    [SOFT] Universal XML Scraper V2 - Easy Scrape with High Quality picture
    scrapescraperuxs
    728 Posts 111 Posters 873.5k Views
      partTimeNinja
      Hello, thank you for the scraper! I'm pretty excited to try it out. Looks like i'm not able to connect to the database at the moment, is that due to the website being down? I tried the mirror site and I could browse there, but still getting the same error when trying to run the program. I updated everything to 2.2.0.3 and still getting the errors: universal xml scraper fatal error! (problem connecting to the database).
      From other posts, it looks like this is a known issue when the site is down for maintenance. I tried to un/re/install, turned off my A/V for a bit, ran as admin, all with the same results. I'm sure if the site says its down, that is my problem. Always my luck. The one night that I have to sit down and mess with it for more than 30 mins and the site is down. lol oh well.
      I'm using windows 7 - 64 bit, and UXS 2.2.0.3. Any help would be greatly appreciated!
      Thanks again!
      Here are my LOGS.txt file.
      • [22:43:33] - /!\ Error Downloading File : C:\Users\Delft\Documents\retroCade\Universal-XML-Scraper-2.2.0.3\Ressources\systemlist.xml
        [22:43:33] - /!\ Bytes read: 0
        [22:43:33] - /!\ Size: 0
        [22:43:33] - /!\ Complete: True
        [22:43:33] - /!\ successful: False
        [22:43:33] - /!\ @error: 13
        [22:43:33] - /!\ @extended: 12038
        [22:43:34] - /!\ Error Downloading File : C:\Users\Delft\Documents\retroCade\Universal-XML-Scraper-2.2.0.3\Ressources\systemlist.xml
        [22:43:34] - /!\ Bytes read: 0
        [22:43:34] - /!\ Size: 0
        [22:43:34] - /!\ Complete: True
        [22:43:34] - /!\ successful: False
        [22:43:34] - /!\ @error: 13
        [22:43:34] - /!\ @extended: 12038
        [22:43:34] - > -In 3 try and 1.51s
      • paffleyP
        paffley
        Hi, is it possible to have a combination of 3d boxart and cartart only? (cartart slightly in front of boxart)
        • E
          EctoOne @paffley
          @paffley You can make your own Mix Template.
          https://github.com/Universal-Rom-Tools/Universal-XML-Scraper/wiki/[TUTO]-Making-a-MIX-Template
          • paffleyP
            paffley
            Thanks @EctoOne :) ............Just checking before i create the xml, has a custom 3d boxart/cartart Mix template been created before?
            • E
              EctoOne @paffley
              @paffley I don't know. I'm almost sure that no one has shared a custom MIX profile in this thread tho.
              I tried to make one some time ago, but it was worthless because of layer issues back then. And it's also a little bit tedious to make MIX templates, because you have to rescrape after every change to check the results.
              • paffleyP
                paffley
                @EctoOne ahh got ya, thanks for the heads up! :)
                • AndersHPA
                  AndersHP
                  Anyone else getting the fatal error (problem connecting to the database) at UXS startup?
                  It worked earlier today, but now I just cannot get it going, but screenscraper.fr seems to work?
                  My Gameboy
                  Impman66I 1 Reply Last reply Reply Quote 1
                  • Impman66I
                    Impman66 @AndersHP
                    @andershp Had the same problem last night, may be updating something
                    Pi Model or other hardware: Raspberry Pi 3 Model B
                    Power Supply used: Generic 5v 2.5A Panasonic
                    RetroPie Version Used : 4.5.1
                    Built From: Retropie website
                    USB Devices connected: 2 x Dragonrise N64 Encoders
                    AndersHPA 1 Reply Last reply Reply Quote 0
                    • AndersHPA
                      AndersHP @Impman66
                      @impman66 what about now?
                      My Gameboy
                      • hooperreH
                        hooperre
                        @AndersHP Site is now down as well.
                        4B ~ RPi PSU 5.1V / 3.0A ~ 32GB SanDisk microSD ~ 128GB USB
                        • Impman66I
                          Impman66
                          Yep nothing working
                          • AndersHPA
                            AndersHP @Impman66
                            @impman66 Seems everything's up again. Be quick and use it before I make everything crash again XD
                            My Gameboy
                            • Impman66I
                              Impman66
                              @andershp said in [SOFT] Universal XML Scraper V2 - Easy Scrape with High Quality picture:
                              Nice one thanks, will have a try :)
                              • Impman66I
                                Impman66
                                Have just used it to scrape the ROMs again, this time with video snaps, worked lovely. Only one issue was that the Commando video snap was of a weird Space Invaders type clone.
                                So will have to find the location these videos are saved in, and replace it with the correct one.
                                Loving this Scraper, when it works as it gives beautiful results. Now the only thing left to do is to try and design my own Theme based on my favourite Sci-Fi programmes :)
                                • paffleyP
                                  paffley
                                  Hi @screech , I've tried to make a custom xml for 3d boxart and cartart but its not working correctly for some reason, if i upload the xml would you take a look please?
                                  XML all seems fine.
                                  When I try to choose the custom Mix, it displays author -1 etc.
                                  When I try to scrape - no images are being scraped, well they are but nothing being exported from screenscraper by the looks of it.
                                  • screechS
                                    screech
                                    Happy New Year everyone
                                    Sorry guys (and girls), I weren't here a lot's these last weeks.
                                    Life work take me a lot's of time lately.. But normally I will be a little more present now ^^
                                    Sorry too for the server issue. Something at our provider turn wrong and the server CPU burn at 100°C permanently so we had a hardware changement. Normally all is good right now..
                                    @paffley no problem ;) just use a pastebin so I can take a look at your XML ;)
                                    (Don't forget some "important things" like your Mix Profil must be in a zip file without folder in the zip, the zipfile must have the same name as wrotten in the XML, relaunch UXS and choose your MIX profile ;) )
                                    • paffleyP
                                      paffley
                                      @screech spot on! Thank you, I had made the mistake of zipping up the folder as well as the files - all sorted now thank you! :)
                                      • screechS
                                        screech
                                        @paffley Nice ;)
                                        Don't hesitate to post a screen, and if you want, I can put your MIX in the UXS Repository so everyone can enjoy it ;)
                                        • Impman66I
                                          Impman66
                                          For those that don't know, found the location of video's and images for the scrape here;
                                          \RETROPIE\configs\all\emulationstation\downloaded_images
                                          Then select the folder you want.
                                          As I know nothing of Linux, I do all this over the wireless network at home, including file manipulation, such as deleting roms or adding them. In this case I just put in the correct Commando video snap, and renamed it to commando-video (didn't change any extensions). deleted the bad one and then restarted emulation station and bingo worked fine.
                                          Hey this forum works, I am actually learning a bit :)
                                          • hooperreH
                                            hooperre
                                            Is XML Scraper down? I see 'Skraper' is now front and center. Has it replaced XML, @screech?
                                            Also, now that I'm thinking about it... For some reason with Chrome, I cannot log in. All my extensions are disabled.
