    Need Some Advice Please
    retropiehelpnewuserromsets
    94 Posts 14 Posters 48.8k Views
    • rbakerR
      rbaker @awsd12
      @awsd12 said in Need Some Advice Please:
      but I dont know where the files go
      I cannot then accept that you have read the instructions. For cave story, they state:
      Create a folder called CaveStory in
      /home/pi/RetroPie/roms/ports/
      Add all of the game files into the CaveStory folder- particularly Doukotsu.exe into
      /home/pi/RetroPie/roms/ports/CaveStory
      I am actually serious. I do read the wiki's
      No, I am not believing it due to the questions being asked. I'm starting to think along the lines of @Ekstreme
        awsd12 @rbaker
        @rbaker
        If it comes across that way my bad, I don't think I am getting the right Cavestory Files so aint going to bother about it. However when I press Tab on my keyboard to edit in game settings such exit back to in game main menu, it doesn't show up I can press select and start to exit the game but it doesnt take me back to the main charcter or game menu ( I m only playing SF3 atm
        rbakerR 2 Replies Last reply Reply Quote 0
        • rbakerR
          rbaker @awsd12
          Why not? You simply download the game that was originally freeware back then. You then locate the patch and run it on the .exe file. You then drag the patched Doukutsu to the folder you made (all according to the wiki instructions) together with the other files that come with the game and when you go to Ports and choose Cave Stoy, it loads up and runs perfectly in English. What did you do to have it not work?
          • rbakerR
            rbaker @awsd12
            This is a feature of MAME, not FBA.
            A 2 Replies Last reply Reply Quote 0
            • Z
              Zigurana @awsd12
              @Ekstreme
              Taking the piss ? I am actually serious. I do read the wiki's and ask about things I don't understand or ask for a direct link.
              Well, if you are truly making an effort, could you please help us out? You too can contribute to this project by going back to the wiki pages you tried to understand earlier, and see if you can clarify what is written there. It is only with feedback from beginning users like you, that we can improve the documentation.
              Even if you can just point out those parts you think are unclear, and how they should be improved, that would be a help.
              This way, everyone benefits, especially new users!
                awsd12 @Zigurana
                @Zigurana
                Sure, didn't know I could edit others wiki or forums thought only admins could, but sure from now on if there is something I have tried and haven't understand I'll link it and suggest edits that could be made :)
                  awsd12 @rbaker
                  @rbaker
                  Ok thank you
                    awsd12 @rbaker
                    @rbaker
                    Hhahai failed at updated the file didin't read the (readme) text in thedownload LOL :)
                    • DominusD
                      Dominus
                      I need some help. I keep trying to post a new topic, but it says "Not enough tags. Topics must have at least one (1) tag." I have typed in a topic, long or short and it keeps saying it. (Sorry for hijacking this thread, but I couldn't post anywhere... heck I don't even know if this will work lol)
                      Never mind... I figured it out after a couple hours lol.
                      A G Y 3 Replies Last reply Reply Quote 0
                        awsd12 @Dominus
                        @Dominus
                        Don't worry about it, I had to hijack someones else thread until i figured it out myself too LOL, btw look at this thread if you are new heaps of dumb questions I asked maybe some help to you :)
                          awsd12 @rbaker
                          @rbaker
                          Hey baker sorry to bother you once again, but im in a dilemma, I got 029738 romset and 2003 mame refernce set. 029738 romset is 10gb and has 4,000 roms inc parent and clones and the 2003 mame refernce set is 17gb and has 2,000 parents and clones, i was wondering do mamae and fba games overlap ?, so I wouldnt have to xfer the 17gb mame refernec set and save that space for other emulators. cheers
                            awsd12 @awsd12
                            @awsd12
                            Scrapped some games then I added the Pixel them, and now when i Press f4, it takes agaes for command line to show up and when it does it doesnt show any prevouis commands liek it used to now it just shoes => (pi@retropie@"-$ ) WTF did I do wrong or pressed ?
                            • rbakerR
                              rbaker @awsd12
                              You just need to read the wiki. On there, there is a very clear FAQ section. In that section, there is this:
                              https://github.com/RetroPie/RetroPie-Setup/wiki/FAQ#why-does-shut-down-and-reboot-take-ages
                              I had this problem and it was solved by reading those instructions to stop it from happening. It is even marked under troubleshooting to make it easier to locate.
                              i was wondering do mame and fba games overlap ?
                              I will assume that you are asking if the same game exists in FBA and MAME? If so, you need to re-read the concepts behind how the emulation of the roms are handled. Games dont "appear in" an emulator. You have to think of the rom file as the original dumped code in a zipped package. If it is zipped and named incorrectly, the emulator of your choice will not run it, hence the romset versions. These versions will only execute with the emulator that they have been compiled for. They evolve over time - you did read those links I posted days ago on this right? Each romset will contain hundreds of identical games but you will not be able to run those games on multiple emulators, hence the need to offer the variety of MAME and FBA versions. I use lr-mame-2003 for most things but for vector games, advancemame is superior and also offers trackball support. I like MAME4ALL due to its performance but lr-mame allows use of the pi-crt shader to emulate scanlines. Each set can only be used according to the dat file. By now, you should know that if you have a recent version of mame roms, you could rebuild any set to any version using clrmamepro if you can be bothered. I did it because I had a 0.111 set and didn't want to download another 50GB. You can also locate "lite" versions of the dat files that remove all the duplicates and some game types to make a cleaner set for the menus.
                                grahamken @Dominus
                                @Dominus Can you please advise. I'm clearly not the most intelligent of lads as I don't seem to be able add Tags either :(
                                DominusD 1 Reply Last reply Reply Quote 0
                                • DominusD
                                  Dominus @grahamken
                                  @grahamken Haha yeah I should have put what I did. On the bottom left under the title and message it says "Enter tags here" or something similar. I think you just put keywords in there.
                                    grahamken @Dominus
                                    @Dominus Thanks Man, really appreciate it. Not so obvious, so don't feel too dumb.
                                      awsd12 @rbaker
                                      @rbaker
                                      I reformatted my sd card and got retro pie 4.0.2 but, now I have the rainbow box flash in the middle of the screen and when i go into command line by pressing (f4) and type Add disable_splash=1 in /boot/config.txt in one line it says (-bash: in: command not found ) ?
                                      Pi@retropie:- $ disable _splash=1 in /boot/config.txt
                                      -bash : in: command not found
                                      • EkstremeE
                                        Ekstreme
                                        You have to edit the file. Come one man, this is basic 2 second google stuff. I'm not watching or replying to this thread any more
                                          awsd12 @Ekstreme
                                          @Ekstreme
                                          Link to how to edit file and how to do it ?
                                          EkstremeE 1 Reply Last reply Reply Quote 0
                                          • EkstremeE
                                            Ekstreme @awsd12
                                            @awsd12 http://lmgtfy.com/?q=how+to+use+google
