    Need Some Advice Please
    retropiehelpnewuserromsets
    94 Posts 14 Posters 54.3k Views
      awsd12 @Ekstreme
      @Ekstreme
      HAHAHAH Nice one :)
        awsd12
        Hello guys,
        I was wondering if i can scrape roms that have numbers infront of them like 2607-Zelda for GBA using Steven Selph's Scraper or does Steven Selph's Scraper scrape roms using rom hash ?. I read https://github.com/retropie/retropie-setup/wiki/scraper but doesnt mention anything regarding numbers infront of roms
        Thank you
        DominusD 1 Reply Last reply Reply Quote 0
        • DominusD
          Dominus @awsd12
          @awsd12 I haven't tried it myself with Steven's, but the ES Scraper did not find anything till I removed the number on one of my roms (A Final Fantasy VII rom for the NES, which should have produced some kind of result). If it doesn't work you can try to get a mass renamer for your roms specifically, or mass renamer like Métamorphose that might be easier to use then renaming them all individually.
            awsd12 @Dominus
            @Dominus
            Yeah Doesn't really work, another thing I found out was most of Neo Geo games are in my FBA romset ahahahha so at this time I dont really care anymore its just to much of a hassle.
            FloobF 1 Reply Last reply Reply Quote 0
            • FloobF
              Floob @awsd12
              @awsd12 Yes, it works based on hashes, so filename itself not important. Unless its MAME/Arcade games then the filename is important obviously.
                awsd12 @Floob
                @Floob
                Cheers, read it but not detail, has anyone unscraped roms ?, meaning getting rid of the images instead ?
                  awsd12
                  Is there a way I can make games more clear ?, like for example street fighter alpha 3 in FBA, it is a bit pixelated and I was wondering If I could make it more clear like 1080p or 720p clear ? or less pixelated
                  Cheers
                    grahamken @awsd12
                    @awsd12 It's not too hard to do when using retro arch in the retroarch cfg for each system... Once you know how. Haven't tried it withFBA, but will have a look into it today and get back with my findings.
                      awsd12 @grahamken
                      @grahamken
                      thanks
                        awsd12
                        hello guys i did this to fix the boot times and now when i scrape roms it doesn't show any j pegs https://github.com/retropie/retropie-setup/wiki/FAQ
                        Cheers
                        • Y
                          Yellowball @Dominus
                          @dominus And how did you manage it???
                          I can find not a single hint to this.
                          • DominusD
                            Dominus @Yellowball
                            @yellowball About posting? In the bottom left is where you have to put your "tags" before it will let you post.
                              Perseides
                              Sorry for digging up an ancient post because this is the only post that mention about tagging.
                              Some one mentioned "On the bottom left under the title and message it says "Enter tags here" or something similar." but I seriously cannot find any place to put the tag for a new post...?
                              Sorry. Am Retarded.
                              Mods please do not ban me.
                                mitu Global Moderator @Perseides
                                @perseides The new post dialog has an input where you can add tags, it's at the bottom, where it says Enter tags here :
