintendoprocontroller
    12 Posts 2 Posters 2.6k Views
    • L
      Limegreengamer9
      Hey I’m new to RetroPie so I’m a bit of a noob.
      I bought this Nexigo Switch Pro HandHeld controller for a build I am copying from this video:
      I have the exact controller from that however when I go to emulation station it says 1 gamepad connected but it doesn’t detect any buttons I pressed. I have tried jstest and evdev but they don’t work either. With jstest however it says this:
      jstest is not fully compatible with your kernel. Unable to retrieve button map! Joystick (unknown) has 2 axes and 2 buttons error reading invalid argument
      Any help would be great
        If jstest doesn't work there's little change EmulationStation will properly detect the controller.
        What version of RetroPie are you using ? Please add the info requested in https://retropie.org.uk/forum/topic/3/read-this-first in the topic.
        • L
          Limegreengamer9 @mitu
          @mitu Sorry,
          I am using Raspberry Pi 4 Model B 8GB
          Retropie V4.1
          Installed from Raspberry Pi Imager.
            mitu Global Moderator @Limegreengamer9
            Retropie V4.1
            I don't think that's correct, that version didn't support the Pi4. If you've used the RPI Imager, then you probably have the 4.8 version installed.
            You haven't offered details about how the controller is connected - and I didn't follow the video your posted. Is it using USB or Bluetooth ? If it's a Switch controller, then installing the hid-nintendo driver can help (see the Switch Controllers page).
            Update the RetroPie installation, so it's up-to-date, and try installing the driver mentioned above.
            • L
              @mitu Hey I installed the Nintendo driver and it worked! But for some reason the right joystick down and right don’t register.
              And I have updated to the latest 4.8. And my controller is a wired one.
                @Limegreengamer9 said in Nexigo Handheld Controller is detected but buttons won’t work:
                Does it work when testing the gamepad with jstest ?
                • L
                  @mitu Yes I tested it and it seems to work fine for that.
                    OK, so it's not a driver issue. Can you try again configuring the device in EmulationStation ? If that doesn't work, you can configure it manually (see here).
                    • L
                      @mitu Hey it’s been a while since I last logged in,
                      I realised that it actually doesn’t work with jstest. My right analog stick can’t move right and for some reason it has stuck drift for the left but when I try on different devices or steam link it works fine. Why is this?
                        Why is this?
                        Maybe they have a different/newer driver for Switch compatible devices ?
                        • L
                          @mitu I have been using hiv Nintendo I believe it’s called do you have any others?
                            @Limegreengamer9 I don't 'have' any other drivers.
                            You may try to see if the gamepad works with a more recent Linux kernel, with the drivers included there. Boot with a recent Raspberry Pi OS Lite and try to run jstest there to see if all inputs are properly detected. You may need to install the joystick package for the jstest command.
