    Need Some Advice Please
    retropiehelpnewuserromsets
    94 Posts 14 Posters 52.1k Views
      PetroRie @awsd12
      @awsd12 said in Need Some Advice Please:
      When I have roms or if I get romsets which I can't find do I have to extract/ unzipp them ?
      When I have the Bios file do I extract it ?
      No you should keep them as a zip file (at least the one I'm using are requiring this). Some systems require the BIOS files to be in the roms directory (neogeo for an example) and the PSX emulator requires them to be in the BIOS folder.
      You don't extract them. Just keep them as a ZIP file. Most emulators can handle ZIP files, also an another reason why to keep the files zipped is they will save you a lot of space on your storage device.
      Can i not just get roms and place them on a USB and transfer to Pi ?
      If you want to load them via USB you need to edit some files. Normally it loads everything off from the SD card.
      i Don't know what some of the names stand for.
      Just use the wiki page to get more information about the system.
      Also make sure you get a good SD card. If you're planning to play PSX games get a 64GB card.
      @Ekstreme @awsd12 Just listen to what he said he's right. Keep it simple. I have the entire NES romset on my Pi but how much of those games did I play?
        awsd12 @PetroRie
        @PetroRie
        Yeah I understand you do not play the entire set but just want to get so I don't have to go back and fourth. My question was do I need to make a romset for nes,neo geo etc or is it just for mame and fba that I need the dat file to make a romset ? if someone understands what I am saying. Also is it better to xfer roms via net or usb just incase I wanted to delete some roms that were not working or lets say didin't want since thier were multipe ?. Could I just xfer via usb and edit my usb after then replug the usb to rewrite the roms ? nvm ill read the wikis
          PetroRie @awsd12
          Clrmamepro is only for MAME games. For the other systems you mentioned it's just copy n paste into the right directory. I always upload roms on my RetroPie trough network, The RetroPie makes a network shared directory for the roms. I never used the USB method to transfer roms, because in my opinion trough net (shared folder) you have a better overview and this is how almost everyone does it. If you want to delete roms you just acces the rom folder and delete the files trough the net.
            awsd12 @PetroRie
            @PetroRie
            Thanks for clearing things up, Lets say I only place 1 game in each of the corresponding emulators then scrape the folders to get game art, would I have to do this again for the new games I add later on ?, just asking to deiced to either place all roms in the emulators and scrape all then delete roms i don't like etc .
            On the side note I notice In my usb file emulators I don't have all the emulators such as Dreamcast etc ?
            P rbakerR 2 Replies Last reply Reply Quote 0
              PetroRie @awsd12
              When you scrape it only downloads the info of the roms which are in the folder, before you scrape it's going to ask you which systems you want to scrape. If you add new games you have to scrape them.
              Just check the roms folder, the dreamcast rom folder is in there. Dreamcast emulator is included.
                awsd12 @PetroRie
                @PetroRie
                Ok might be there but I mean in the in the USB files you get it doesn't have a dream cast folder were you could potentially place roms
                • rbakerR
                  rbaker @awsd12
                  https://github.com/retropie/RetroPie-Setup/wiki/FAQ#why-do-some-emulators-not-show-up
                    awsd12 @rbaker
                    @rbaker
                    Couldn't find the answer it says you have to put roms inside it for it to show up in emulator, but my question is that I have No folder to put dreamcast roms into if i had any in teh first place
                    • rbakerR
                      rbaker @awsd12
                      @rbaker
                      https://github.com/retropie/RetroPie-Setup/wiki/First-Installation:
                      "On RetroPie 4.0, not everything is installed by default. The pre-made image ships with libretro emulators with a few standalone emulators such as mame4all, mupen64plus and pifba. Ports like quake and doom and other software like ScummVM can be installed later.
                      Software can be installed from the RetroPie-Setup script - which is accessible from the RetroPie menu on Emulation Station. Once there you can Navigate to "Packages" where you will see various section. You can see available packages in each section and which ones are installed. Stable additional packages are under the "Optional" section, with more unstable packages listed under experimental. The packages are ordered by type (emulators / libretro cores / ports), then alphabetically. By selecting a package you can choose or install it, or remove it. Some packages also have additional configuration."
                        awsd12 @rbaker
                        @rbaker
                        hey rbaker, I should use the program to make my romset then It's ok If i start with one rom intially xfering it to the pie via usb and scraping it, then xferng the rest of the roms I want via .net ?
                          awsd12 @dankcushions
                          @dankcushions
                          Hey dude I got the Mame 2003 reference set, dammm that was a huge file, however I also manage to get 0.173 (fba 0.2.97.38), Im in a pickle I want to get Street Fighter 3 on my pie but don't know which verison is english or what files i got. A link to the picture => https://gyazo.com/e10fba0a6f546939bd2d413b55ab706b , If I wanted to pay SF3A which files would I xfer don't know if this set is non merged, spilt or merged, if you could advise me would be helpful and if its the same with mame 2003 reference set ?
                            dankcushions Global Moderator
                            @awsd12 in the FBA set street fighter 3 3rd strike is called sfiii3.zip - put that in your fba folder and you're good to go!
                            with mame, if you downloaded the full reference set I told you to, you can just put any of the game zips in that in the mame-libretro folder and they will work. if you look on the wiki page the 'compatibility lists' show the file name and the full name for each game.
                              @dankcushions
                              Bro I got FBa romset 02.97.38, and in it, it has heaps of files, I don't know which 1 i xfer O.o https://gyazo.com/b9f0cd7a5cbbbeba614d1626c10ad3cf and i don't know if this is non merged or spilt
                              dankcushionsD FloobF 2 Replies Last reply Reply Quote 0
                                dankcushions Global Moderator @awsd12
                                @awsd12 I told you the filename and it's in your list. you got this. I believe in you.
                                • FloobF
                                  Floob @awsd12
                                  @awsd12
                                  Transfer the one called sfiii3 - its in your screenshot.
                                    @dankcushions
                                    HAHAHAHAH IT WORKS WELL I SEE FBA EMUALTOR AHAHAHAHAHAHAHAH :D THIS JOURNEY HAS BEEN A LONG ONE. HAHAHAHAH however my other question is how do i get ports so I can play cave story and get kodi ? and how do I know what files i have to xfer from x set ?
                                    • rbakerR
                                      rbaker @awsd12
                                      @awsd12
                                      https://github.com/retropie/retropie-setup/wiki/cavestory
                                      https://github.com/retropie/retropie-setup/wiki/KODI
                                      why do you continue to ask these questions?
                                        awsd12 @rbaker
                                        @rbaker
                                        Because you guys are caring people that answer my questions when i Don't understand the wiki :), I get ports and kodi but I don't know how to get cavestory to pie I knw I have to get the file and enlish update thingy but I dont know where the files go ?, In port do I just drag both of them in ?
                                        • EkstremeE
                                          Ekstreme
                                          I've been following this thread and biting my tongue, but surely you're taking the piss now?
                                            awsd12 @Ekstreme
                                            @Ekstreme
                                            Taking the piss ? I am actually serious. I do read the wiki's and ask about things I don't understand or ask for a direct link.
